#71 |
NASA SpecE30 Racer
Wanted to update this thread with my opinons on the Full Blown oil cooler kit. The majority of the pieces are off the shelf Mocal items and your standard AN oil lines. The only truly custom piece is the mounting bracket for the outside of the oil cooler that connects under the passenger side headlight. This is similar to the Perrin kit that only contains stand offs for the bottom of the oil cooler. I was e-mailed a set of directions, and they had good pictures that made sure I knew where things were supposed to go and made recommendations such as using high temp sealant on the fittings going into the oil cooler instead of teflon tape (which I usually use).
You will need to take special care when mounting the oil cooler to make sure that you leave clearance for the driver side fitting on top of the oil cooler. It is very close to the bracing that comes out and holds the bumper bar. I would recommend you install the fittings on to the oil cooler before mounting it and tightening everything down. The driver side of the oil cooler mounts to a hole in the bottom radiator core support. That happens to be the hole that the Full Blown turbo kit uses to remount the horn. The instructions didn't mention that, but I just relocated it to the bolt that holds the A/C condensor to the radiator. The only real downside to the kit was that both oil lines were about a foot too long. I had to take each AN fitting apart and cut the lines to the proper length and reassemble. Since the kit tells you exactly where to run the lines, I would have expected them to be the correct length, but I understand a little flexibility for possibly needing to modify that routing. At the end of the day, the kit fits great and had no leaks: ![]() ![]() ![]() ![]() ![]()
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following 8 Users Say Thank You to King Tut For This Useful Post: | akuhei (07-15-2013), Dezoris (07-15-2013), Dipstik-sportech (07-15-2013), FullBlown (07-15-2013), Kiske (10-29-2014), Pitman (07-20-2013), pmccut (07-15-2013), Sportsguy83 (07-15-2013) |
#72 |
I really need to re-do my lines seeing that. You running -10AN fittings?
#73 | |
NASA SpecE30 Racer
- King Tut
#74 | |
Professional Smartass
Drives: White Out FRS
#75 |
Drives: Scion FRS
They are all -10 lines.
#76 |
NASA SpecE30 Racer
I will try and get some good logs tonight to compare to my logs before the oil cooler install. Here is my before post:
Ambient temp tonight will most likely be in the 80s.
- King Tut
| The Following 2 Users Say Thank You to King Tut For This Useful Post: | Jrdad (04-07-2017), post_break (07-15-2013) |
#77 |
How safe will this run in the winter time, cold start?
#78 |
NASA SpecE30 Racer
It has a thermostat, so I assume it will work as well as any other car that has an OEM oil cooler. On cold start the oil will be cold anyways, the thermostat will allow it to warm up as soon as possible. If you are really worried you should have an engine block heater to prewarm the oil.
- King Tut
#79 |
Drives: Scion FRS
Should be ordering this later this month, I am thinking about removing the washer fluid bottle and mounting it in that area instead.
#80 |
NASA SpecE30 Racer
Before:
65F Ambient Temp 25 minutes 12 3rd Gear Pulls from 2500 RPM to 8000 RPM 131C/268F Oil Temps After: 85F Ambient Temp 4 minutes 7 3rd Gear Pulls from 2500 RPM to 8000 RPM 111C/232F Oil Temps
- King Tut
| The Following 7 Users Say Thank You to King Tut For This Useful Post: | Boba_kz (05-28-2014), FullBlown (07-24-2013), jamesm (07-19-2013), post_break (07-19-2013), Sportsguy83 (07-19-2013), Thorpedo (02-14-2015), whataboutbob (07-19-2013) |
#81 |
That's hot. (before) But it's amazing because of the location of the radiator. I think it's safe to say I'm sticking mine behind the fogs as well since it's obviously still working.
#82 |
Yeah that's awesome. Ill probably put one in the same place. I was going to open up the mesh on that one side but it definitely doesn't seem necessary.
#83 | |
NASA SpecE30 Racer
- King Tut
#84 |
Drives: Scion FRS
Buddy, which fittings leak. Please let us know, we alot of kits out there without any issues. Call us monday and I will send out a new line/fitting kit.
| Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 09:10 PM |
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 05:30 PM |
| One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 06:42 PM |
| You want it, you got it: PERRIN Oil Cooler GB | JoeBoxer | Groupbuys | 96 | 06-16-2013 04:10 PM |
| Best oil cooler | whitefrs | Engine, Exhaust, Transmission | 4 | 02-22-2013 12:36 AM |
