Old 06-19-2013, 11:40 AM   #1
CSI:86
86 = First New Car
Drives: 2013 Pegasus White Toyota 86 GTS MT
March 2013 Build Check Engine Light
I have a March 2013 build 86 that has 6000 kms on it. And i just got my first check engine light in traffic on a downhill slope. I let go of the clutch, just before it go to the engagement point, the car shakes and almost stalls and the check engine light goes on. The car still runs fine and there is no power loss.
My partner has a April 2012 build 86 and it has 18500kms. Her car very occasionally has the rpm dip when idling, other than that has had no check engine light so far. *knock on wood*
I plan to take it to the dealer to see what the problem could be but im also concerned that the dealer may void my warranty and not fix the problem because i have a intake and header on mine. Plus it is strange that a 2nd year model still has the check engine light that is common in the 1st years.
EDIT: The check engine light has gone. And there seems to be more power WTF
CSI:86 is offline   Reply With Quote
Old 06-19-2013, 11:49 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i would put back to stock and visit dealer
Old 06-20-2013, 04:11 PM   #3
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Maybe borrow an OBDII (or buy for 10-15) and see what codes it is throwing out before going to the dealer. If the code has nothing to do with headers or intake might be OK to take it to the dealer but they might give you trouble still.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 06-21-2013, 05:10 AM   #4
CSI:86
86 = First New Car
Old 06-21-2013, 12:21 PM   #5
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
Running lean? That could cause the extra power, but not for long...
Freetime is offline   Reply With Quote
Old 06-21-2013, 01:25 PM   #6
CSI:86
86 = First New Car
What do you mean? How can it be running lean after the check engine light is gone?
Old 06-22-2013, 09:34 AM   #7
Blood
Drives: 2018 STI
This happened to me yesterday too. BRZ was idling somewhat rough and almost stalled once. A few minutes later I got a CEL + slip light. Slip light went off, but CEL stayed on. I was close to my dealer so I dropped by and had them look up the code. First time the OBDII said no code found, but the CEL was clearly still there. Restarted the car and it pulled p0011. The technician did not clear the code.
Went inside the service area to set up an appointment and when I started it up to leave, the CEL was gone. Took it out on the highway to make sure it felt fine and my butt dyno definitely says it had more power and ran smoother than it's ever run. Really weird.
Only mods I have are perrin catback, drop in filter, and inlet hose and they've all been installed for 5k+ miles. Manufacture date of 11/12, 6056XX VIN number.
Blood is offline   Reply With Quote
Old 06-23-2013, 03:18 AM   #8
CSI:86
86 = First New Car
Yeah its weird indeed... My guess is that the check engine light turning on and off is characteristic of it learning the driver's driving patterns and adjusts accordingly. Let me know if the CEL goes back on.
Sent from my GT-I9505 using Tapatalk 4 Beta
Old 06-23-2013, 03:51 AM   #9
jacobzking
Drives: White FRS
remember that if you have an aftermarket intake it could cause the MAF to read incorrectly and cause engine issues. what intake do you have?
jacobzking is offline   Reply With Quote
Old 06-23-2013, 05:18 AM   #10
CSI:86
86 = First New Car
It says in my signature. I have a Takeda AFE Dryflow intake. They are not known to cause any MAF issues.
Check engine light just came on after 2k miles. danthedirt Issues | Warranty | Recalls / TSB 604 01-31-2015 05:26 PM
Check engine light. Help!!!!! sf86 Issues | Warranty | Recalls / TSB 2 06-05-2013 04:51 AM
Check engine light? czar07 AUSTRALIA 0 09-01-2012 03:50 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 10:50 PM
