AVOturboworld
Old 01-24-2013, 12:02 PM   #2129
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
EcuTek licenses are $250.
EcuTek Cables are $350.
Then you have shipping.
In America, yes. Unfortunately, I sell in other parts of the world as well, and EcuTek has different relationships and rules there.
AVOturboworld is offline   Reply With Quote
Old 01-24-2013, 12:04 PM   #2130
Visconti
Drives: 05 STi
How about my question ?
Visconti is offline   Reply With Quote
Old 01-24-2013, 12:09 PM   #2131
AVOturboworld
It includes everything as originally - turbo kit, fmic, mechanical oil pump, all hoses, fittings, and other pieces for the full bolt on. A stage 1 base map is included. The only difference is that ceramic coating of the exhaust manifold, the turbocharger, and the turbo discharge pipe is now included.
Old 01-24-2013, 12:19 PM   #2132
Visconti
Drives: 05 STi
Does the kit come with a map sensor ?
Old 01-24-2013, 12:23 PM   #2133
AVOturboworld
On the Stage 1 kit, no. It's designed for 5~7psi of operation, well within the threshold of the stock MAP sensor.
Old 01-24-2013, 01:38 PM   #2134
Visconti
Drives: 05 STi
Is that really safe?
The stock map sensor is only good for .5 bar of boost.
How are you suppose to put a boost cut on the tune?
Old 01-24-2013, 01:51 PM   #2135
AVOturboworld
There is no such thing as a .5 bar map sensor, we had that discussion with EcuTek already. So instead, you've got either a 1.5 bar or 2 bar MAP sensor - and this stock one is the same part number as a turbo FA20 MAP sensor.
Old 01-24-2013, 01:54 PM   #2136
Visconti
Drives: 05 STi
There is no such thing as a .5 bar map sensor, we had that discussion with EcuTek already. So instead, you've got either a 1 bar or 2 bar MAP sensor - and this stock one is the same part number as a turbo FA20 MAP sensor.
It's a 1.5 bar map sensor.. Can only see .5 bar of boost.
Again it's not a good idea to be sending basemaps that don't include a boost cut. It's impossible to have a useful boost cut with the factory map sensor ..
John
The Following User Says Thank You to Visconti For This Useful Post:
Batman (02-20-2013)
Old 01-24-2013, 01:54 PM   #2137
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
How does EcuTek execute a boost cut solely through software?
Old 01-24-2013, 01:55 PM   #2138
Visconti
Drives: 05 STi
How does EcuTek execute a boost cut through solely software?
With a custom racerom map..
Old 01-24-2013, 02:25 PM   #2139
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
We know the OEM provisions doesn't allow for it, particularly when the car is NA from the factory.
And if you wanted to get technical the stock map sensor won't read past .36 bar of boost based on what the ECUTek logs read. Again, this was designed as a NA car to begin with so why would Suby & Scion put anything more than they need to in the first place?
Right, in the custom racerom map, there's no "boost cut" limiter in the traditional sense but you can have several activation channels to retain a "safe" condition.
But I'm sure you already knew that.
So were you leading into a point or trying to make one since I believe they did mention it's just a base map that they supply and that they recommend customers to go to tuners to have it tuned for the fuel in their locale...
OR were you trying to say you're the only one that can provide for safety in all things FI? Not quite sure what you were getting at here.
Regards,
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
DriftEightSix (01-25-2013)
Old 01-24-2013, 02:41 PM   #2140
Visconti
Drives: 05 STi
Regards,
Im commenting on pricing because I'm curious and people are asking me questions I can't answer.
Those questions include map sensor questions... It's a good a valid question...
I think this is a good kit at a good price point but customers need to know if they're going to need additional hardware.
But clearly AVOWORLD and my self disagree of what the factory map sensor is good for, unless I misunderstood.
No I don't think I'm the only person that can tune* forced induction, many other vendors on here have proved that including AVO.
This wasn't meant to out anyone just real simply friendly questions.
Btw you only need one custom map for a safe boot cut.
So I don't want to drag this on but the factory map sensor is good for 4-5 psi at best, this kit or any kit should include a map sensor so a boost cut can be out in and the the customer can always datalog boost pressure. Can you do with out it? I guess.. But at least inform them so it's not a after thought
John
Old 01-24-2013, 03:07 PM   #2141
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I have a gauge that will flash if I go over my boost threshold or control something when that happens. I can log my boost just fine with it. I would agree that anyone installing this kit should definitely at least have a boost gauge to ensure they are getting the 5 psi they are supposed to and no more or less.
Old 01-24-2013, 05:07 PM   #2142
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Really any car with a turbo should have a boost gauge!
industrial is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
