Old 01-12-2016, 08:23 PM   #3697
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by Apoc View Post
Another method to test belt tension is to twist it in the center of the longest section. If you can't twist it 90 degrees it's too tight. If it twists more than 90 degrees tighten it up a bit.
This has worked for me in the past
Freeman is offline   Reply With Quote
Old 01-13-2016, 06:27 PM   #3698
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by rj101592 View Post
The cellphone Gates app, not sure of any other methods other than keeping it tightened... just not having any luck. Considering selling the kit and going turbo
Half a belt twist, just like what was posted earlier. I've broken two belts too. Once was during initial install. 21mm rule was way too loose. the second time, my pulley bearings were shot and caused uneven wear on the belt since the pulleys were moving. Now on the third belt for months and no problems.
I am sorry you are having trouble, at least you can say their customer service is awesome. CJ at Group A you are the man!!!
pgranberg11 is offline   Reply With Quote
Old 01-13-2016, 06:29 PM   #3699
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by Barbas View Post
So how often are you suppose clean air filter and switch the oil on the kit? Thanks in advance.
Not sure to be honest for the air filter. I guess when you think it looks dirty enough? lol
The oil said it was good to last two years. I forget what mileage though. I plan on changing mine once a year just because I track. Probably overkill, but rather play safe than sorry.
Old 01-13-2016, 08:49 PM   #3700
rj101592
Drives: 2013 scion frs
The 90 degree belt method worked for you as well?
And thanks guys
rj101592 is offline   Reply With Quote
Old 01-13-2016, 10:56 PM   #3701
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Just tested mine and the 90 degree twist holds true with my current tension. Might be the trick...
nlowell is offline   Reply With Quote
Old 01-14-2016, 03:19 AM   #3702
leomkay
Drives: Toyota 86
Is the belt for the c38 kit still TP1200-8MGT-20? If not which one is it?
leomkay is offline   Reply With Quote
Old 01-14-2016, 01:30 PM   #3703
rj101592
I did the 90 degree method and noticed the whine is a lot more louder when driving and idling... Is that normal?
Old 01-14-2016, 01:32 PM   #3704
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
Yeah, if you had it too loose before, there will definitely be a difference in noise level
Sent from my Nexus 6 using Tapatalk
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
Old 01-14-2016, 01:54 PM   #3705
rj101592
Just called and spoke to CJ, definitely a great help. He did confirm that the increase in whine noise is very normal. Lets hope for goodluck this go around! Lol
Old 01-14-2016, 04:31 PM   #3706
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Never had a belt snap on me either. 20000 miles with the c38 installed and lots of pulls. I wanted to mention however that the bearings in the pulleys went bad from running the charger with too loose of a belt. I knew the belt was a little loose but didn't expect the pulleys to go. Luckily I still have an extra set. I was surprised to see how much knock the engine was reading because of it, and how much power I lost.
D-VO is offline   Reply With Quote
Old 01-14-2016, 04:53 PM   #3707
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
hmm that's an interesting thing about knock and the pulleys. it makes since though since knock could be multiple things, including abnormal noises that the pulley bearings could make.
Old 01-14-2016, 06:35 PM   #3708
rj101592
Would you guys consider running e85 with the c30 kit? or is it not worth the gains
Old 01-14-2016, 06:36 PM   #3709
Freeman
Freeman's Avatar
If I had E85 here that's all I would run
Old 01-14-2016, 06:41 PM   #3710
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
I was just about to call up CJ and discuss this exact thing with him. Going e85 on c30 or upgrade to c38
KW V3
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
