#589 |
Drives: 2014 Scion FR-S
Can't get OBD2 Bluetooth adapter to work for the life of me. Tried with my previous adapter and then purchased one recommended here from Amazon.I even tried a USB one I had lying around. Torque tells me it can connect to adapter but adapter can't talk to Ecu. I've tried on Android head unit and on my phone actually with same results.
Used to work with previous adapter phone but stooped at some point. I have Open Flash Tablet and just flashed Stage 1 tune again to make sure there's nothing wrong with the port. Any ideas? How can I tell if if there is problem with port? Using tiny blue Bluetooth dongle from Amazon. Sent from my GT-N5110 using Tapatalk |
| The Following User Says Thank You to DC2R For This Useful Post: | Dipstik-sportech (07-02-2014) |
#590 | |
#591 |
Exact same issue I'm having. If it was pin length then why is the adapter getting power but no signal from the ECU?
#592 |
#593 |
EcuTek plug works, other scanners work. Just the dongle won't connect
#594 |
#595 |
Well we don't have pepboys up here but yes the generic ones work
#596 |
#597 | |
Sent from my SM-N900T using Tapatalk |
#598 | ||
Drives: Subaru BRZ
Looks like it is caused by the Torque application trying to discover the protocol expected by the ECU using a scan, and this scan causing the ECU to bork. If you go into the profile you set up for your vehicle and scroll to the bottom, there is a drop down menu where you can set the "Preferred OBD2 Protocol." See the attached picture. In my case--and I'd expect it to be the same for all BRZs--it was ISO15765-4 CAN (11 bit, 500k baud). While connected to the adapter you can go to the "Adapter Status" button on the home screen and you can confirm the setting there. I don't think it would vary based on adapter, but check your car to be sure. After changing this setting I haven't had a reoccurrence in a couple days of testing. I'd be interested in hearing if this works for others and if the settings are identical on an FR-S. |
#599 | |
Drives: Panda FR-S
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
| The Following User Says Thank You to Cal3000 For This Useful Post: | DC2R (07-05-2014) |
#600 | |
#601 |
Drives: 2013 FR-S Asphalt
OFFICIAL Torque Android app PID/Misc Thread
OBD2 ports use a standard, if the adapter you are using doesn't fit, don't modify it. You can literally fry your ECU by causing a short. Some OBD2 adapters are just subpar and have connectivity issues. It could be as simple as shoddy soldering of components. I would say it's never worth a $1800 ECU to use a $9 obd2/elm adapter.
#602 |
Drives: Toyota GT86 SWP
Is it possible to use the adresses described in this thread in Torque?
http://www.ft86club.com/forums/showthread.php?t=56432 For example: E_IAM_1byteExtExt_E96 FFF89B67 E_IAM_4byteExt_E31 FFF816F4 |
| Tags |
| android, app, boost, gauges, torque |
| Torque app for android question | Brody602 | Electronics | Audio | NAV | Infotainment | 8 | 01-08-2015 05:53 PM |
| Torque for Android | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-23-2012 12:05 AM |
| Android Torque app questions | Craig | Engine, Exhaust, Transmission | 1 | 11-12-2012 05:14 PM |
| Bluetooth OBD scanner and Android Torque - less than 25 shipped | whataboutbob | Engine, Exhaust, Transmission | 7 | 10-20-2012 02:15 PM |
| Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 09:23 PM |
