#1639 |
Drives: 2003 Subaru Outback
Because they didnt mention any changes to the downpipe, im assuming the downpipe is the same for both stage 1 and 2. Realistically downpipe size at 2.5 will be good for more than most people will get out of this car. I talked to Paul and he said you can pretty much change anything on this kit and I will probably be opting for the 3" variation.
| The Following User Says Thank You to Tansey86 For This Useful Post: | Sportsguy83 (11-28-2012) |
#1640 |
Site Moderator
Drives: Stuff
Flywheel torque?
This isn't wheel torque fellas.. let's see the wheel torque. Peak torque really looks like about 219-220ftlbs, quite a bit different from 254..
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | ngabdala (11-28-2012) |
#1641 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I feel like there isn't enough transparency with this kit.
#1642 |
Drives: Whiteout FR-S
The screen says flywheel but that is at the wheels, i'm pretty sure Crawford's dyno says the same thing i don't know why it is confusing.
#1643 |
It says flywheel but it is actually wheel horsepower. This misconception has been covered several times I believe. Stage 1 is 230rwhp, do you really think they lost 10rwhp by upping the boost and finishing the exhaust?
#1644 | |
I Love custom Turbo kits
Drives: Limited BRZ
Just as a quick example, ![]() This is Perrin's chart. He already explained why it is as well as Crawford as well as AVO.
#1645 |
Functionally Retarded
Drives: LinkECU V6 MR2 - MKVII Golf R
Transparent enough?
[ame="http://www.youtube.com/watch?v=315BAOsePsk"]Drift-Office : AVO TurboWorld 6MT FRS Turbo Kit ~ Stage 1 - YouTube[/ame]
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
![]() I'm not really an asshole, but I play one on the internet. |
| The Following 2 Users Say Thank You to deucethemoose For This Useful Post: | gosaints420 (11-28-2012), Klar (11-28-2012) |
#1646 | |
Site Moderator
Drives: Stuff
It mathmatically does NOT work. If you know the RPM and either HP or TQ you can mathmatically determine the other, and the numbers DO NOT work in the posted graph. Example, if we have torque and RPM, we determine horsepower by: HP=TQ*RPM/5252. If we have HP and RPM, we determine torque by: TQ=5252*HP/RPM So, if we use the spot they have a cursor on around 3225rpm, they show basically 254lbft of torque and approx 137-138hp, but lets call it 140. If we do the math... HP=254*3225/5252 HP=156HP TQ=5252*140/3225 TQ=228lbft So if we use EITHER of their provided numbers at a set RPM, it simply DOES NOT work. You can pick any RPM, I did so with a few and the results were always the same - the graph doesn't make sense if both are wheel numbers. So take you pick, both are wheel and the graph is a lie or one is calculated somehow. Both can't be wheel and accurate. Unless the Dynopack changes the fundamental definition of the relationship between HP and TQ of course.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles Last edited by Dave-ROR; 11-28-2012 at 03:21 PM. Reason: oops fixed a bad typo. Meant "can" wrote "can't" |
#1647 | |
Drives: Limited BRZ
This has already been explained too. That Dyno graph shifts up the Torque side so that peak HP and peak TQ are in the same level line. Look at the torque scale on the left, you will see a different number then the HP scale on the right (this is the shifting). That is why they don't meet at 5252. The numbers are not Lying. It doesn't say 279 TQ and 279 HP, it says 254 TQ and 279 HP, they look like that only because of the torque shift up. And again, it was not intended to mislead, as AVO had already explained it.
#1648 | |
Site Moderator
Drives: Stuff
I'm not talking about where they cross, that's obvious. Look up how to determine HP from TQ and RPM, the scale of a dyno chart doesn't mean ANYTHING. They could have provided just HP and RPM in a chart and you can calculate the torque. The dyno itself doesn't even measure both, it calculates HP from TQ and RPM.
-Dave
#1649 |
This kit just hasn't been through legit testing . Don't get me wrong I want this kit. There's more to a kit than dyno charts.
Where's the application on a track or even on the street? The videos are vague and I'd hardly call a drive to SEMA and a drifting clip a real test.
#1650 | |
Drives: Limited BRZ
The only thing I can say is that it has been said since day one that Dyno chart is on Japan, and the Dyno chart to go by in the USA adds up and makes sense, the one that was done in Oregon for 230 HP and 198 TQ. Here's the USA Dyno chart:
#1651 |
Yeah i guess data logging 1500mile road trips through every type of weather and below sealevel to 6000ft isnt enough. Read the first post, this kit has more r&d than any other kit in my opinion
#1652 |
Site Moderator
Drives: Stuff
Hey, look at that, a quick check shows that math works.
Has nothing to do with the graph I was talking about from the JDM office though...
-Dave
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
