#2339 |
Drives: GT86
If you want a proper fuel pump, buy Bosch. Won't be a direct drop-in though.
#2340 |
Drives: BRZ WRB
#2341 |
That Guy
Drives: 2013 asphalt FRS MT
Honest question, what's going on with the torque curve?
#2342 | |
That Guy
I really don't want to seem rude or combative but I've got to add, .5 psi shouldn't make a 20 ftlb difference, should it? |
#2343 |
Add lightness!
Drives: 17' WRX
Maybe this is a dumb question but are you guys using boost control through ecutek, a MBC or running purely off the wastegate spring?
#2344 |
Drives: Scion FRS
So this is on stock exhaust with only the stage one kit out of the box? Pretty good numbers, hopefully you can get another actuator.
#2345 |
I Love custom Turbo kits
Drives: Limited BRZ
Nameless exhaust
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | vubaru (03-25-2013) |
#2346 |
Drives: Limited BRZ
My install is going pretty good. I hope to be complete by next weekend, Dyno numbers to follow!
| The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post: |
#2347 | |
Fiebru
Drives: Scion FR-S and Integra Type R
I really want a turbo kit lol
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
| The Following User Says Thank You to Draco_PR23 For This Useful Post: | Sportsguy83 (03-24-2013) |
#2348 |
Drives: 2013 Black FR-S
250 whp at 5-6 psi... Wowy. I hope you bump the boost up to 8-9 psi and get some dyno time! It wouldn't be too hard would it? Just need a map sensor and boost controller?
| The Following User Says Thank You to sw20kosh For This Useful Post: | vubaru (03-25-2013) |
#2349 |
Drives: Limited BRZ
Correct.
#2350 |
Drives: 86 (FR-S)
#2351 |
Drives: Limited BRZ
See signature
| The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post: | Draco_PR23 (03-24-2013), Jeff86 (03-24-2013) |
#2352 | |
Drives: 2013 Subaru BRZ
That is way too hot, where were you measuring oil temperature? |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
