Old 06-20-2013, 03:27 PM   #113
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
^this. Aftermark top hats make noise. These whiteline ones. If they only make noise when leaving the house then fine I can live with that.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-20-2013, 03:58 PM   #114
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
You said you wanted adjustment. The Com-C is NOT adjustable, it is shaped such that it locates the strut differently, adding both camber and caster in a STATIC (unchangeable) manner. Furthermore, the solid-mounted nature of camber plates means that they will make more noise as they are metal-metal instead of using rubber to isolate suspension noise/harshness.
If you get proper (non-stack-height altering) camber plates, you will not LOSE suspension travel. You can also cut your bumpstops if you're still using the stock ones. TIC (Turn In Concepts) sells the camber plates you're looking for if you want to NOT lose travel AND adjust camber/caster. @Racecomp Engineering also sells some, but they've been out of stock forever I hear; perhaps Andrew or Myles could better explain what I'm saying.
EDIT: http://www.ft86club.com/forums/showthread.php?t=29567
Ok, good info! Thanks! I don't give a shit about noise. It's my DD but it's also my racecar. As soon as it's paid off it'll get a nice German sedan parked next to it. For now I suffer.
Old 06-22-2013, 01:50 AM   #115
autobrz
Drives: Mazda 3
Can anyone confirm they have the new batch of the com c and they no longer have the bearing seizing when turning the wheel,or if they still ran into the problem?
autobrz is offline   Reply With Quote
The Following User Says Thank You to autobrz For This Useful Post:
Calum (06-22-2013)
Old 06-22-2013, 02:09 AM   #116
cnk
Drives: '13 DGM BRZ Limited
I have the new Comp-C's and the only noise I get is a pop when first backing out of my driveway for the day. After that, they are quiet. No idea why they pop, but as long as that's the only noise, I'm fine with it.
The Following User Says Thank You to cnk For This Useful Post:
autobrz (06-23-2013)
Old 06-22-2013, 06:41 AM   #117
Calum
That Guy
Drives: 2013 asphalt FRS MT
They pop because the bearing is seized. The sound is the spring unwinding after the bearing lets go. Mine did the same for a few days, just when I did the first turn of the trip. After a while though it was every time I turned the wheel more then about 30 degrees.
The Following User Says Thank You to Calum For This Useful Post:
Old 06-22-2013, 11:35 AM   #118
Calum
That Guy
I'm really curious about this to. It's such a great product idea, if only they could get a decent bearing in there.
Old 06-22-2013, 11:57 AM   #119
cnk
Oh well, if it does get worse I guess I'll give them one more try with a warranty replacement or just swap them out for Group-N mounts and be done with it.
Sent from my Transformer using Tapatalk 4 Beta
Calum (06-22-2013)
Old 06-22-2013, 06:50 PM   #120
feldy
feldy's Avatar
Do you know how long it took for these to get worse? I mean from popping in the morning to all the time?
Old 06-22-2013, 07:20 PM   #121
Calum
That Guy
If memory serves me, it was about 500 kms and about 5 days.
Old 06-23-2013, 02:47 AM   #122
makinen
makinen's Avatar
Drives: Toyota 86
As I recall @ATL BRZ 's post in his build thread, the alignment is critical in the installing process.
Originally Posted by ATL BRZ View Post
No, I asked Whiteline's US contact and they said no conical washer is required. However I would recommend using spring compressors even if you have lowering springs to install the top mounts. It's critical that you get the upper spring perch aligned correctly below where the threads on the strut shaft start before you thread the nut on with a pass-thru socket and long allen socket to hold the shaft still.
Also, I do not recommend using camber bolts with the Com-C's. I didn't like the strut geometry they were creating with the new top mounts when pushing the rotors up to get the camber from the bolts. It just didn't look or feel right, so I put the stock fat upper strut mounting bolt back in and it looked right with plenty of negative camber.
makinen is offline   Reply With Quote
The Following 2 Users Say Thank You to makinen For This Useful Post:
ATL BRZ (06-23-2013), autobrz (06-23-2013)
Old 06-28-2013, 01:59 PM   #123
feldy
feldy's Avatar
I'm not using whiteline camber bolts anymore but I am using the Subaru crash bolts. -2.5 degrees of camber up front. I have a few thousand miles on them now and the clunking on this second set is getting worse. I made the mistake of driving on some gravel roads yesterday. It just made it worse now I get clunking on every left turn I make regardless of how much the wheel is turned.
Is anyone clunk free?
Old 06-28-2013, 02:58 PM   #124
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
I'm a little over a week into my second set, but I used the stock bolts on setup - around -1.2 degree's up front and so far no noise.
mikalem is offline   Reply With Quote
The Following User Says Thank You to mikalem For This Useful Post:
Calum (06-28-2013)
Old 06-28-2013, 03:02 PM   #125
feldy
feldy's Avatar
Cool keep me posted also are you on stock shocks or koni yellows?
Old 06-28-2013, 03:32 PM   #126
mikalem
mikalem's Avatar
Stock, with rce yellows
Sent from my SGH-M919 using Tapatalk 2
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-12-2013 12:31 AM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 09:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 11:48 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 07:43 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 08:07 PM
