Old 12-23-2011, 05:28 PM   #99
aesthetect
form follows function
aesthetect's Avatar
Drives: 240Z, E90 M3, tacorunner
Originally Posted by syldrin View Post
stock 17x7's are probably heavier than a good set of 17x9's say an enkie RPF1
rpf1s are exceptionally light, ESPECIALLY for the money. you can bet those oem 17x7s (with the lengths theyve been to to reduce weight on this thing, id be surprised if they were more than 16lbs) are lighter than most of the sub $1500 aftermarket, and for sure any rota, which seems to be about 80% of the wheel market these days.
Originally Posted by Longhorn248 View Post
You're welcome for being one of the insane ones. If it wasn't for people like me that are going to buy the first gen and work out the kinks you'd never buy one
yup, thank god for you early adopters for letting teh rest of us sit back and wait for prices to drop :happy0180:
Originally Posted by Buggy51 View Post
A quick question to those with a better history than I do, but what first generation car from Toyota/Scion and Subaru have had problems? I'm not talking about drastic changes in performance the following year, but overall quirks.
what causes problems in first gens is new technologies being introduced, such as the high pressure fuel pumps used in the bmw N54, limping all sorts of X35s. both subaru and toyota have a good record in this respect, but i also havent seen a lot of vastly different technologies introduced, besides cam phasing, which afaik went well for both. the only thing i look at is the parallel fuel injection system, and that mostly cause i come from the subaru camp so dont really know toyotas history with it, ie how different this is from previous versions (has toyota released cars with BOTH direct injection and port injection? SEE EDIT BELOW). subaru purportedly did the majority of the engine development, but im sure in this respect got all the help they asked for from toyota. however, i could see this being a problem in the STi version, depending on how aggressive they get, as i am beginning to think after release of these base models the collaboration between teh OEMs will dwindle.
EDIT finally some of my poking around paid off on the matter and found history on this D4-S system
Originally Posted by http://en.wikipedia.org/wiki/Toyota_GR_engine
The 2GR-FSE is a 3.5L engine used in the Lexus IS, and GS 350, incorporate Toyota's latest D4-S twin injection fuel system. This system combines direct injection with traditional port injection. Using direct injection and port injection simultaneously facilitates more precise mixing of air and fuel under low and medium load conditions for greater efficiency, while high load conditions dictate the use of direct injection alone for maximum power. The 2GR-FSE engine is rated at 309 PS (227 kW; 305 hp) at 6,400 RPM and 38.4 kg·m (377 N·m; 278 ft·lbf) at 4,800 RPM. The engine's service weight is 174 kg.
The 2GR-FSE was on the Ward's 10 Best Engines list for 2006, 2007, 2008 and 2009.
id say that last bit is a pretty strong indication of a good, solid system
that would eliminate any fears i would have regarding early adoption, although this engine will be mixing subaru's AVCS with the D4-S, which is a first (wonder why AVCS over VVTi?). but still, that seems to suggest most potential problems would be integration/control/ecu related. but personally ill wait to see what the STi/TRD look like as im nominally cross shopping with cayman, lotus; but would definitely prefer to see some NA performance versions, even at the expense of peak power.
aesthetect is offline   Reply With Quote
Old 12-27-2011, 11:49 PM   #100
old blue
Drives: cayman
I had one of the first STI's off the boat. 90000 miles and absolutely no driveline problems.
Ditto for one of the first Preludes, and for one of the first Ducati 916's, one of the first Yamaha R1's; Cayman was bought used, though, but had no problems.
I wonder how many of the people saying no will ever buy a new one, period.
old blue is offline   Reply With Quote
Old 12-28-2011, 12:05 AM   #101
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
Originally Posted by WingsofWar View Post
Its fun just kickin it with friends while we work on cars (with beers and BBQ of course), i know im responsible for getting some friends to go to UTI because i rubbed off on them. Lots of them are better than i am at this sort of stuff now and its me that asks for their help once in a while.
I called UTI and asked if they had any racing programs outside of Nascar... their rep didn't even know what Le Mans was. That's when I hung up
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 12-28-2011, 12:26 AM   #102
dwcnmv
Drives: 2013 Limited WR Blue BRZ
You live my ideal life.
dwcnmv is offline   Reply With Quote
Old 12-28-2011, 01:19 AM   #103
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
UTI is a very american school, and people who get into the manufacturer programs do very well and get paid nicely. But the racing programs..NASCAR NASCAR NASCAR..and possibly Indy cars. Anything else is an entirely different dimension to them.
WingsofWar is offline   Reply With Quote
Old 12-28-2011, 09:55 PM   #104
Max Schnell
Drives: Lexus GS350 F-sport
Manufacturers tend to do slight adjustments to improve the breed within a short few years from the first model year of a completely new model. The more problems the quicker the adjustments it seems. First new models of a completely new car tend to see adjustments the fastest from my observation.
I doubt we will see huge changes in this car within 3 years but what I know for sure is the the first year guys will be stuck with whatever the manufacturer got wrong the first time around. (this is my main reason to not buy a first year of a completely new model)
Happends with any manufacturer not just Toyota or Subaru. Also, in order to keep the buyers interested most manufacturers do some type of small upgrades over the span of the life cycle to make the cars more appealing (and jacking up the price). Whether it is better trim, more power, or cosmetics.
Max Schnell is offline   Reply With Quote
Old 12-29-2011, 04:37 AM   #105
Stigmaru
Stigmaru's Avatar
Drives: 2022 Halo White GR86
Originally Posted by RYU View Post
Depends if you're willing to pay extra for the STi. The reason I like this car so much is partly because of what you get for under $25k (I hope!). I'm not sure if at $30k+ i'd be willing to pay for a FI version.
It's also tough to say if a FI version will be out for this at all. Autoblog said when this motor was designed it resulted in simply no room for a turbo where traditional boxer turbos were placed. It's also a new motor with 12.5:1 compression. That is not FI friendly at all. They'd likely have to drop the compression and package it with a weirdly mounted turbo. That's basically a significant redesign.
Another option is to go SC. TRD has a strong history of using Magnuson for thier SC (I have one in my Tacoma). Packaging wise, that seems more logical but they still have to deal with the high compression issue. That won't be so easy for the dealer to handle since all TRD SC units I know of are dealer installed not factory installed.
I think FI isn't until way way way down the line.. maybe after 4th yr at least and will require engine internals to be changed.
I read something entirely different. Wasn't there a thread before saying that it was odd in terms of engine layout that there was ample room left for what appears to be an intercooler?
Stigmaru is offline   Reply With Quote
Old 12-29-2011, 05:35 AM   #106
Longhorn248
Hook 'em
Longhorn248's Avatar
I thought UTI was something they taught kids in medical school...
Longhorn248 is offline   Reply With Quote
New Car Buying 101 Guff Other Vehicles & General Automotive Discussions 6 03-23-2012 07:06 AM
Why I am buying a BRZ BMWDAD BRZ First-Gen (2012+) — General Topics 37 01-01-2012 10:01 PM
What do you look for when buying a sports car? Diar Other Vehicles & General Automotive Discussions 43 09-28-2010 09:50 AM
I'm kind of afraid... VenomRush Scion FR-S / Toyota 86 GT86 General Forum 106 09-14-2010 02:53 AM
I'm afraid the FT86 might be too inexpensive. BRZrkr Scion FR-S / Toyota 86 GT86 General Forum 30 02-24-2010 03:45 PM
