#57 | |
Re-member
Drives: Toyota camry
Dealer uses premixed coolant. Loosing that much coolant is a problem that needs immediate attention. If you top it up and your dealer is shity they wont be able to ''replicate the problem''. If you admit you drove with too little coolant they might blame other problems on you. Best thing- call them.
Nothing decays like progress, and nothing preserves like neglect.
#58 | |
Drives: 2010 BMW M3, 2013 Subaru BRZ
#59 |
Drives: Rocket Bunny'd GT86
Mine goes a bit lower than full every once in a while (maybe every month and a half for a daily driver living in Dubai with summer heat ranging to 110 degrees). I guess it's just normal, no leaks or overflowing, temperature is below the middle as always even at colder temps.
#60 |
Drives: Scion FRS
So the dealer sold me toyota pink which says it for every toyota but the FRS? Am I ok with using it?
#61 |
I went to subaru to get the blue coolant. It was ~$25. I noticed that I had lost a little...nothing crazy. I've owned the car for 6 months and it just now hit the low line. When I bought it, it was about 1/2 way up to the full line.
#62 |
Asphalt FR-s
Well my wife complained about some problems with the car as she drove it from san Diego California to yuma arizona. She complained about a knocking in the engine bay and feeling the gas pedal knock as well. She also complained about hearing the brakes whistle when she come to a stop. I drove the car from home to work and I only noticed the knocking noise. I checked the engine bay and everything looked fine, except for the coolant. It was looking low and the theme here alone is well past 100
Sent from my SCH-I535 using Tapatalk 4 Beta
2013 Scion FR-S Asphalt, 5% tint, Invidia n1 exhaust, Cusco front strut bar w/ BCS, Cusco rear strut bar, cusco earth ground kit, Cusco oil catch can, Takeda short ram air intake, custom vinyl |
#63 |
AutoX-10/10ths every run
I just swapped hoses to the Perrin ones with t-clamps a few weeks ago. Also did a coolant change at that time. Car has not "lost" any coolant since. I think that the stock hoses and clamps aren't sufficient to keep coolant from seeping out. My stock hoses always had a white residue around the ends near the fill cap.
#64 |
Drives: Scion FRS
So I cant use the toyota pink? I guess ill see if I can return it and go to the subaru dealer and pick up blue.
#65 | |
Drives: 2013 FRS Asphalt
no you can no use the pink stuff. get blue from subie
2013 Scion FR-S AT Picked up 5/30/2012
#66 |
Drives: Scion FRS
How much do I need assuming im doing a full swap and installing the FBM radiator?
#67 | ||
Undisputed El Presidente
Drives: Zenki 37J ZN6
You guys have any update? Also did you pay for the pressure test or did the dealership cover it? |
#68 |
Coffee Snob
Drives: '14 SWP BRZ Limited
I just want to say that this issue was evident on my FRS as well. I was around 3k miles, and the coolant levels were surprisingly low.
#69 |
Drives: raven FRS
19.000km, its pretty cold here in montreal but checked the car after being warm for 35min,
and its barely half of low. Cold theres no coolant in the tank.... kinda odd but maybe its due to the weather, no leaks apparent anywhere.
RAVEN FRS 2013 - TRD air filter - Nameless OP/DP - Greddy EVO3 - STAGE 2 OFT/OFH -
#70 |
Drives: raven FRS
so i went to toyota today for the coolant. They checked for leaks couldn't find them... i specifically said to put The BLUE coolant but they topped it off with Pink...... am i screwed? do i have to reflush the whole system now?
i hate dealerships T_T
| Checking and Changing BRZ/FR-S Engine Coolant | GrimmSpeed | DIY (Do-It-Yourself) Guides | 39 | 05-29-2023 09:15 AM |
| Blue Coolant | Boosted2.0 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 108 | 07-12-2016 06:13 PM |
| Coolant Levels | DriftEightSix | AUSTRALIA | 17 | 01-29-2013 10:19 AM |
| Low Coolant | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 12 | 11-25-2012 01:03 PM |
| European fuel/coolant gauge face | arbnpx | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 05-31-2012 01:23 AM |
