Old 06-20-2013, 04:42 PM   #169
jonghyun
Drives: '13 BRZ Ltd MT WRB
Originally Posted by RurumariGhost View Post
1. There are no "certain type" of leds, leds are leds, all that varies is the color and power draw (voltage/current)
2. I personally don't like t-taps, I will be doing this in a few weekends and will most likely strip the insulation off a wire, splice and solder my leads in that way, For my money its worth the time to do, better connection and no risk of corrosion.
3. Since I will be tapping directly into a wire there is no need for me to tap into the fuse box, the only difference is where you're drawing power from.
4. a fuse tap will tap plug onto the back of a fuse and draw power by making a connection that way.
okay you mentioned tapping directly into a wire. If i wanted to tap into the wiring that makes the interior lights come on when doors are opened, how do you know which wire to tap into?
jonghyun is offline   Reply With Quote
Old 06-20-2013, 04:47 PM   #170
RurumariGhost
Drives: Dark Grey Metallic 2013 BRZ
Two words: wiring diagrams, I haven't looked it up yet or I would tell you which one to tap into. I will probably tap into either the wire that controls dimming for the radio, or the lights for the Instrument cluster. More likely I'll tap into the IC lights.
RurumariGhost is offline   Reply With Quote
Old 06-20-2013, 06:54 PM   #171
Chaetagnath
Drives: Whiteout FRS
Originally Posted by Honeydew View Post
Hi im just wondering where that First picture is the wire with the pink green and black wire? And how do i get to it?
That's the harness that plugs into the dome light directly. It can be accessed by pulling the dome light down.
Chaetagnath is offline   Reply With Quote
The Following User Says Thank You to Chaetagnath For This Useful Post:
Minovsky (06-20-2013)
Old 06-20-2013, 06:55 PM   #172
Chaetagnath
@Chaetagnath, do you ever hit your switch with your knee while driving? It looks like you put it right where my knee tends to go while cruising on the highway
No, it doesn't seem to hit my knee at all. Of course, the switch can be put almost anywhere to fit your driving position.
Old 06-21-2013, 10:32 AM   #173
RurumariGhost
Cool, I'll probably end up doing a switch on the panel with the IC Dimmer and Fog switch. thanks for the good writeup
Old 06-21-2013, 12:30 PM   #174
jonghyun
Someone should do footwell lighting to match the shift lights. idea inspired by mightycarmods and their video [ame="http://www.youtube.com/watch?v=wL2CZ26ltlM"]How To Install A Shift Light - YouTube[/ame]
Old 07-09-2013, 03:45 PM   #175
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
does anyone have the oem kit installed? is it plug and play?
SuperDave is offline   Reply With Quote
Old 07-10-2013, 05:28 PM   #176
tobin
tobin's Avatar
Drives: '13 BRZ
I have the "Blue Interior Illumination" option on my 2013 Limited that I just picked up a week ago. I wasn't 100% sure what that meant when I bought the car, but the one I wanted already had it. It's kind of cool but I wish I could turn it off if I wanted to (like a button or something). Otherwise it's connected to the dimmer.
tobin is offline   Reply With Quote
Old 07-11-2013, 01:07 AM   #177
SuperDave
SuperDave's Avatar
could you be so kind as to take a couple of photos of it? where the wiring runs and if i understand what you're saying, it's gonna be always on with the ability to adjust its brightness with the dimmer?
Old 07-11-2013, 09:44 AM   #178
tobin
tobin's Avatar
Drives: '13 BRZ
Correct, they turn on as soon as you turn on parking lights or headlights, and they are connected to the dimmer for the instrument cluster. I will take some pictures next week at some point.
Old 07-15-2013, 09:51 AM   #179
tobin
tobin's Avatar
Drives: '13 BRZ
I apologize for the poor quality of these pics (iPhone 5), but these will give you an idea of what the "Blue Interior Illumination" option for the BRZ looks like. In my opinion, it's kind of tacky, and I will probably disable it at some point (or at least find a way to turn it WAY down).
Brightness all the way up...
Brightness all the way down...
Old 07-15-2013, 04:46 PM   #180
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
This is what i have done. Works with the dome light, and its bright enough to see whats on the floor but not too bright to over power the dome lights. I think red matches the red gauge cluster for the brz.
vignesh is offline   Reply With Quote
The Following User Says Thank You to vignesh For This Useful Post:
cebul (07-09-2016)
Old 07-19-2013, 12:27 AM   #181
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Originally Posted by koteman View Post
Fuse tap under dash in driver side for power to switch or leds. Ground is any chassis bolt. No splicing or cutting stock wiring this way.
Sent from my Galaxy S3
Hey im just wodering where you got a fuse tap and once you got it you just plug it in?
Minovsky is offline   Reply With Quote
Old 07-19-2013, 01:39 AM   #182
stockysnail
Just the tip
stockysnail's Avatar
Just remove the lighter adapter in the glove box and plug the LED strips into that with red ends that fit into the lighter plug female part after removal. That's what I did 6 months ago and still going strong.
Differences In Types of Headlights/Lighting Asphalt Cosmetic Modification (Interior/Exterior/Lighting) 7 02-21-2013 08:49 AM
HID_Powerhouse offers HID kits and LED lighting for your FR-S/BRZ KI_ZN6 CANADA 2 07-27-2012 06:13 PM
interior lighting? fistpoint Scion FR-S / Toyota 86 GT86 General Forum 2 05-09-2012 02:52 AM
Stupid girl 2 foot driving GenkiElite Off-Topic Lounge [WARNING: NO POLITICS] 31 07-23-2011 09:33 PM
How much do you like heel-toeing or left foot braking? USMCMike Other Vehicles & General Automotive Discussions 20 01-15-2010 05:20 PM
