Old 06-15-2013, 01:16 PM   #57
ahausheer
Re-member
Drives: Toyota camry
Originally Posted by RAWR BRZ View Post
Guys I checked my coolant after driving around with a warm engine and it is below the low line... I cant even see my coolant fluid... Just add distilled water tomorrow or go to dealer for free top up? Do dealer use a coolant mix or just pour distilled water in my car?
Dealer uses premixed coolant. Loosing that much coolant is a problem that needs immediate attention. If you top it up and your dealer is shity they wont be able to ''replicate the problem''. If you admit you drove with too little coolant they might blame other problems on you.
Best thing- call them.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-17-2013, 02:14 AM   #58
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
When I checked (at night) it looked as if there wasnt any because I distinctively remember seeing the coolant when it used to be in the middle of low and full... The next morning when I checked it warm was way over full... at least a good 2 inches over... It must of been so full that night that I couldnt see the line where the top of the fluid was before between low and full. I bet the dealer added coolant to full level when the car was cold while my car was there....
RAWR BRZ is offline   Reply With Quote
Old 06-17-2013, 07:16 PM   #59
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Mine goes a bit lower than full every once in a while (maybe every month and a half for a daily driver living in Dubai with summer heat ranging to 110 degrees). I guess it's just normal, no leaks or overflowing, temperature is below the middle as always even at colder temps.
Yamajee is offline   Reply With Quote
Old 07-31-2013, 05:39 PM   #60
dabocx
dabocx's Avatar
Drives: Scion FRS
So the dealer sold me toyota pink which says it for every toyota but the FRS? Am I ok with using it?
dabocx is offline   Reply With Quote
Old 07-31-2013, 05:46 PM   #61
suaveflooder
I went to subaru to get the blue coolant. It was ~$25. I noticed that I had lost a little...nothing crazy. I've owned the car for 6 months and it just now hit the low line. When I bought it, it was about 1/2 way up to the full line.
suaveflooder is offline   Reply With Quote
Old 07-31-2013, 06:03 PM   #62
ronnBOi720
Asphalt FR-s
ronnBOi720's Avatar
Well my wife complained about some problems with the car as she drove it from san Diego California to yuma arizona. She complained about a knocking in the engine bay and feeling the gas pedal knock as well. She also complained about hearing the brakes whistle when she come to a stop. I drove the car from home to work and I only noticed the knocking noise. I checked the engine bay and everything looked fine, except for the coolant. It was looking low and the theme here alone is well past 100
Sent from my SCH-I535 using Tapatalk 4 Beta
Old 07-31-2013, 06:08 PM   #63
whataboutbob
AutoX-10/10ths every run
I just swapped hoses to the Perrin ones with t-clamps a few weeks ago. Also did a coolant change at that time. Car has not "lost" any coolant since. I think that the stock hoses and clamps aren't sufficient to keep coolant from seeping out. My stock hoses always had a white residue around the ends near the fill cap.
Build thread:Here
Old 07-31-2013, 08:31 PM   #64
dabocx
dabocx's Avatar
Drives: Scion FRS
So I cant use the toyota pink? I guess ill see if I can return it and go to the subaru dealer and pick up blue.
Old 07-31-2013, 09:31 PM   #65
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
no you can no use the pink stuff. get blue from subie
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-01-2013, 03:03 PM   #66
dabocx
dabocx's Avatar
Drives: Scion FRS
How much do I need assuming im doing a full swap and installing the FBM radiator?
Old 03-11-2014, 06:49 PM   #67
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by Laika View Post
Well technically speaking, you don't need to heat up a container to make the water inside boil, you can just drop the pressure.
Grab a box of pasta, it should say to boil it longer if you're in a high altitude (low pressure) area.
@ahausheer's rationale seems right on the money.
To go back to my last post regarding the issue and the coolant being topped off. Scientifically speaking, it should take MORE time to get to operating temp but at the same time, the car should stay warmer LONGER after getting to operating temp and turning the car off.
I haven't really noticed a truly longer warm up time, maybe by about 10-15 seconds. On the other hand, I do notice the car staying warm longer after I let it sit. I used to come back to the car 2 hours later and have to wait for it to reach the 6oclock position on the thermostat. Now I can just get in and go it seems.
Edit: The dealership insisted on running a pressure test for me. No leaks anywhere.
Originally Posted by Zach View Post
13k miles here - was just on a 700 mile road trip when I noticed a funny smell at a motel when i stopped for the night. Checked it in the AM and the coolant res was BONE DRY. No idea how much was in the rad but i didnt have any CEL or warning lights and had not checked since my last oil change so no idea how long its been dry.
I found a toy dealership close to me and got to spend the entire day there, the end result was a ok pressure test and them filling it back up. Not happy, keeping my eye on it.
Zach
Im at 44000 and currently going through this issue. Was bone dry on 2/25 and took it to the dealer. Since they topped it off it only took a week to get below the low line. This was all check in the late morning.
You guys have any update? Also did you pay for the pressure test or did the dealership cover it?
Old 03-11-2014, 06:56 PM   #68
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
I just want to say that this issue was evident on my FRS as well. I was around 3k miles, and the coolant levels were surprisingly low.
leicaboss is offline   Reply With Quote
Old 03-12-2014, 11:47 AM   #69
frsqc
Drives: raven FRS
19.000km, its pretty cold here in montreal but checked the car after being warm for 35min,
and its barely half of low. Cold theres no coolant in the tank.... kinda odd but maybe its due to the weather, no leaks apparent anywhere.
RAVEN FRS 2013 - TRD air filter - Nameless OP/DP - Greddy EVO3 - STAGE 2 OFT/OFH -
frsqc is offline   Reply With Quote
Old 03-14-2014, 02:02 PM   #70
frsqc
Drives: raven FRS
so i went to toyota today for the coolant. They checked for leaks couldn't find them... i specifically said to put The BLUE coolant but they topped it off with Pink...... am i screwed? do i have to reflush the whole system now?
i hate dealerships T_T
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 09:15 AM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 06:13 PM
Coolant Levels DriftEightSix AUSTRALIA 17 01-29-2013 10:19 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 01:23 AM
