AVOturboworld
Old 09-26-2012, 12:10 PM   #631
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
A lot of time has been consumed by the scavenge pump in regards to the fitment testing and pump operation testing. I'm sure everybody will agree that that is a key piece of the kit, and it is something that everybody will find very interesting once we release those details.
AVOturboworld is offline   Reply With Quote
The Following 7 Users Say Thank You to AVOturboworld For This Useful Post:
bimmerboy (09-26-2012), Calum (09-26-2012), civicdrivr (09-26-2012), dcamco (09-26-2012), Jeff86 (09-27-2012), kidgogeta (09-26-2012), Sportsguy83 (09-27-2012)
Old 09-26-2012, 05:21 PM   #632
subatoy
subatoy's Avatar
Drives: subatoy
Sorry but I don't know what a scavenger pump is, can you explain?
subatoy is offline   Reply With Quote
Old 09-26-2012, 05:34 PM   #633
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
an oil pump used return oil from the crankcase to the oil tank.
Ny Brz is offline   Reply With Quote
The Following User Says Thank You to Ny Brz For This Useful Post:
Guff (09-26-2012)
Old 09-26-2012, 06:38 PM   #634
Calum
That Guy
Drives: 2013 asphalt FRS MT
Just to make a little more clear, the scavenge oil pump will be pumping the drain oil from the turbo back to the oil pan. With the turbo lower then the oil pan, it's required.
Old 09-26-2012, 06:44 PM   #635
AVOturboworld
A teaser of the oil scavenge pump:
200cc in 7 seconds.
A further teaser - there are no wires connected to this pump...
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 09-26-2012, 06:53 PM   #636
Cheddar
Saving them pennies...
200cc in 7 seconds.
Pulley driven?
Cheddar is offline   Reply With Quote
Old 09-26-2012, 07:08 PM   #637
sweeney208
sweeney208's Avatar
Drives: red subaru brz limited
bare with me.. i come from a world of lifted jeep wranglers and mudding and just completely switched to a BRZ.. so turbos are sooo new to me. I know with like lift kits theres always more that you need then what comes in the box.. is this the case with turbos? or will a kit be all you need.. just curious because one day i plan on doing this to my brz. thanks.
sweeney208 is offline   Reply With Quote
Old 09-26-2012, 08:24 PM   #638
Calum
That Guy
Like lit kits, it'll depend on the company supplying it. For some turbo kits you'll end up needing to drill things or buy hoses or clamps. Some will come with everything.
Old 09-26-2012, 08:57 PM   #639
Gen
Drives: Scion FR-S
How long do these typically last? Any maintenance required? Any warning if it's going to die?
Gen is offline   Reply With Quote
Old 09-26-2012, 09:13 PM   #640
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
No wires? Has to be belt driven.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-26-2012, 09:23 PM   #641
Calum
That Guy
No idea, non at all. The only scavenge pumps I've worked on were on a 25000 hp gas turbine and those didn't go often and required VERY little maintenance. Honestly in the 12 years I did that job, I'd heard of one going. But that's a completely different application with (most likely) VASTLY different tolerances and R&D.
Old 09-26-2012, 09:26 PM   #642
Calum
That Guy
The wires might go to the motor not the pump. It's a technicality that I doubt AVG would exploit, but possible nonetheless.
Old 09-27-2012, 03:15 AM   #643
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
AVO, with such a distinct approach you have my hands ready for applause
Just raise a curtain a bit
F5 F5 F5
MSTiFK8R is offline   Reply With Quote
Old 09-27-2012, 04:58 AM   #644
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Thanks for the teaser. The scavenge pump is my biggest concern about your setup and I like the fact that I couldn't hear a noisy electric pump. Very curious to see what you are doing. I've heard of mechanical pumps driven off of cam gear. Is there going to be a reservoir? One of my worries is the pump being too efficient and running the turbo dry.
Jeff86 is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
