#29 | |
The mk7 GTI w/PP in particular looks promising though. VW is saying all the right things: electronically-controlled LSD, lower height and CG than mk6, lighter weight than mk6, etc. But will it be enough to make it handle comparably to an FR-S? No idea. It's a tall order though, as the gap is quite large currently.
2022 BRZ Build 2013 FR-S Build |
#30 |
Drives: 2006 Cayman S, 2007 Outback 2.5i
#31 |
Drives: 2013 Scion FR-S AT Asphalt
At the last autocross event that I competed in, there was a bone stock Cayman S. I was only .6 seconds off his best run on stock tires. Neither of us are "newbies".
Interpret that however you like. ![]() Scott
#32 |
Drives: 2020 CTR
Agreed. Owning the Boxster Spyder and test driven the FR-S what I can say is that the FR-S feels similar but just not as good in every way.
From the driving feel perspective with all the weight in the middle on the boxster or cayman it just turns better. Just like rotating the dumbbell with 5lbs on the end is much harder than rotating without the weight on the end and placing the 10lbs on middle of the handle. I love the FRS and still considering buying one. The driving feel and fun factor is all there and I respect driving feel over anything else. That is the reason I still drive my Evo IX MR. Other than the Evo, Miata I don't know if anything else comes close in terms of driving feel other than moving up in $ to the Porsches or supercars. Yes limits are proportion to the cost but driving the FR-S give you the feel of a Porsche without the cost. A+. Love the car and still consider buying one. |
#33 | |
Drives: 2020 CTR
#34 |
Probably Watching F1
Drives: 10 Series FR-S 6MT
Some top gear should help.
#35 | |
If someone is looking for better grip, they need only switch the tires. |
#36 | |
Again, I'm not saying the BRZ is bad - it's an amazing car and I'm a huge fan (which is why I'm here, obviously), but the Cayman's handling is better in pretty much every way, at least subjectively (with one disappointing exception in my case - the older Caymans, mine included, suffer a bit for lack of a decent LSD, which can be problematic when trying to put down power out of a low speed corner. The newer ones with PTV have solved this problem though). |
#37 |
Drives: Toyota 86 GTS 6M
Stating the obvious here, but the 86/BRZ will out handle sweet f#%k all if you're a shit driver.
#38 |
#39 |
Time Traveller
Outhandle?
According to MotorTrend the the Triplets are amongst the best driver's cars in the world. No mention of hot hatches with their front drive understeer and turbo lag. As @chaoskaze noted above, people often don't understand the difference of performance vs. handling and why the trips low COM, COG, weight, RWD, + weight distribution, suspension tuning and NA engine & price make it one of the finest cars produced in a generation. MotorTrend is no bible, but they make a great point that guys like Chris Harris, Clarkson, Probst, and more backup. The 86 is so hard to fault that it's constantly compared to much more expensive cars (as in the MotorTrend article above), or v.s. used sports cars that cost thousands more when they were new. This is key because in a real world comparison test people rarely cross-shop cars that are $7k - $33k more expensive. Heck, put $10k into a base FRS and it would smoke any of these cars on the track (blower, tires, brakes). 2006 Porsche Cayman S $58,900 - 2013 adjusted $68,716 2011 Lotus Elise $39,985 - 2013 adjusted $43,669 2011 Mazda RX-8 R3 $32,960 - 2013 adjusted $34,527 2013 Nissan 370z $32,280 2009 Honda S2000 $34,995 - 2013 adjusted $38,219 The triplets ride on RWD sports car platform to be built out. A foundation to make either a track monster, show car, or something in between for very little money ***And another thing, this time power - The triplets FA20 is one of the highest specific output naturally aspirated engines in the world at 100bhp/liter. >link< Porsche 911 GT3 RS4.0 - 125.1 bhp/L Ferrari 458 Italia - 125.0 bhp/L Lexus LFA - 115.1 bhp/L Audi RS5 - 108.1 bhp/L Lambo LP570-4 Superleggera - 108 bhp/L FA20 Triplets - 100.0 bhp/L </rant> |
| The Following User Says Thank You to DAEMANO For This Useful Post: | sprintertrueno86 (06-20-2013) |
#40 |
Drives: 2018 BMW M2
#41 | |
#42 |
Drives: Ultramarine 86 - 6MT
I Disagree. Thanks for your input though.
