Old 05-31-2014, 01:20 AM   #561
steve99
Originally Posted by Dipstik-sportech View Post
OK so it still will not connect to my ECU. It just tries the says "can not connect to ECU possible faulty adapter or ignition not switched on". The adapter works fine in my other cars and the car is running while I'm attempting to connect so the ignition is on. Could it be something to do with ecutek not allowing it access?
The Frozen North
Probably a fair bet its due ecutek tune, ecutek can lock rom and the change structure of rom code to do the map switching and other fancy features, try it on a non ecutek or brzedit tuned rom and should be fine
Old 05-31-2014, 01:24 AM   #562
steve99
IAM is available in my datalogs:
http://datazap.me/u/stugray/za1ja00c...?log=0&data=41
The PIDs will be different for the various ROMs in our cars.
It is best to lookup the logcfg.txt for the tactrix datalogging for your individual ROM.
As for finding a direct knock counter that would be great.
The engine has two knock sensors. One on each head.
Maybe you could rig a buzzer or something to each of them and then log data while toggling the buzzer on and off. If there is a counter, you should see it incrementing in synch with the buzzer being on.
I doubt this will work as the obd port has a couple of different modes, standard pids can be called with torque but getting things like IAM and FLKC FBKC requires direct reading of ram addreses which i dont believe torque does.
Old 05-31-2014, 01:25 AM   #563
Dipstik-sportech
Dipstik-sportech's Avatar
There has to be people on here using these with an ecutek tune. The whole reason I bought this was to monitor oil temps on my boosted car.
The Frozen North
Old 05-31-2014, 01:34 AM   #564
steve99
The Frozen North
If you try your adapter on a stock tuned car and it works then at least you know your adapter works with brz 86, mine works and its just an ElCheapo elm327, im oft tuned though so no locks ect on ecu
Old 05-31-2014, 01:39 AM   #565
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
The Frozen North
I was using the slim elm327 Bluetooth reader with my na EcuTek tune without a problem most of the time using the custom pids for oil and fuel level - so I'm gonna bet its your particular elm adapter. Do you have access to another adapter you can try?
mikalem is offline   Reply With Quote
Old 05-31-2014, 01:58 AM   #566
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
The Frozen North
Using on an ecutek tune, no issues here
Decay107 is offline   Reply With Quote
Old 05-31-2014, 01:32 PM   #567
stugray
Drives: 2013 GBS BRZ Limited
I thought that is how we were getting the oil temp through the custom PIDs.
The Oil temp worked for me back when I tried the custom PID, but I havent tried it with anything lately since I got the tactrix working.
I suppose I could try it if I felt like taking two steps backwards
Old 05-31-2014, 05:55 PM   #568
steve99
Im pretty sure the pid is different to accessing a direct ram address pid is something the manufacturer supplys as part of their obligation to make standard parameters readable by anyone so only certian values are available as pid its also a lot slower pulling pids from ecu maybe twice a second for low number of parameters.
This is fine for temps and say iam but would be way to slow for usefull logging of fast changing engine parameters like fuel trims timing knock like flkc fbkc as these change so fast and can be very short duration
you need about 5 reads a second for good engine parameter logging, with tactrix reading direct ram addresses you will get 20 times as second with about 20 parameters
Old 06-02-2014, 09:17 AM   #569
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
Originally Posted by Cal3000 View Post
I used the code for the engine oil temp and for some reason when I use this custom PID, it works for about a minute, then can't locate the Blutooth anymore. When I don't have this custom PID, it works fine.
I might suggest trying a different OBD adapter. Which one are you using?
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 06-02-2014, 09:40 AM   #570
ML
ML's Avatar
Drives: 13 White MT FR-S
Originally Posted by developer View Post
Using some of the information I have gleaned from other posts I have come up with what looks like a very accurate reading of how much fuel is in the tank. It seems to be much more accurate than the default fuel percentage that is in Torque.
Torque PID setup for accurate fuel remaining.
PID: 2129
Long name: Fuel Remain (or whatever you want)
Short name: Fuel Remain (or whatever you want)
Minimum Value: 0.0
Maximum Value: 100.0
scale: x1
Unit: Gal
Equation: ((A*13.2)/100)
OBD Header: 7c0
The 0 in 7c0 is a zero not the letter O.
Warning: this is not as accurate with e85. It left me on the side of the road Saturday ha.
Old 06-05-2014, 01:10 AM   #571
Cal3000
Drives: Panda FR-S
I have the ELM327 mini. I think everyone uses this one. lol
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 06-05-2014, 01:20 AM   #572
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Here's mine with oil temp custom PID for oil temp. w/ ecutek tune SC flex-kit.
zoth is offline   Reply With Quote
Old 06-05-2014, 09:45 AM   #573
codesplice
codesplice's Avatar
To my understanding, ELM327 is only the chipset used in a wide variety of adapters, and there are a lot of Chinese ELM327 clones that may/may not work as well. Knowing the specific model of the adapter you're using may be helpful.
For reference, I've used Torque on my BRZ with the OBDLink LX and also with a Vgate ELM327 clone, and both seem to have worked just fine.
G+
Old 06-11-2014, 01:45 PM   #574
1Cor10:23
1Cor10:23's Avatar
Anyone have an A01C tactrix datalog? Cheers.
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
