Old 06-15-2013, 07:29 PM   #953
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by sw20kosh View Post
Update:
Car dyno'd and running strong. We got the expected performance from the kit.
Water/meth injection added 20 hp and extra torque everywhere from 3,000-7,500. It also flattened out the top end even more. Good results today. Robi's tuner worked his magic. It allowed 3 degrees of timing advance among other things. This is with the smaller nozzle (5gph 313cc/min) supplied with the kit. Will test the larger nozzle (7gph 440cc/min) down the road with a progressive MAF based controller.
Time to hit the track tomorrow and sunday.
Originally Posted by swift996 View Post
Nice, when can you share the dyno?
It seems you missed the question, when can you share the Dyno? Also did you take any Dynos of just the kit, no WMI kit installed?
Old 06-15-2013, 11:02 PM   #954
sw20kosh
Drives: 2013 Black FR-S
I can't share it untill innovate releases their dyno graphs. Believe me you will see graphs from Robi and I as soon as we are allowed to. We are silly excited to share this with the community! Photos, anecdotal evidence and videos for now till NDA released.
The auzzie dynos are pretty cool to look at.
The Following 6 Users Say Thank You to sw20kosh For This Useful Post:
akuhei (06-15-2013), Jeff86 (06-15-2013), Sportsguy83 (06-15-2013), tom@kartboy (06-15-2013), trdfrs (06-16-2013), whataboutbob (06-17-2013)
Old 06-15-2013, 11:19 PM   #955
Carwhisperer
Drives: A lot of supercars.
Boom.
Carwhisperer is offline   Reply With Quote
Old 06-16-2013, 12:24 AM   #956
Sportsguy83
Drives: Limited BRZ
Good edit
Old 06-16-2013, 12:35 AM   #957
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Good edit
It is a good edit indeed.
I will forget what I read....
:happy0180:
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
The Following User Says Thank You to akuhei For This Useful Post:
Sportsguy83 (06-16-2013)
Old 06-16-2013, 01:36 AM   #958
invisage
Drives: Thunder Silver 86 GTS
Directly before the supercharger rotors. This was recommended by someone who has been meth injecting positive displacement superchargers for decades.
If you inject pre supercharger you:
1. Can inject 3-4 times as much as the rotors further help to atomize the fluid and the rotors actually take up a fair bit of fluid as they have large surface area compared to centri compressors on turbo and centri sc.
2. You cool off the hot rotors significantly increasing their efficiency (heat kills efficiency)
3. You soft-seal the rotors to each other allowing them to be more efficient at producing boost. You can typically gain up to 1-2 psi depending on application whereas with an intercooler you typically lose psi due to pressure drop across the intercooler.
* It allowed 3 degrees of timing advance among other things. This is with the smaller nozzle (5gph 313cc/min) supplied with the kit. Will test the larger nozzle (7gph 440cc/min) down the road with a progressive MAF based controller.
Is yours e intercooled version? I bought an AEM kit just for this but when mentioned to Sprintex the engineer said he would be concerned with the laminova (spelling) intercooler it may cause the water/meth particles to condensate and cause pooling in the manifold ect. Have you checked to see if this is happening?
invisage is offline   Reply With Quote
Old 06-16-2013, 02:58 AM   #959
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Any updates from Innovate regarding CARB EO?
uspspro is offline   Reply With Quote
Old 06-16-2013, 03:21 AM   #960
sw20kosh
Non intercooled
Old 06-16-2013, 03:24 AM   #961
sw20kosh
:happy0180:
lol
Originally Posted by robispec View Post
The latest down under dyno chart is spot on.
E85 = chemical intercooling so we are "very close" to the above intercooled chart.
he is running the 75mm pulley (= 7 lbs of boost)
Old 06-16-2013, 04:29 AM   #962
Gen
Drives: Scion FR-S
Fortunately I'm under no NDA.
What I will say is Robi puts down more WHP on the same dyno than I do with my turbo. He's got some other stuff that helps though.
Gen is offline   Reply With Quote
The Following User Says Thank You to Gen For This Useful Post:
Old 06-16-2013, 09:23 AM   #963
Pete
Pete's Avatar
Drives: 22 BRZ
I'm stoked to see what sw20kosh got out of it with wmi. Filthy tricksy NDA! The WMI route is more interesting to me, looks cleaner. I'm such a nerd for this.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 06-16-2013, 09:47 AM   #964
wparsons
wparsons's Avatar
Is anyone running the intercooled version in a car that sees track use? I'm curious to see how many laps it'll take before the liquid/air IC can't keep the intake charge cool anymore.
If it can't hold up to ~30 minute track sessions then I'll probably go non intercooled, but if it can stay efficient for that long then intercooled seems to be the way to go!
flickr
Old 06-16-2013, 01:11 PM   #965
swift996
swift996's Avatar
Non intercooled
Do you plan on swapping a smaller pulley and running more boost with the meth? Very anxious to see your results.
I rode with my friend in a 335i yesterday. I know it's apples to beef but he showed me some pulls on his non-meth tune and his meth tune. Meth tune, fast as ______. He also mentioned his car would go into limp mode during HPDEs from overheating. When he runs meth he doesn't have that issue.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-16-2013, 01:50 PM   #966
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Thank the car gods for physics!
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 11:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 11:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 02:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 05:40 PM
