Old 07-14-2013, 08:26 PM   #141
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
When you go through the programming process, you Query the ECU to pull the ECUtek parameters -- including the license. I flash without an Internet connection. I do, however, update ECUtek software when I get a new tune. Just to ensure that the versions match up.
A partial flash will certainly bork things up. I made sure to disable and power saving features in Windows to ensure that it didn't put the computer or USB to sleep while programming.
Hope you get it sorted out!
cobrabyte is offline   Reply With Quote
Old 07-14-2013, 08:27 PM   #142
Visconti
Drives: 05 STi
Rich sometimes says shit that blows my mind.
No Internet connection needed.
And for those who are bitching about the lost license thing, i feel your pain .. Trust me.
Just so happens that I've really been pushing ecutek for a fix and tomorrow a new version of ProECU will be available that will fix this issue.. Yes no more lost license .
Still never got a response to my launch control , flat door shifting , ecu recovery , immobilizer disable, AF correction #3 disable, boost cut for turbo cars..guess brzedit doesn't have that.
Saved two motors last week with my racerom boost cut.. I must have saved at least 20 motors this year with that feature.. Something brzedit does NOT have.
John
Visconti is offline   Reply With Quote
Old 07-14-2013, 08:28 PM   #143
Visconti
Drives: 05 STi
Originally Posted by swift996 View Post
I'm going to try laptop #3 tomorrow, might get a different cable, hopefully they can get to the bottom of it. Just sucks being stuck in your driveway with no other car.
I've seen several cars with bad OB2 ports
Old 07-14-2013, 08:39 PM   #144
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
There's a bunch of threads with people reporting this. Pins slightly pulled out, etc. Seems ours is a bit fragile. Would it still successfully query/sync with the ECU and just not flash if that were the case, or would it not have any connectivity? I suppose it depends on the pins pulled.
Nightbringer is offline   Reply With Quote
Old 07-14-2013, 08:40 PM   #145
Visconti
Drives: 05 STi
No connection at all.. But sometimes connection isn't that good and disconnects or drops out during the flash
The Following User Says Thank You to Visconti For This Useful Post:
Nightbringer (07-14-2013)
Old 07-14-2013, 09:09 PM   #146
Nightbringer
Drives: Scion FR-S
I thought Toma stated somewhere that they had flat-foot shifting and launch control at least, though it may go about it in a different way. Would like to get a response on the brzedit featureset as well. Someone needs to make a side by side comparison spreadsheet of these options, sticky the damn thing, and put this argument to rest. BRZEdit vs EcuTEK vs Unichip vs ... that BMW guy's opentablet?
Old 07-14-2013, 10:02 PM   #147
jordBLP1
Drives: Stock white BRZ
So what about data logging? For example if I were to order a turbo kit with a 91 octane map with ecutek, then I want to up the boost and add some ms109.. but I'm no where near a shop with a dyno.. could I do a street tune with data logs? I'm leaning towards brzedit because it seems a little more open in that sense. I'm just speculating though as I literally have no experience with tuning
jordBLP1 is offline   Reply With Quote
Old 07-14-2013, 10:04 PM   #148
Visconti
Drives: 05 STi
If you want to tune yourself you'll need unichip or brzedit..
Ecutek is for pro tuners
John
Old 07-14-2013, 10:17 PM   #149
swift996
swift996's Avatar
Turns out it was a bad cable or should I say I used a friend's cable and it worked. Not 100% sure it was the cable but hopefully a new one will eliminate the issues I've had.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-14-2013, 10:19 PM   #150
swift996
swift996's Avatar
Condolences man. Hope they get to the bottom of it shortly! When did you first report the problem? I'm just curious on response timeframes to a critical issue.
The different cable worked. Mike at Moto-East was super helpful on a Sunday but just a risk you take. I don't expect a tuner to be available 24x7 but if you expect your car to be, just know that if something goes wrong, you might be without a car. I think the issue was the cable, for $350, you would expect better out of a cable (if that was truly the issue).
Old 07-14-2013, 10:38 PM   #151
Tromatic
Originally Posted by Rich@ViscontiTuning View Post
We see this problem when there isn't a consistent internet connection and the tune fails to apply. What's going on is EcuTek's software requires validating the license with their servers during every flash. We realize how inconvenient that can be when you're on the road without reception or internet and we've been working with them on a solution. It really is a pretty isolated incident though.
CORRECTION: when the flashing process fails, you lose the license which then has to be re-issued. That's the part that requires the internet connection. You can flash without active internet connection. I apologize for the error. ProECU update tomorrow should be rectifying this issue.
That right there is a deal-breaker if it's not fixed.
Old 07-14-2013, 10:41 PM   #152
Visconti
Drives: 05 STi
Read above.. Fixed in tomorrow's software update..I've been testing it out for the past few weeks.. Works great
Old 07-14-2013, 10:44 PM   #153
jordBLP1
John
I should have been more clear.. my fault. What I meant was could I send those logs to an ecutek tuner to tweak while I do the driving? My problem is that I'm not close to any ecutek master tuners.. or any dyno facility at all for that matter, its a PITA
Old 07-14-2013, 10:46 PM   #154
Visconti
Drives: 05 STi
Yeah, people do that all the time.
If you want multiple revision in a short period of time I suggest you setup something with your tuner ahead of time..
John
Ecutek's 86 jpit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 07-12-2013 12:35 PM
Will the new Subaru WRX kill resale value of the 3rd gen WRX's? CSI:86 Other Vehicles & General Automotive Discussions 20 06-05-2013 09:31 PM
resale value kbb available Celica00 Scion FR-S / Toyota 86 GT86 General Forum 16 05-24-2013 12:03 PM
resale value jmaryt Scion FR-S / Toyota 86 GT86 General Forum 28 10-08-2012 09:58 PM
ECUTEK????? 20valvewynn83 Engine, Exhaust, Transmission 4 10-03-2012 09:34 PM
