Old 03-04-2014, 09:03 PM   #435
utekineir
blowhard
Drives: frs, project forester
My grill / bumper is on without trimming. But it did take a bit of effort to get the plugs lined up
utekineir is offline   Reply With Quote
Old 03-04-2014, 09:04 PM   #436
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Well why don't you just rub it in everyone's faces :P
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 03-04-2014, 09:18 PM   #437
captain_jack
captain_jack's Avatar
Well so is mine but there is a slight gap between the edges by the wheel well and side makers. There always was but it's about a 1/16 more then before.
may the schwartz be with you....
Old 03-04-2014, 10:25 PM   #438
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Same here
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 03-04-2014, 11:45 PM   #439
captain_jack
Well crap, finally got my oil today and after adding a bit to make sure i was full. I start it up and of coarse i wasn't low at all.... Now im over filled... Oh well guess i will get the vacum pump out tomorrow and remove some. Got the leak fixed though so thumbs up on that. I always have weirdest bad luck.
sent from your mom
Old 03-04-2014, 11:53 PM   #440
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Each time I check the unicorn piss (aka Rotrex oil/fluid) it seems to be on the top end of the dip stick closer to the max level. I have about two inches left in the bottle. Didn't shorten any of the hoses provided with the kit so I'm thinking it should hold capacity? Where was your leak at?
mit_peid is offline   Reply With Quote
Old 03-05-2014, 12:33 AM   #441
captain_jack
Well for some reason the cooler to resovoir was like 12" short but was the 34 inches as stated in kit. Every other hose was spot on. I went and bought more hose and the used that. I had a leak at the banjo fitting itself as i had it cocked enough that the hose rested on the resovoir when i tightened the fitting. That caused the leak. I fixed that tonight and repositioned both to be off of the resovoir.
sent from your mom
Old 03-05-2014, 10:12 AM   #442
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Any of you guys know who, other than Nameless, is making 3" OP and FP? I'm having a hard time finding something to mate up the the Tomei 80.
digital_assassin is offline   Reply With Quote
Old 03-05-2014, 10:35 AM   #443
captain_jack
Go to a good local exhaust shop they can take your factory op and make a new one in 3". We did that here and all said and done it was like 100$ I mean for here in az we didn't need stainless so we used standard exhaust tubing. Easy peasey, just my 2 cents
Old 03-05-2014, 02:19 PM   #444
captain_jack
Originally Posted by vgi View Post
could someone pls post a pic where exactly is an issue with FRS grill / bumper?
It's the mesh that's the issue as far as I can tell.it causes the sides to not mate up completely.it's small like I said and completely livable. Although it would be nice to fix it.
Old 03-05-2014, 03:11 PM   #445
mit_peid
Boosted Noob
mit_peid's Avatar
I can try to take a few photos tonight. The FRS grill (not sure if this is the same on the BRZ) is up against the sides of the bottom of the IC and piping. There wouldn't be too much effort to Dremel/trim (maybe 1/4"), but it would take a bit of effort to get things to fit better.
Old 03-05-2014, 04:58 PM   #446
utekineir
blowhard
Unrelated to grill fit
Did you guys remove the black plastic peice between the intake and condenser/radiator or leave it on?
Old 03-05-2014, 05:20 PM   #447
captain_jack
Had to come out to put for the filter tube to go in.I could have put it back on if I wanted to take the time to cut it around the intake tube.
Old 03-05-2014, 10:44 PM   #448
mit_peid
Boosted Noob
mit_peid's Avatar
If you're talking about this piece, I was able to put it on after the tube/air filter was on.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
