Old 06-12-2013, 08:29 PM   #155
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Originally Posted by Ellesedil View Post
I picked up my caps from the anodizing place. They feel a little tacky/sticky to the touch, but look great otherwise. Is this normal? Or should they have been sealed? And will there be any issues if I attempt to stick some vinyl graphics onto them?
Can you provide details on the process you had done for the black caps?
I'm not a coating expert but here is some info I found:
Virtually all anodized, unsealed parts feel sticky to some degree or another. Probably the best example of this is on parts with relatively thick, hard anodic coatings. Many years ago in some shops this was often used to judge whether or not the anodic coating was sealed (obviously, before the days of QS 9000). If it felt "sticky," it wasn't sealed. Good sealing will eliminate the stickiness. However, many hard anodized coatings are purposely not sealed in order to preserve maximum coating hardness. The sticky feel does not affect the quality of the hard anodic coating in any way.
Contacting your anodizer may be your best bet.
kask2_6.0 is offline   Reply With Quote
Old 06-12-2013, 09:05 PM   #156
Ellesedil
Drives: 2012 Subaru Legacy GT
Yep, found that exact info. I was more curious as to how the black anodized caps turned out. Were they a bit tacky to the touch?
Ellesedil is offline   Reply With Quote
Old 06-12-2013, 10:20 PM   #157
Foobar
SLO NO MO
Foobar's Avatar
Not at all. It's steel smooth.
Sent from my Nexus 4 using Tapatalk 2
Old 06-13-2013, 02:49 PM   #158
Ellesedil
So, this has been an interesting experience. The anodizing I had done was a "hard coat (type III)" anodize. It is the most durable, but also the thickest anodizing process. After talking to my anodizer, he stated that sealing a hard coat anodized part would weaken the durability of the anodization a bit.
Since the tacky feeling is the only downside I've noticed, and these will live in a set of wheels on my car, I'm going to leave them as-is. He suggested wiping them down which I might do today, but I'm not worried if the tacky feeling remains.
Only thing left to figure out is if I want to put some sort of clear coat on them, what product that should be, and if I want to do it before or after I stick vinyl on them.
Old 06-13-2013, 02:51 PM   #159
Foobar
SLO NO MO
Foobar's Avatar
If you do it at all, I'd probably suggest doing it after you stick your vinyl on so that it is also protected.
Old 06-13-2013, 02:59 PM   #160
Ellesedil
Yep, I'm leaning that way. The only downside is that it makes the vinyl a little more permanent and the design I'm getting is Legacy specific (but also fairly obscure). So if I want to sell my 18x8.5 wheels to say... a BRZ owner, it might be problematic for the new owner.
But I'm not so sure I care.
Old 06-14-2013, 07:00 AM   #161
colHolm
Default User Title
colHolm's Avatar
I'm leaving the bare aluminum for now. It sort of reflects the colour of the wheel and it isn't immediately noticeable that they don't quite match...
Thanks Kask!
colHolm is offline   Reply With Quote
The Following User Says Thank You to colHolm For This Useful Post:
kask2_6.0 (07-16-2013)
Old 07-14-2013, 08:40 AM   #162
JSUB
JSUB's Avatar
Drives: 2026 BRZ tS coming
I agree as ColHolm said:
"I'm leaving the bare aluminum for now. It sort of reflects the colour of the wheel and it isn't immediately noticeable that they don't quite match...
Thanks Kask! "
JSUB is offline   Reply With Quote
The Following User Says Thank You to JSUB For This Useful Post:
kask2_6.0 (07-15-2013)
Old 07-15-2013, 11:22 PM   #163
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
Just thought I'd throw in my set:
17x8, 17x9 with square 235/40 nitto tires.
Lowered on Swift springs (BRZ spec)
Wilwood 6 piston front kit
Tom's rear lights
No flaming the center cap stickers!
hamlet is offline   Reply With Quote
The Following User Says Thank You to hamlet For This Useful Post:
Old 07-19-2013, 10:04 PM   #164
mugenbb6
Drives: subaru
Any more available? I would like to get a set in black.
mugenbb6 is offline   Reply With Quote
Old 08-07-2013, 09:23 PM   #165
3 pedals n a stick
Drives: white out frs
I would also like to know if there's any more still available?
3 pedals n a stick is offline   Reply With Quote
Old 08-07-2013, 10:01 PM   #166
KONVERTER
KONVERTER's Avatar
me3
KONVERTER is offline   Reply With Quote
Old 08-07-2013, 10:38 PM   #167
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Unfortunately I don't have any more
Old 12-04-2013, 04:34 PM   #168
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
If you ever make these again please let us know. It's abit mind blowing that weds doesent make these on their own to buy???
Watanabe/ROTA RKR for 86 Interest List ap1mikeo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 116 04-07-2017 06:31 AM
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
2013 TOYOTA FT86 SCION FR-S SUBARU BRZ CENTER CONSOLE CUP HOLDER RED TRIM RING zetaproducts.net Interior Parts (Incl. Lighting) 1 12-13-2012 02:30 PM
Work, Rays, Volk, Vossen, Stance, Advan, Wedsport, XXR Wheels and More !!!! IslandImportPerformance Wheels and Tires 1 06-18-2012 07:38 PM
