Old 03-12-2013, 11:09 AM   #15
MI FR-S
MI FR-S's Avatar
Drives: Ultramarine FR-S MT
I had the dealer look into this for me (amongst many other things) and they replaced the center HVAC vent surround.
So far so good.
MI FR-S is offline   Reply With Quote
Old 05-21-2013, 04:15 PM   #16
2013BRZ
2013BRZ's Avatar
Drives: 2013, Galaxy Blue Silica, Limited
I solved this issue today.
I removed the radio surround, starting in the lower right corner of the panel.
I unbolted the 4 10mm bolts and removed the radio - wow, a lot of plugs.
Then I shimmed all of the plastic between where the radio would have been, and the vents above it to add pressure between all the panels. I used cardboard and surplus 1/8"TH Dynaliner as shims.
Upon replacing the radio, I stuffed a couple sheets of cardboard between the radio and plastic between the radio and vents, again to add some pressure. After reinstalling the radio and snapping the surround back into place, there are no more rattles from this area of my car.
Win.
2013BRZ is offline   Reply With Quote
Old 05-21-2013, 04:49 PM   #17
captain_jack
captain_jack's Avatar
Win.
I woukd definitely use something other then cardboard. The radio will get hot and cardboard does not belong in a dash. Use plastic or metal. Not paper products.
Sent from my SPH-L900 using Tapatalk 2
Old 05-26-2013, 08:29 PM   #18
Indestruct
Drives: 2013 SWP Limited BRZ, MT
I have this rattle on my brz limited, it's killing me! Everyone thinks i'm crazy too. If I stick my hand in the phone holder and push UP, I can suppress this rattle. One of these days i'm gonna take the whole thing apart and apply gorilla tape on every lose piece.
Indestruct is offline   Reply With Quote
Old 05-30-2013, 02:54 AM   #19
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
I have this really annoying rattle now too. Could someone please post pics or video of how to get rid of this, or explain the process in more exact detail. Thanks!!
UPDATE: Laika gave me a hand trying to fix this today. We put foam padded tape above and below the radio and on top of the phone cubby. The rattle is still there unfortunately...it still seems like pushing up on the inside of the phone cubby makes it go away. Any tips would be appreciated!
Phaedrus29 is offline   Reply With Quote
Old 07-14-2013, 09:17 PM   #20
Phaedrus29
Phaedrus29's Avatar
bump for help???
Old 07-16-2013, 07:18 PM   #21
Indestruct
Check this out Phaedrus, looks promising http://www.ft86club.com/forums/showthread.php?t=19533
Also here are instructions to remove all the stuff.
http://www.ft86club.com/forums/showthread.php?t=8336
Old 07-17-2013, 06:11 PM   #22
Phaedrus29
Phaedrus29's Avatar
Wow thanks for directing me to this Indestruct!!! I just did the zip ties and that seems to have done it! It didn't even require removing that much...just taking out the phone cubby with USB port. Thanks again!
Old 09-12-2013, 07:22 PM   #23
Phaedrus29
Phaedrus29's Avatar
Just an update that this rattle started to come back a bit even though I had the zip ties installed. BUT, I had the HVAC out for a mod, and I cut the zip ties hoping to be able to locate the rattle with everything open. The rattle didn't occur, so I started putting things back piece by piece and checking for the rattle after each part. The rattle didn't come back, and hasn't come back in a couple weeks (even though there are NO zip ties or anything now)! So the cause of this rattle may have something to do with the HVAC connectors being loose or something. I'd advise taking out the HVAC and then putting it back in making sure all of the connectors are secure. Worked for me (for now at least)!!
FS/FT: OEM FRS Center Caps (Trade for Subaru Center Caps) Meeners Wheels and Tires 4 11-20-2012 05:47 PM
Rattle from the middle of the car brichard0625 Issues | Warranty | Recalls / TSB 11 10-05-2012 08:04 PM
Does anyone have a rattle coming from the center dash? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 29 09-30-2012 11:09 AM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 08:46 PM
FR-S center stack blk Scion FR-S / Toyota 86 GT86 General Forum 81 02-29-2012 02:03 AM
