Old 02-10-2013, 12:13 PM   #197
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
Is 220 the max oil temp you can display? Can it be raised to 300 or more for track duty?
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent!
Kamran is offline   Reply With Quote
Old 02-10-2013, 12:25 PM   #198
xwd
You should be able to raise it, it's just a setting.
If you are seeing 300 degrees on a track your engine is probably not going to last very long.
Old 02-10-2013, 01:22 PM   #199
2forme
Originally Posted by Snake View Post
I got really excited because Sony are releasing a head unit with a thing called Mirrorlink which duplicates your screen to the head unit. More investigation reveals it only works with a few phones one of which is my galaxy s3. I really want to play with one to make sure it works with this app. If someone gets hold of one of these before me, please let me know if it works for torque!
I'll just leave this here..
http://www.ft86club.com/forums/showthread.php?p=725368
Old 02-11-2013, 10:17 AM   #200
swift996
swift996's Avatar
Anyone know how to use the dyno mode? I'm interested in getting some baseline results to see the difference of some modifications.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-14-2013, 03:55 PM   #201
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Originally Posted by so26 View Post
Has anyone tried the 60-80mph timing feature in the torque pro app? I gave it a try the other day on a flat road and got 3.7s in 3rd gear, 5.0s in 4th, 6.6 in 5th and 8.0 in 6th. I'm curious what others are getting and what possible gains a tune will have on those numbers.
When i go back on e-85 i was going to test these out and see what i get. Ill try on pump gas and see what i get with a tune
brichard0625 is offline   Reply With Quote
Old 02-14-2013, 04:24 PM   #202
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
I can't see exceeding 220*C even on a track ... Remember the temp is in *C not *F so for you southern folk that is 430*F
pheoxs is offline   Reply With Quote
Old 02-14-2013, 05:00 PM   #203
jpit
Drives: Subaru BRZ
If your temp gets up to 220 C your engine will be toast. My torque app reads in fahrenheit (you can change it to Celsius) and varies between 180 to 205 in normal driving. At 260* you will probably go into limp mode. I had an oil cooler on my 370Z and despite having a 180* thermostat it rarely reached 170* driving around down which can be bad also.
jpit is offline   Reply With Quote
Old 02-15-2013, 03:07 AM   #204
Drofnum
Drives: CBS Subaru BRZ
430F is ridiculously high for oil temps. The sensor is set up as C but that would be converted just like any other sensor all of which are initially configured in C.
Drofnum is offline   Reply With Quote
Old 02-15-2013, 07:30 AM   #205
brichard0625
I tried to do some runs on a somewhat flat road. it was a little wet on the road but not sure if it wud affect the numbers that much.
3rd gear 3.7
4th gear 4.8
5th 6.7
6th 9.3(not sure why it took that long)
My girlfriend put hess gas in my car i usually go shell or sunoco so im not sure if im running on crappy gas but doing the pull in 6th felt super sluggish
Old 02-16-2013, 09:28 AM   #206
so26
Drives: Raven FR-S 6MT
3rd gear 3.7
4th gear 4.8
5th 6.7
At the time of my runs I had BP gas in the car with a fuel level between 1/2 to 1/4. Also I dropped my speed a couple of mph below 60 before flooring it.
so26 is offline   Reply With Quote
Old 02-16-2013, 10:56 AM   #207
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
I am curious to hear others impressions of logging speed using an elm bluetooth adapter and android s3. I have logging interval set to .2 and it is common for me to see 3-4 duplicate values in a row in the logfile for speed and rpm. Is this as fast as these two sensors update? The duplicates skew virtual dyno runs a bit.
pixel67 is offline   Reply With Quote
Old 02-17-2013, 02:31 PM   #208
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
Anyone has any recommendation on iPhone app?
I've been researching the few apps that are available, but their customer reviews are either bad or very limited if at all. I'd like to be able to input the oil temp, and I'm not sure if any of them allow customization. Any input, with first hand experience would be appreciated.
Old 02-17-2013, 03:54 PM   #209
swift996
swift996's Avatar
I just picked up a USB adapter to log on my laptop. I'm getting too many errors from the bluetooth (errors in the datalogging). I'll continue to run Torque here and there via bluetooth but I want to get some more accurate reads for tuning purposes.
Old 02-17-2013, 04:11 PM   #210
xwd
I'm using an OBDLink MX and have had good luck with logging both with speed and accuracy, Torque even supports a specific mode for it. However it's not cheap compared to the other ELM BT adapters.
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
