#29 | |
Drives: Attitude
#30 |
Drives: 5th Gen Toyota 4Runner
I need to pay attention more when driving. I do have the metallic clunk but thought it was normal. Hmmmmm...
| The Following User Says Thank You to Overland'n'5thGEN For This Useful Post: | Kelbyat07 (06-25-2013) |
#31 | |
Drives: '22 BRZ
#32 |
Drives: Scion FR-S (Asphalt)
i took it to the dealership once already, but they just told me that they were unable to replicate the issue and asked if i would take their tech for a ride along. He had already gone home though, so i need to make an apt. to go back. problem is that he has the same work hours that i do
However, since then i have installed the perrin rear-shift bushing and the whiteline positive shift kit. The problem has certainly improved. It doesn't happen EVERY time now, just occasionally. But when it does happen, it is a pretty severe crunch and has even refused to go into 5th. Luckily i keep the clutch in and re-tried from 4th-->5th. hopefully some better transmission oil will help some more. on a side note: The only negatives i have with the shifter bushing/positive shift kit are that my trans in now pretty noisy when creeping along, such as in a parking lot. Also have a bit of a gear whine noise accelerating through lower RPMs. As to be expected though. And Unfortunately, i put them both in at the same time, so i couldn't tell you how they affect the car separately. |
#33 |
Drives: Frs
Same here. 5th gear always grind. When your driving highway speed on 6th gear, pop it to neautral and waite until rpm drops and try to put in 5th gear. It will grind 100% of the time. I dont know if this is normal.
#34 |
Drives: N/A
I just got my car back from the dealership and they said they couldn't replicate the issue. However, magically, shifting is now smooth as butter. Not sure what they did but on the downside I now have crickets. Didn't have that before taking it to dealer. So one problem seemingly solved only to gain another. *sigh*. F it. I'm just drive this thing and try not to care.
#35 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Seems likke a lot of people have the same 5th gear problem; is this a normal or something we should all be worried about.. ?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#36 |
Drives: 2013 6spd manual Scion FRS
I'm dropping mine off tomorrow night i get a syncro grind/crunch going from 3-4 WoT under heavy load 5500 rpm and up everytime. I'll let you know what the they tell me hopefull on wednesday
#37 | ||
ビーアールゼット
Drives: WRB BRZ '18
I'm sure your problem is real, because you're not the only one having the exact same issue. I am, and so are other folks on this forum. I say you try a different dealer...don't live with a crunchy tranny. Quote:
I've just been super reluctant to take mine in. I don't doubt they'll fix it (I actually work at a sister dealership to Toyota), but it's nice to have the reassurance, so post your experience |
#38 |
Drives: 2015 Scion FRS-One
I'm dissapointed with all the factory defect problems with the BRZ. Glad I have the automatic transmission for now at least ;/
#39 |
I call the dealership and they say they could not duplicate the concern, then they say the conditions were hard to meet without speeding. so did they not duplicate it or not actually try to duplicate it? The dealership is not even 5 minutes from a highway. Being a tech I don't understand how hard it is to duplicate a concern that is described as much as I described it. they didn't perform the LOF i asked for because they said it was too early... I told them that's why I asked for it and said I would pay. So the only thing they did was order a fuel filter for my crickets. So now I have another appointment at another dealership. I hope I get a survey for the first dealer so I can destroy their CSI
#40 |
Site Moderator
Drives: Stuff
Nice. my clutch has been making noise for a long time now and the trans also likes to grind at times (and yes I do know how to drive a manual, clutch will be all the way in and not trying to speed shift). It's done that since new more or less. :shrug: I'll just deal with all of these things at 30k.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#41 | |
Drives: 2014 SWP BRZ Limited
It's one of the reasons I got rid of the car. I probably should have went through the lemon process just to be vindictive. |
| Replacing badges | Pneub | BRZ First-Gen (2012+) — General Topics | 1 | 05-30-2013 03:52 PM |
| anyone have DIY for replacing OEM HU?? | mbh1101 | DIY (Do-It-Yourself) Guides | 2 | 01-27-2013 01:18 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 08:54 PM |
| Toyota FT-86 transmission is this it? | 4agze | Engine, Exhaust, Transmission | 65 | 03-24-2011 09:08 PM |
