Old 06-03-2013, 08:44 PM   #211
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by ethanzhang View Post
Hi there. I just got new street flex coilover on my Brz. I just wanna ask what is the best height for this coilover?
-32mm front
-33mm rear
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 06-06-2013, 01:35 PM   #212
peachch
Drives: White 86 Sport Plus
Anyone know H&R sport spring rate??
peachch is offline   Reply With Quote
Old 06-22-2013, 03:02 PM   #213
SWAMechFRS
SWAMechFRS's Avatar
Drives: 2013 Scion FR-S Asphalt 6-Spd
Swift Sport Mach FR-S springs. 1" drop.
(upper pic is after install and lower pic is before)
Sent from my iPad using Tapatalk HD
Don't Text and Drive
KCCO:happy0180:
SWAMechFRS is offline   Reply With Quote
The Following User Says Thank You to SWAMechFRS For This Useful Post:
WingsofWar (06-26-2013)
Old 06-22-2013, 05:25 PM   #214
ill86
ill86's Avatar
Drives: iG FR-S
They don't seem to list spec.
For more information, visit www.hrsprings.com and www.trakplus.com or call (888) 827-8881.
Old 06-28-2013, 09:43 AM   #215
MountainManFR-S
MountainManFR-S's Avatar
BC Racing coilovers
MountainManFR-S is offline   Reply With Quote
Old 07-04-2013, 04:23 PM   #216
Cesium Rainbow
Cesium Rainbow's Avatar
Drives: '13 dgm brz
Why do some springs (Tanabe, H&R) have a bigger drop in the rear while others (Tein, Prova) lower the front more? Is it a function vs. looks thing? The only reason I can imagine why you'd want a lower rear end is to move weight bias back (but I don't imagine a couple mm's would make much difference). Visually the front needs a bigger drop to keep the wheel gap consistent front to back.
And the spring rates are confusing too. Some of the lowering springs barely increase front rate at all, while many of the coilover come with the same rates front/back or stiffer fronts. Why the different approach?
I don't even think I've ever seen an FR with stiffer springs in the back. Can't argue with the result handling-wise but it's too bad there's not more choices offered by the aftermarket (I see you RCE , just surprised you're the only ones). But then if you wanna get all anal about rates, I spoze that's what coilovers are for.
Thx Darren and WingsOfWar for the informative and easily digestible info. One of the better enthusiast forums I've visited.
Cesium Rainbow is offline   Reply With Quote
The Following User Says Thank You to Cesium Rainbow For This Useful Post:
Racecomp Engineering (07-04-2013)
Old 07-13-2013, 11:17 PM   #217
melon
melon's Avatar
Drives: Toyota 86
Hope someone would update the list of new coilovers and spring rates at the 1st page.
melon is offline   Reply With Quote
Old 07-14-2013, 07:12 AM   #218
wes1202
Drives: 86
Originally Posted by MountainManFR-S View Post
BC Racing coilovers
how is the ride of the bc br coilovers ? is the height you have here in the pic the pre set or was it adjusted ?
wes1202 is offline   Reply With Quote
Old 07-14-2013, 02:56 PM   #219
MountainManFR-S
I have my ride set on a 7 stiffness level all the way around and its more stiff that stock but not bad at all for daily driving. The height in this picture is adjusted. Out of the box the BCs I had would have dumped the car.
Old 07-14-2013, 09:12 PM   #220
wes1202
Drives: 86
thanks
Old 07-15-2013, 06:55 PM   #221
Esoteric
Esoteric's Avatar
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
Originally Posted by clayrush View Post
I am having a hard time figuring out what springs or coils to get for my girls FRS.
Cost and compromise is the name of the game...
On the affordable side that still very comfortable, I recommend the Hotchkis springs with Koni shocks, or even the Sportlines. The new ST suspension coilovers look like they may be perfect for her needs.
Pair either of these with camber/caster adding upper shock mounts and your will have a very comfortable car, great performance and no more cost than most entry level coils!
If you want a bit more adjustability, then I have 3 very happy customers with Ground Control kits. They are very nice.
I also like the FEAL kit (BIG review coming soon), but they are for someone who sounds more focused on track days than your GF.
Best
Esoteric is offline   Reply With Quote
The Following User Says Thank You to Esoteric For This Useful Post:
clayrush (07-16-2013)
Old 08-07-2013, 07:20 PM   #222
DougW
Drives: FR-S stock for now
Just let everybody know I have been testing the Bilstein Damptronic package on my FRS. I make a control box for the Porsches and GTRs that we adapted to the FRS, it uses the CAN for G, steering ,tps and braking to control the shocks. It rides soft but firms up based on mapping, pretty cool.
DougW
DougW is offline   Reply With Quote
The Following User Says Thank You to DougW For This Useful Post:
DAEMANO (01-13-2014)
Old 08-21-2013, 02:29 PM   #223
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Why is it that all the springs with minor drops are TBA? I don't want to go very low and right now the lease I can find is the RCE Yellows with their .8" but I think I'd prefer a .5" instead.
Nevermore is offline   Reply With Quote
Old 08-21-2013, 03:05 PM   #224
Cesium Rainbow
Drives: '13 dgm brz
TRD & STI? Plus you get to keep your warranty.
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 04:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 11:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 09:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 02:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 01:52 PM
