#29 | |
Drives: 4 Wheels Auto
Not sure if anyone found this; the short track from turn 9 to 20 really looks like the outline of the monster in Loch Ness. It just suddenly appeared to me today.
Looks like a fun track.
#30 | |
Drives: FR-S Firestorm 6MT
I use 2nd to 4th gears, occasionally 5th at end of Rocky Road if I get good exit speed out of T3/4 and I'm hustling the car (but it's a quick 5th then back down into 4th then 3rd for Big Rock). For Temptation T8, it's borderline 2nd or 3rd. I use 2nd gear into Beak T12A, 2nd or 3rd for Hook T14 and 2nd through T18-19 before getting on it for the main straight. |
#31 | |
For our July 8th event, we will be using this configuration so it should be quite fun. Advantage to momentum cars! The May 24th event is coming soon!! Sign up while there is still availability! |
#32 |
Me? No speedbleeders here. Gotta still do fluid change and swap pads as well though.
#33 | |
Bump! Only 1 week before the first MCO lapping event of the year. Don't miss out on the opportunity to drive and learn this fabulous track! |
#34 | |
#35 |
Drives: Raven 6AT
How did the day go? Any videos? I'm trying to plan for the July session. Can I do it on stock tires and brakes?
The fun has returned!!
Morimoto Mini H1 HID conversion |
#36 | |
Track was dry after lunch so it was a good afternoon, lots of cars on track and for the most part everyone was well behaved. I had a good student with a 911 so he had fun learning the track. As far as stock goes, 3 of the FT86 there had upgraded tires. Geoff and the other instructor ran stock tires. Last year I ran the stock tires for all events and they did pretty well and you learn a lot about the car's dynamics this way. Definitely stickier with better tires though. I upgraded pads to HP+ from my second event on, a very worthwhile upgrade for under $100. You will fade the stock pads at Calabogie. |
| The Following User Says Thank You to Slick For This Useful Post: | SupraRon (05-25-2013) |
#37 |
#38 | ||
Drives: Raven 6AT
Ron
#39 |
Calabogie Track Videos
Hi Guys,
First time doing vids so editing took a bit longer than expected. Here are a few vids from the last MCO Lapping School on May 25th. It was a crazy cold day (was actually snowing when we arrived at 7:00am). Temps started at 2-3 deg C and gradually warmed up to 11C by end of day. Wet sessions until lunch when it finally dried for the afternoon. Total of 5 FR-S/BRZ at the track that day! 10:00am A rather cold (4C/39F) and still wet session, spent some time getting used to the new tires, Conti Extreme Contact DW, very impressed with the wet grip. Some fun chasing the STi for a bit and getting past some others. [ame]http://youtu.be/Dtj3gJ58rA0[/ame] 1:00pm Finally dry for the first afternoon run and warmed up a tad to 8C. Lots of traffic and fun catching up to some packs of cars. First lap clear and then I catch some traffic. Checkout the flame-throwing Miata with super-tall wing at 12:15. Norm in black FR-S does a good job to stay in front for a while. Radical storms by at 13:15. Fun keeping pace with the GTi toward the end. [ame]http://youtu.be/PfEB9083LPM[/ame] 3:15pm Much warmer now finally, but still only 11C. Much quicker laps. Clear laps until 7:57, then S2000, Vette and finally catching Mike in his blue Miata. [ame]http://youtu.be/rvVlsem9OX8[/ame] 4:30pm Relatively quiet last session of the day, at 8:00 I drive through the pits since Civic wasn't letting the 911 ahead of me by. At 12:00 waive past the Lotus and keep pace with him. Thought it would be tough to match the cornering, but I am able to catch him in the corners but he just flies away on the straights. A little bobble at the end of the last lap, back end tries to come around, oops! [ame]http://youtu.be/IkVPJvWTNSA[/ame] Last edited by Slick; 06-05-2013 at 11:55 PM. |
| The Following User Says Thank You to Slick For This Useful Post: | Mike86CelicaGTS (06-06-2013) |
#40 |
Drives: Raven 6AT
Great vids. Thanks for sharing. I definitely gotta get there this year.
#41 | |
FR-S's will rule... Should be loads of fun, I'd guess the first corner will be second gear. |
#42 |
Drives: Subaru BRZ
Turn 1 Stadium track is a lift or tap corner - your turn in should be right where the pit wall ends, and apex where there's a flat/straight spot on the curb on the right. If you get it right, you should have one input all the way through 9a. You don't have to be full throttle on turn in - I found it best to be partial throttle on turn in and ease back to full throttle once you're at the exit of Temptation.
FWIW, this is in my track prepped ITR, and it took a bit of time during my school in May to get to that point where it was just lift and go. It's more comfortable to tap though because you are carrying a lot of momentum either way.
Bryan.
| First 3 Days of the FR-S (Deer On Road) | kanundrum | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-30-2012 03:02 AM |
| Insurance for track days? | Hanakuso | Tracking / Autocross / HPDE / Drifting | 24 | 06-25-2012 09:19 AM |
| 6 Days to go.............. | Neilus | AUSTRALIA | 51 | 06-03-2012 04:24 AM |
| SCCA and Track days | Primo86 | NY / NJ / CT / PA | 4 | 06-01-2012 08:07 PM |
| A little bit disappointed in these three days | dodof | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 11-30-2011 03:18 PM |
