AVOturboworld
Old 04-28-2014, 01:20 PM   #2927
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by SkAsphalt View Post
So to up the boost a little bit on the Stg 1 kit, I just need to play with the waste gate actuator guide a little bit? Cause I know some people are boosting 7-8 pounds off the stage 1 wastegate. Just wondering, I am consistently hitting 6.2 with full boost, zero knock on 94 octane. I have some room to grow.
Don't do it without tuning for it.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
SkAsphalt (04-28-2014)
Old 04-28-2014, 03:52 PM   #2928
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Most certainly will not - but that is how I would go about doing it correct?
Old 04-28-2014, 03:54 PM   #2929
Sportsguy83
Drives: Limited BRZ
Yes sir. Shorten it so that there is more preload, but don't over do it.
Old 04-28-2014, 07:39 PM   #2930
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Given the amount of questions lately in regards to cooling at the track, I've got some photos of how we prepped the AVO Japan BRZ that has been tracked extensively. The key to cooling at the circuit is air flow through the radiator, and how to maintain that effectively as the speeds rise. Speed is a very important factor that is often overlooked. That's because air seeks the path of least resistance, and when you are going fast enough, that's not through the bumper/radiator, but around it. So you need to force it to go where you want.
We started by sealing off the edges around the radiator, important for making the air go through and not around.
Mounted to the car.
Next, and just as important, we made sure the air from the bumper opening is ducted properly through the intercooler and to the radiator
Finally, we designed our own lip spoiler. From our experience tuning race brz's at 230km/h, we found that too much air was escaping under the bumper instead of going into the radiator. With the lip spoiler, we dramatically lowered temperatures and improved handling. The Oil cooler is also ducted and sealed up properly.
An interesting fact here - our RA model BRZ only has one cooling fan, as it has no air conditioner fitted (from the factory). In the BRZ/FR-S, one cooling fan is for the radiator, and one is for the air conditioner.
AVOturboworld is offline   Reply With Quote
The Following 6 Users Say Thank You to AVOturboworld For This Useful Post:
DarkSunrise (07-09-2014), Kiske (01-31-2015), M1K3 (04-29-2014), Raven604 (05-02-2014), sw20kosh (05-21-2014), Xero-Limit (05-22-2014)
Old 05-02-2014, 09:06 AM   #2931
qtwre
Drives: White FR-S
So how many PSIs is/was everyone getting with the stock kit? I finally got my kit installed yesterday and my log tells me I'm hitting a very consistent 5psi with the actuator labelled 6psi.
I'm thinking of giving the rod a couple turns to at least get to the proper 6psi. Not trying to be greedy.
Also, I don't know if it's impolite to discuss, but for those of you who don't have a great tuner nearby, who have you gone with or plan to go with for an e-tune?
qtwre is offline   Reply With Quote
Old 05-02-2014, 10:11 AM   #2932
protpibe
protpibe's Avatar
I'm getting 7psi on the stock actuator, however, I've had the actuator off and would have moved the actuator rod in the process. Just adjust the rod and you can bump it up to 6psi.
I went through Bill @ Delicious Tuning for my AVO base map and was very pleased. The everyday driveability was perfect with no surging, idle dips, etc. I just ordered their new Speed Density MAP tune with a boost controller so I'll post up impressions when I have it in next week.
It was between Delicious and Drift Office for me.
The Following 2 Users Say Thank You to protpibe For This Useful Post:
DesertFrs (05-04-2014), SkAsphalt (05-05-2014)
Old 05-02-2014, 11:24 AM   #2933
onzippy
Drives: 2014 FRS
Originally Posted by protpibe View Post
...... I just ordered their new Speed Density MAP tune with a boost controller so I'll post up impressions when I have it in next week.
I've got the AVO kit also and just installed/flashed mine Wednesday with Delicious speed density flash and electronic boost controller and 11PSI map sensor.
How much boost are planing for the multi-maps? The only other mods I have are exhaust so I went with 6psi and 11psi maps.
onzippy is offline   Reply With Quote
The Following User Says Thank You to onzippy For This Useful Post:
Old 05-02-2014, 11:34 AM   #2934
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
OEM map sensor and logging through EcuTek? If it is a consistent number then you have probably maxed out your OEM MAP sensor so you don't really know how much boost you are running.
The Following User Says Thank You to King Tut For This Useful Post:
protpibe (05-02-2014)
Old 05-02-2014, 11:53 AM   #2935
protpibe
protpibe's Avatar
You're much more liberal than me haha. I'm running 2.5" overpipe, 2.5" catless front pipe (soon to be 3"), and a 3" non-resonated catback. I'm only doing 7psi and 10psi 91 octane, and 10psi 94 octane
DesertFrs (05-04-2014), onzippy (05-02-2014)
Old 05-02-2014, 12:02 PM   #2936
protpibe
protpibe's Avatar
King Tut is right. I didn't realize your boost data is coming from your logs and not a boost gauge.
Old 05-04-2014, 09:05 AM   #2937
aaguirre123
Drives: sti 2012 sedan
Can you sell your stage 1 without the turbo? Everything else that comes with stage 1 but without the turbo? If so, how much?
aaguirre123 is offline   Reply With Quote
Old 05-04-2014, 09:26 AM   #2938
kbogarto
Drives: 2013 BRZ limited WRB
Does the base tune come with a built in failsafe for psi or AFR? I searched through the forum but couldn't get a definitive answer.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 05-04-2014, 03:52 PM   #2939
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
You guys are going to love @DeliciousTuning new VE tune! I had Bill once again work on my car last month. My current setup is 8psi on 91, 8psi on E80, 13psi on E80, and 15-16ish psi on E80. Waiting on some new parts to come in so I can start using this new tune. I'm on like revision 10.89 lol
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following User Says Thank You to DesertFrs For This Useful Post:
Old 05-04-2014, 03:55 PM   #2940
protpibe
protpibe's Avatar
No, you'll need a 3rd party tune for thst or an aem failsafe gauge
Sent from my HTC One using Tapatalk
The Following User Says Thank You to protpibe For This Useful Post:
kbogarto (05-04-2014)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
