#225 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | strat61caster (06-18-2013) |
#226 |
Mentat
Drives: 2013 Scion FRS 6MT
Other than cargo space. The S2000 is superior in every way.
#227 | |
Drives: '13 FRS - STX
Worrying about it is completely normal, this thread SHOULD exist. I'll agree that calling for the crucifixion of Toyobaru is premature but if they don't have a reasonable solution to an actual problem it'll be a big blemish on the car and the companies. |
| The Following 5 Users Say Thank You to strat61caster For This Useful Post: | Carwhisperer (06-18-2013), Lonewolf (06-28-2013), Muaddib (06-18-2013), sierra (06-28-2013), vgi (06-18-2013) |
#228 |
Drives: 13 Asphalt FRS AT
A couple of noob questions... I read this thread from front to back and didn't see any mention of aftermarket injectors. Has anyone who replaced their injectors with aftermarket injectors experienced this problem? I also heard that independent Ecutek tuners have incorporated the necessary retard into their tunes. Anyone have any firsthand experience with the new tunes?
#229 |
Drives: Moped
| The Following 3 Users Say Thank You to Lonewolf For This Useful Post: |
#230 | |
| The Following User Says Thank You to Dezoris For This Useful Post: | pixel67 (06-19-2013) |
#231 |
Besides, there's nothing wrong with the injectors just their seals appear to be a weak link.
And there are aftermarket seals available for other injectors: http://www.therpmstore.com/store/p/5...-3-6-CX-7.html The thread title should more correctly read: 'Combustion chamber leaking due to broken/missing injector seals'. (The direct injectors are not leaking). |
#233 |
Anyone have access to the Subaru Technical Information System?
It looks like a new revised version of the 11-130-13 TSB was posted today: 11-130-13R Technical Service Bulletin Difficulty Starting, Rough Idle, Cam Position or Misfire DTCs Jun 19, 2013 I'm assuming the R is for revised? |
| The Following User Says Thank You to Tirewarmer For This Useful Post: | xjohnx (06-19-2013) |
#234 | |
Grip>Slip
#235 | |
Drives: Attitude
#236 |
Grip>Slip
Coming up. Just bought a subscription and downloaded it.
#238 |
Grip>Slip
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 06:33 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 04:26 PM |
| Direct Injector's Leaking | Carwhisperer | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-11-2013 09:31 AM |
| Leaking Oil? | 636 | Issues | Warranty | Recalls / TSB | 11 | 01-05-2013 04:43 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 05:03 PM |
