Old 06-18-2013, 02:19 PM   #15
waterbison777
EDIT**
Originally Posted by radroach View Post
Should I have the syncro rings checked before 30,000 miles?
No need. You'll know if they're dying.
Are the syncro rings replaceable instead of the whole transmission?
Yes, but toyota opted to just replace the entire tranny and send the defective one back to HQ so they could take a look at the entire unit
waterbison777 is offline   Reply With Quote
Old 06-18-2013, 03:23 PM   #16
SoCal_86
テック
SoCal_86's Avatar
Drives: 85 Toyota Corolla GTS 13 Scion FRS
Originally Posted by waterbison777 View Post
I had my transmission replaced by longo toyota a few months ago as well. It was the same issue as the OP; metallic crunching sounds shifting into 4th from either 3rd or 5th gear. The crunching was definitely more prevalent when shifting above 6k rpm, but you could feel it at lower rpms as well. They said that my transmission had a deformed synchro ring and replaced the entire tranny free of charge.
I purchased my FRS at longo, should I contact the sales rep who helped me purchase the car or should I be speaking with a different department? @waterbison777
SoCal_86 is offline   Reply With Quote
Old 06-18-2013, 03:30 PM   #17
Yruyur
Yruyur's Avatar
Service. Sales is just there to make money for the dealership.
The Following User Says Thank You to Yruyur For This Useful Post:
strat61caster (06-18-2013)
Old 06-18-2013, 04:07 PM   #18
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
If you contact a sales rep he'll just transfer you to the service department anyway, save yourself the 1 minute conversation.
ineedyourdiddly
Old 06-18-2013, 06:03 PM   #19
waterbison777
Old 06-18-2013, 09:19 PM   #20
SoCal_86
テック
SoCal_86's Avatar
^what they all said
Thanks!!
Old 06-20-2013, 04:13 PM   #21
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
When did you buy your FRS? I have an occasional grind in some gears but almost always have a little bit of grind going into 5th at freeway speeds (downshifting and upshifting). Not sure if it's the same issue but it is worriesome
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 06-23-2013, 01:12 PM   #22
swFt86
swFt86's Avatar
Drives: N/A
I'm also having this issue. A noticeable amount of resistance shifting from 1st to 2nd. However, no weird sounds or resistance on any other gears. Not sure what the deal is...
swFt86 is offline   Reply With Quote
Old 06-23-2013, 10:54 PM   #23
whtchocla7e
Drives: 2013 FR-S Hot Lava
1st to 2nd is pretty normal. I don't recall anyone not having this issue at one point or another?
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 06-24-2013, 02:01 AM   #24
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
I'm having this and I'm really annoyed with it considering I took it in the other day and they didn't do anything about it.
husker741 is offline   Reply With Quote
Old 06-24-2013, 08:11 AM   #25
d1ck
Drives: Black 2013 FRS
If I shift from 3rd to 4th very quickly at high RPM I can sometimes feel and hear a slight grind. I hope it's not the start of a bad syncro...
d1ck is offline   Reply With Quote
Old 06-24-2013, 01:47 PM   #26
swFt86
swFt86's Avatar
Drives: N/A
What did your dealership say? I'm taking mine in on Wednesday. I hope it's not a waste of time.
Old 06-24-2013, 06:47 PM   #27
husker741
That it is fine. It's not fine. Something I want to know is how many people with this issue followed the break in procedure.
Old 06-24-2013, 08:04 PM   #28
Gixxer86
Drives: Scion FR-S (Asphalt)
same issue, but mostly with 5th gear. With both down-shifting to slow down or to accelerate harder, if i don't make sure that i shove it into 5th gear, than there is a pretty bad grind. Even with the shove, it still does make an unpleasant sound, as well as feeling it through the shifter. This is with rev matching of course.
Gixxer86 is offline   Reply With Quote
Replacing badges Pneub BRZ First-Gen (2012+) — General Topics 1 05-30-2013 03:52 PM
anyone have DIY for replacing OEM HU?? mbh1101 DIY (Do-It-Yourself) Guides 2 01-27-2013 01:18 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
Toyota FT-86 transmission is this it? 4agze Engine, Exhaust, Transmission 65 03-24-2011 09:08 PM
