86 = First New Car
Drives: 2013 Pegasus White Toyota 86 GTS MT
March 2013 Build Check Engine Light
I have a March 2013 build 86 that has 6000 kms on it. And i just got my first check engine light in traffic on a downhill slope. I let go of the clutch, just before it go to the engagement point, the car shakes and almost stalls and the check engine light goes on. The car still runs fine and there is no power loss.
My partner has a April 2012 build 86 and it has 18500kms. Her car very occasionally has the rpm dip when idling, other than that has had no check engine light so far. *knock on wood* I plan to take it to the dealer to see what the problem could be but im also concerned that the dealer may void my warranty and not fix the problem because i have a intake and header on mine. Plus it is strange that a 2nd year model still has the check engine light that is common in the 1st years. EDIT: The check engine light has gone. And there seems to be more power WTF Last edited by CSI:86; 06-21-2013 at 05:10 AM. |
#3 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Maybe borrow an OBDII (or buy for 10-15) and see what codes it is throwing out before going to the dealer. If the code has nothing to do with headers or intake might be OK to take it to the dealer but they might give you trouble still.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#4 |
86 = First New Car
#5 |
Drives: Raven Manual FRS
#6 |
86 = First New Car
#7 | |
Drives: 2018 STI
Went inside the service area to set up an appointment and when I started it up to leave, the CEL was gone. Took it out on the highway to make sure it felt fine and my butt dyno definitely says it had more power and ran smoother than it's ever run. Really weird. Only mods I have are perrin catback, drop in filter, and inlet hose and they've all been installed for 5k+ miles. Manufacture date of 11/12, 6056XX VIN number. |
#8 | |
86 = First New Car
Sent from my GT-I9505 using Tapatalk 4 Beta |
#9 |
Drives: White FRS
remember that if you have an aftermarket intake it could cause the MAF to read incorrectly and cause engine issues. what intake do you have?
#10 |
86 = First New Car
| Check engine light just came on after 2k miles. | danthedirt | Issues | Warranty | Recalls / TSB | 604 | 01-31-2015 05:26 PM |
| Check engine light. Help!!!!! | sf86 | Issues | Warranty | Recalls / TSB | 2 | 06-05-2013 04:51 AM |
| Check engine light? | czar07 | AUSTRALIA | 0 | 09-01-2012 03:50 AM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 07:50 AM |
| Check Engine Light | b.e | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 06-17-2012 10:50 PM |
