AVOturboworld
Old 02-10-2013, 05:54 PM   #2199
dabocx
dabocx's Avatar
Drives: Scion FRS
Whats the size of the downpipe that hooks up to the overpipe?
dabocx is offline   Reply With Quote
Old 02-10-2013, 07:46 PM   #2200
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The turbo discharge pipe, I believe 2.5"
Old 02-10-2013, 10:04 PM   #2201
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Originally Posted by MSTiFK8R View Post
I hope you will have enough data to approve 10+psi version of the kit shipped out by March ( 2nd batch coming, if I got you right ).
I'd love to have Stage2 (or whatever you call it) to pass 300whp and need to know which supporting mods you advise for a safe trip north of digit 300 ) - injectors, pumps, clutch, etc?
I'm not sure if we'll have a 10+ psi setup that's off the shelf in terms of tuning. While I know for a fact the turbo kit can go past 10psi, and also that it can get to 300whp easily, I'm far more comfortable with it being specifically pro-tuned on a dyno for people going to that level. Injectors, fuel pump, MAP sensor, clutch, and other supporting hardware are going to be necessary.
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
Sportsguy83 (02-10-2013)
Old 02-11-2013, 01:52 AM   #2202
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Right, Paul
I know going past 10psi every other car will perform VERY different and I suppose noone from this thread expects the 10+psi off-the-shelf solution
It would be just great to get the hardware to support that kind of power, having an ECUTEK Pro Guy standing next to you and leaning his geeky hands to your OBD-2 port )
To sum up, question:
Would you be able to include other far-going items in the package for the shipping batch?
My mods by now:
1) clutch: to withstand 300 lb\ft (HKS LA),
2) exhaust: 2,5" Milltek catback with a Motiv HiFlow Catted Front pipe
Seems I'll be needing extra:
1)injectors,
2 fuel pump
3)MAP sensor
4)AVO overpipe coated with matching ceramic coat
5) else?
I expect the basic map just to allow start-up and movement to the dyno-spot, nothing like fireworks strightaway )
PS - Sorry for leading this thread maybe too private, but I suppose I'm not the only one having these questions in mind
Mike
MSTiFK8R is offline   Reply With Quote
Old 02-11-2013, 02:23 AM   #2203
Sportsguy83
Drives: Limited BRZ
1)injectors,
2 fuel pump
3)MAP sensor
5) else?
I'm guessing the specifics will be unknown until AVO designs and releases other kit versions (stage 2, 3?, 4?). To properly answer your question, AVO would first need to design the system to specific safe parameters which takes time, that so far has been dedicated to designing the kit, finalizing stage 1, building them and starting specifics of stage 2.
My personal guess is you won't see components to supports 10+ psi until Stage 3+ if they do release more stages. (Of course, you can get the components yourself and make the 10+ psi without waiting for them to design it through your local shop).
Not to mention, seconding what Paul already said, that at that level you are talking about several other modifications needed like suspension, brakes, tires, motor mounts, clutch; not to mention taking the stock engine internals to the edge and having to start thinking about upgrading them (not meaning that you would need to upgrade them right away or that the motor will break anytime soon but it starts coming into play way sooner than say being on the Stg 1 kit with a good, safe tune)... It can get PRICEY!
Old 02-11-2013, 03:39 AM   #2204
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
I got this ^
everything else of course will be supporting that much power ( suspension, motor mounts, brakes, tires, clutch, oil cooler, etc )
the only spot I'd love to avoid putting apart is the FA20, which is a masterpiece
If AVO won't be able to recommend certain injector/fuel pump sizes and MAP sensor scale - seems I'll be digging that out myself
Old 02-11-2013, 03:47 AM   #2205
Sportsguy83
Drives: Limited BRZ
I'll let AVO answer that.
I can personally recommend you to look at what kits currently doing 10+ psi right here on the forum are doing for fuel upgrades and go from there. For MAP sensor you should get a 3 BAR sensor which is the most common.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
MSTiFK8R (02-11-2013)
Old 02-12-2013, 07:16 AM   #2206
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
What is the size of the down pipe on this kit?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 02-12-2013, 07:35 AM   #2207
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
afaik everything related from AVO is 2,5"
Old 02-12-2013, 12:00 PM   #2208
AVOturboworld
Here's the specifics of our Stage 2.0, which we've decided will be 7.5 psi setup that retains stock fueling.
3-bar MAP Sensor
7psi Actuator, or Boost Controller and standard 5psi Actuator
2.5" Cross over pipe
2.5" Stainless Steel Front Pipe with 5" metal cat
Stage 2.0 Base Map Tune with 8psi Fuel Cut
Final tuning for this package will be done in early March, after which we'll release these packages.
We feel this is a good base for setups going to 8~14psi, in that all you need to add after that is fueling and tuning.
The Following 8 Users Say Thank You to AVOturboworld For This Useful Post:
Alienate (02-12-2013), Apex Chase (02-14-2013), Brody602 (02-12-2013), BRZranger (02-12-2013), cmss2000 (02-13-2013), diss7 (02-13-2013), MSTiFK8R (02-13-2013), Sportsguy83 (02-12-2013)
Old 02-12-2013, 12:55 PM   #2209
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
3-bar MAP Sensor
Any price point or rough price set for the stage 2 kit yet? Will it be available for purchase directly from your website like the stage 1 kit. Do you have any rough performance figures yet? If you cannot provide the rough price and performance information at this time, when can we expect to read the information?
Thanks,
Brody
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 02-12-2013, 01:29 PM   #2210
AVOturboworld
Roughly $1400.00 range for the entire package including tune.
Yes, we'll have it available as a package, and as individual pieces. For instance, some people may have already gotten a cross-over and front pipe.
Roughly - and I do mean, roughly - between 250~270whp, 215-230 ft/lbs of torque depending on gas quality, elevation, dyno, etc. If it's for an automatic or manual will also change those figures. I won't have final figures until our Master Tuner, Ross, flies over from Japan in early March and we do another big road trip/road tune. The dyno tune doesn't take long, it's the road trip to verify the settings in various conditions that will take some time.
The Following 3 Users Say Thank You to AVOturboworld For This Useful Post:
Old 02-12-2013, 02:28 PM   #2211
Brody602
Drift King
Brody602's Avatar
Will the stage 2 be cheaper to buy stage 2 immediately as a complete package as opposed to stage 1 and then upgrading to stage 2?
Example:
Base turbo kit: $4400
Stage 2 add on: $1400
Total: 5800$
Complete Stage 2 Turbo kit: 5400$
Also, the manual generates more whp correct?
Thanks,
Brody
The Following User Says Thank You to Brody602 For This Useful Post:
cmss2000 (03-02-2013)
Old 02-12-2013, 03:22 PM   #2212
DriftEightSix
Pegasus White
Drives: 86
with the extra power from the stage 2; any recommendations for new clutch? or you will see what happens when tuning starts in march?
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
