Old 07-24-2013, 06:07 PM   #1
Khánh
Khánh's Avatar
Drives: sc00ter
"dEAD CLICKS" ON TEIN ST FLEX
is there such a thing as dead clicks on tein flex? I recently installed Street flex, and there are 26 clicks. the description for flex are 16 ways dampener, so the rest of the clicks are useless? Is this a common thing for tein? for any coilovers?
Khánh is offline   Reply With Quote
Old 07-24-2013, 06:10 PM   #2
sidnacious
sidnacious's Avatar
Drives: Argento FR-S
Yes that is correct, my Tein Flexes are the same way. I was worried about it so I asked my friend that works at Tein. It does nothing past 16 clicks.
sidnacious is offline   Reply With Quote
Old 07-24-2013, 06:24 PM   #3
Khánh
Khánh's Avatar
Drives: sc00ter
ah cool thanks.. pass 16 clicks meaning on the hard side right?
also which way is hard? clockwise ?
Old 07-25-2013, 12:49 PM   #4
sidnacious
sidnacious's Avatar
Yup clockwise is stiff and counter-clockwise is soft. I clicked it all the way to soft(counter clock) and then counted up to the stiffness to my liking. GL!
Old 07-25-2013, 01:10 PM   #5
CSG David
CSG David's Avatar
Start from full stiff and the back off from there. Definitely not an issue for the shock. My set of custom valved TEIN SRC CSG Spec on the S2000 have 30 clicks on rebound and compression, but only the top 16 clicks work. It still runs like a champ.
Old 07-25-2013, 01:35 PM   #6
sidnacious
sidnacious's Avatar
"Top 16 clicks" as in if you were to turn it all the way clockwise until it stops? Then turn counter clock until desired? Thank you, I did not know that. I must get off work and try this....
Old 07-25-2013, 02:02 PM   #7
CSG David
CSG David's Avatar
Basically go full stiff, which is clockwise until you can't click. If you feel a half click when you turn counterclockwise, that is either click 1 or the next click is the 1st click. This is just to give a safety buffer on the valve adjustment. Then back off about 8 clicks which is in the middle. Drive on the road a bit and find out if it's hopping over bumps or soaking them. Adjust from there.
Old 07-26-2013, 08:48 AM   #8
Teo
Teo's Avatar
This middle setup 8clicks back from stiff is for all 4shocks?
Or you suggest more click in the front (stiff) and less in the rear?
Teo is offline   Reply With Quote
Old 07-27-2013, 01:53 AM   #9
Khánh
Khánh's Avatar
Drives: sc00ter
great stuff. thanks man if it's hopping, i should add more clicks?
Old 07-27-2013, 09:16 AM   #10
wparsons
wparsons's Avatar
Hopping or bouncing? Hopping I would say go softer, bouncing go stiffer.
flickr
Old 07-29-2013, 01:48 AM   #11
CSG David
CSG David's Avatar
What wparsons said.
Bouncing means it's too soft. Hopping means too stiff.
Old 03-10-2019, 02:36 PM   #12
Nickmann
Nickmann's Avatar
Drives: Subaru BRZ 2017
Sorry for digging out this old thread, but as you can see on my thread from two days ago, I've got the same "problem" with my Teins. I can turn the adjustment knob about 30 times until it stops clockwise or counter-clockwise.
Hopefully one of you guys from this old thread will read this:
Did it harm your coilovers somehow on the long run when you set the dampening adjustment at above the 16 recommended clicks counter-clockwise? Or did you recognized any disadvantages from turning the knob on the "dead clicks" range? Since this thread is a bit older, maybe someone can report about what happened on the long run with your Teins when using the "dead clicks" or turning once the knob to this dead click range.
Thanks so far.
From Germany...so please be sorry if some sentences are incorrect
Nickmann is offline   Reply With Quote
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Borla UEL flex sections "loose"? Fast_Freddy Engine, Exhaust, Transmission 28 07-24-2013 09:13 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
