Old 06-23-2013, 03:59 AM   #15
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Great install. Got one going on our silver car.
FT-86 SpeedFactory is offline   Reply With Quote
Old 07-23-2013, 04:35 AM   #16
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Fantastic write up as always Victor. Hmmmm maybe I should have tried this myself..
stevo_12v is offline   Reply With Quote
Old 07-23-2013, 05:42 AM   #17
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Great article! I assume the total portrayed by the scale includes the wooden plank so the weight difference between the two is not quite as great?
Mim is offline   Reply With Quote
Old 07-23-2013, 06:19 AM   #18
stevo_12v
Metric Units here..
I think Victor is a pretty cluey guy and would have "TARE'd" off the plank in that measurement
Also the weight difference between the two is around half(as stated)
I just calculated it(I'm working out my own personal weight loss regime for my car atm - I'm bored):
STOCK: 11.181035kg
CF DSS: 5.599032kg
The Following User Says Thank You to stevo_12v For This Useful Post:
Mim (07-24-2013)
Old 07-24-2013, 08:50 PM   #19
Mim
Mim's Avatar
This is certainly one of the mods I'm looking forward to myself, once I finally get my own 86. I like the idea of reducing drive train power loss and improving the underlying performance prior to upgrading power.
Lighter 17x8 rims, brace kit, cf drive shaft, lighter pulley kit and diff ratio are the first mods I'd likely make.
Old 08-02-2013, 01:50 PM   #20
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Just wanted to say thanks to Victor for stopping by the shop and taking some pictures. I think we were each able to knock out the work that needed to get done to our vehicles.
PhastekSport is offline   Reply With Quote
Old 09-20-2013, 05:30 AM   #21
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Now you've had this for awhile can you comment on thoughts of performance and NVH and so on please? Very curious to hear as I am doing mine soon as well. I know some fellows with the aluminum ones have commented on increased NVH or vibrations and having to turn 90-180 degrees on back plate to rid of and wondering if there are any concerns on the CF version?
The Following User Says Thank You to OICU812 For This Useful Post:
pjpetrozelli (12-25-2013)
Old 09-20-2013, 07:43 AM   #22
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
How much fluid will leak from an Automatic Transmission during this conversion?
How do you refill?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-20-2013, 11:35 AM   #23
PhastekSport
How do you refill?
I have no reason to believe that if you vehicle was level more fluid would come out of an automatic. We didn't lose any with this vehicle.
I haven't noticed an increase in vibration. Must note that he car is overwhelmingly loud (Borla UEL and Perrin unresonated / uncatted the rest of the way), and that could have taken away from my ability to notice a change with the driveshaft. Come to think of it, the vehicle had a stock header when it was installed. Didn't notice much of a difference as far as NVH.
STOCK: 11.181035kg
CF DSS: 5.599032kg
We definitely zeroed out the scale with the plank on there.
Old 09-20-2013, 03:40 PM   #24
CajunFRS
Drives: Challenger R/T, CRX SI,
A few in car videos of the l aluminum DS noise would be awesome. On a car without headers and has at least one cat. :P
CajunFRS is offline   Reply With Quote
Old 09-20-2013, 08:11 PM   #25
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Originally Posted by F1point4 View Post
Unlike the OEM one, this carbon fibre driveshaft doesn't have a shaft collar. Normally having a collar is good in the event that your driveshaft falls out of the gearbox and catapults your car in the air.
Just so you know, Mythbusters totally busted that myth.
neurokinetik is offline   Reply With Quote
Old 09-24-2013, 01:26 PM   #26
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Having your shaft snap is still not a pleasant feeling nor a great experience and that comes from a person who had this happen to him on a 4x4
Old 09-27-2013, 06:34 PM   #27
SurfAndSand
8SiX
Drives: FRS 10series
Does that collar (or whatever that piece is that bolts in the middle of transmission tunnel) offer any structural advantage to the chassis? Should you reinstall something to bridge that gap, that was once bolted together with the stock drive shaft?
SurfAndSand is offline   Reply With Quote
Old 09-27-2013, 06:53 PM   #28
PhastekSport
I don't see why it couldn't hurt to add a brace. Just have to get one made. I don't notice any negative side effects at the moment.
diy, driveshaft, driveshaft shop, dss
Driveshaft Shop Carbon Fiber Shafts Explained Driveshaft Shop Engine, Exhaust, Transmission 121 11-17-2017 12:57 PM
Driveshaft Shop Axles & Upgrades for Scion FR-S!! MVP Motorsports RobertatMVP Transmission and Driveline 39 07-11-2014 02:48 PM
Driveshaft on a DD FRS Bullnettles Engine, Exhaust, Transmission 31 10-06-2013 02:22 PM
The Driveshaft Shop Custom Axles and Shafts Sportsguy83 Engine, Exhaust, Transmission 26 01-11-2013 05:55 PM
Automatic Carbon Fiber Driveshaft? Yes! RallySport Direct Engine, Exhaust, Transmission 13 12-15-2012 01:40 AM
