Old 06-14-2013, 05:24 AM   #29
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Originally Posted by SLICVIC View Post
this.
eyeballing my LCA and toelinks was extremely difficult. in the end had an alignment shop do it. I read up somewhere about a company attempting to produce these and the result was too difficult to mass produce and sell at an attractive price. Seeing these 800 does not surprise me. As far as fitment goes, sometimes negative camber isnt "Good" camber. For example, the front LCAs being on a Mcpherson setup, Dialing in more negative camber will give you LESS clearance . (same effect on the GD Subarus with Mcpherson all around) On our rears, the LCAs do help for fitment clearance, but the uppers will give you alot more room between tire and fender. LCAs will kick out the bottom of the knuckle/wheel while upper arms will pull in the top of the knuckle/wheel.
Just curious, lets say on stock LCA , trailing, toe links, Whats the maximum negative camber possible with your upper control arms?
Appreciate this info a lot.
I originally had upper camber bushings, LCA's and toe arms on order but after reading this I think I will try and cancel that order and just go with the upper arms for now.
All I want to do is tuck my rear wheels because my offset is pretty aggressive and 4 degrees should do it. If not I'll
revisit the LCA option again.
JordanWho is offline   Reply With Quote
Old 06-14-2013, 04:58 PM   #30
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
What kind of offsets? i can see upper control arms becoming more popular than LCA+ etc. Might have to start saving up for these
SLICVIC is offline   Reply With Quote
Old 06-14-2013, 07:44 PM   #31
JordanWho
JordanWho's Avatar
Front - 18 x 8.5 +13
Rear - 18 x 9.5 +18
Will take before and after pics during install.
The Following User Says Thank You to JordanWho For This Useful Post:
SLICVIC (06-14-2013)
Old 06-17-2013, 02:20 PM   #32
Cmarsh
Drives: 2013 FRS
Yeah...$800 for arms that you can't adjust on the car? I appreciate the hard work and design, but no thanks.
You are willing to pay more for a weaker part? I like this design, and tend to shy away from parts that have an adjuster built in..just from a strength point of view. Besides...90% of the people with these cars have no buisness making on car camber adjustments..nor the correct tools to measure camber when not on an alignment machine.
Chris
Cmarsh is offline   Reply With Quote
Old 06-17-2013, 11:39 PM   #33
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
very true^
Old 06-18-2013, 12:40 AM   #34
IMOA
Drives: 86 GTS
Chris
I'm happy enough to pay extra for a weaker part as long as it's strong enough to be fit for purpose. And just because a part is on car adjustable doesn't mean it's being adjusted while not on an alignment machine, it just makes it easier, faster and cheaper to do so.
IMOA is offline   Reply With Quote
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 10:17 AM
SPC rear lower control arms, Fix your camber! JoeBoxer Brakes, Suspension, Chassis 12 03-31-2013 08:02 PM
WORKS Rear Upper Control Arm Bushing - Inner Camber Correction 86_ZN6 Brakes, Suspension, Chassis 0 02-06-2013 01:20 AM
