#15 |
Drives: 2013 FRS
@Brian@Vortech perhaps you might want to chime in on this
#16 |
This was the noise I started hearing which maybe bearing noise from that pulley at this point.
[ame="https://www.youtube.com/watch?v=FgyYmguXMZQ"]FR-S Vortech Pulley Noise - YouTube[/ame]
| The Following 2 Users Say Thank You to Dezoris For This Useful Post: | Deepseadiver (07-09-2013), michaelosx (07-09-2013) |
#17 |
#18 | |
Drives: 2013 whiteout FR-S
#19 |
My pulley is in perfect condition. It has barely brushed my intake pipe. I did feel nervous about that plastic pulley before install because it did wiggle.
I will say this some of these ground down pulleys "could" be installation error. I still have room to position the pipe higher on the the supplied bracket.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#20 |
Thupercharged
If you are driving the car during the winter do you have a battle plan for a blower heater for cold starts?
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#21 | |
#22 |
Thupercharged
Just checked my pulley/pipe clearance. No issues.
When I installed, I lifted the pipe before tightening the couplers/bracket for this exact reason It looks like less from the picture, but there is a good 8-9mm of clearance between pulley/pipe ![]() No rubbing ![]() Also, all owners should check their pipe for rubbing... it took less than 2 minutes with a flat blade screwdriver and a 10mm wrench to pull the pipe and check. The pipe DOES contact the hood insulation, but it doesn't really put pressure on the hood/pipe and only touches when fully closed. I am changing the pulley for a dayco/Duralast pulley. I wonder what the mfr. of the pulley that comes with our system is....
2013 FRS
| The Following User Says Thank You to DJCarbine For This Useful Post: | charged86 (07-09-2013) |
#23 |
#24 | |
Thupercharged
Dayco 89003 Pulley 76mm x 17mm Flat w/Flange, 26mm wide Gates 38006 Steel Smooth/Backside 76mm x 17mm x 30.5mm Its listed as a cross-reference for the 89003, and looks like it will actually give more room than the dayco pulley because it does not have the "guide" ridges on the ends of the pulley
2013 FRS
#25 |
Thupercharged
Also are you guys removing the blower to change the belt?
It looks like with enough cursing, you don't need to.....
2013 FRS
#26 |
Hmm I will check when i get back in town next weekend for other places i may be rubbing. I am at 1,500-2,000 miles and just checked my idler pulley. Looks perfect. I have a decent clearance and everything is completely centered between pulleys, brackets, etc. I just made sure to line that up when installing. However when i reinstalled the MAF up pipe i forgot to check for clearance. I will verify if maybe instead of rubbing against the pulley if i am rubbing against the chasis on the passenger side.
Although the thought of a potential belt issue is un-easy considering when i get back i have a ~1,500+ mile road trip in the car coming up.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#27 | |
| The Following User Says Thank You to cb7tuner For This Useful Post: | charged86 (07-09-2013) |
#28 |
Drives: BRZ Limited
I checked mine this morning. There's a little wear spot on the pipe but I notices if you make sure to push it in till it hits the throttle biddy it self there's alot more room. I do have to say I am disappointed in Vortech service latley I have been trying to contact the guy that sold me my kit for about two months now.
| Kartboy Crank Pulleys 95.00 | tom@kartboy | Engine, Exhaust, Bolt-Ons | 16 | 06-11-2013 02:06 PM |
| Crank,Alternator,Waterpump Pulleys etc..? | fareastbrz | Engine, Exhaust, Transmission | 6 | 05-28-2013 09:46 PM |
| Titan Performance second batch of pulleys | Amalgamo | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 07-30-2012 10:57 PM |
