Old 02-07-2015, 01:01 AM   #2941
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Originally Posted by SPCorBUST View Post
Are you on C30 + 91? Then maybe you can barely tell since the hp gain is low anyway. The power drop for me at that time was something like 30% of the power, probably not even that much since I'd have to redline to make that number.
I've done NA w/ e85 (currently doing that while preparing and installing other mods) and a broken belt was nowhere near right now. Not even close...
EDIT: I see you're running the same FlexFuel kit on E85 close to 100% of the time. Its surprising that you feel they're the same.
Oh, no... not the same feeling at all. Just like I said normal City driving, so no pedal to the metal or high RPM's. So at low RPM's and just doing my regular in City routine it's fine. Of course if I try spirited driving then I do feel that I'm not boosted. What my point is that I have a normal working non-boosted car without a belt. If that makes sense. Limp could mean a lot of things. But yes it's not as much fun driving not boosted.
If you mean limp by not having that much WHP then I agree with you.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 02-07-2015, 10:16 PM   #2942
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I had a belt problem as well, but not the Kraftwerks S/C belt. My accessory belt fell off after a hard shift into third. See my other post here. http://www.ft86club.com/forums/showthread.php?t=81319
My car overheated cause the water pump stopped working. I towed my car home via AAA. The next morning I found that one of the OEM idler pulleys seized (the one to the right of the crank).
I have a new part coming on Tuesday. Hopefully replacing the seized pulley will fix the problem. Hoping it won't be too much of a pain in the ass to remove the KW/Rotrex assembly to get at the idler pulley.
mit_peid is offline   Reply With Quote
Old 02-08-2015, 07:22 PM   #2943
zoth
zoth's Avatar
Attachment 102074
I will be replacing my accessory belt as well when I install the new SC belt & pulley's. Are there any better accessory belt than OEM out there?
Old 02-08-2015, 08:15 PM   #2944
mit_peid
Boosted Noob
mit_peid's Avatar
I'm only aware of one belt claiming being higher quality than OEM - Gates Racing Blue http://www.rallysportdirect.com/Gate...tine-Belt-Blue
I just went with another OEM belt (the OEM one I had was a Mitsubishi) since I don't think it was a problem with the belt itself.
Old 02-08-2015, 08:51 PM   #2945
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I'm running the gates blue belt. It appears to be beefier than stock.
post_break is offline   Reply With Quote
Old 02-08-2015, 10:51 PM   #2946
zoth
zoth's Avatar
I wonder if any one have a good guide in replacing both belts? @KraftWerks
Old 02-09-2015, 08:40 AM   #2947
post_break
post_break's Avatar
I've heard someone say you can do the blower belt without taking the blower off. But the accessory belt needed the blower to come off. I think it's 3 or 4 bolts. Just get a buddy to hold the blower in his hands and slip the belt around. Obviously have the other belt off first.
Old 02-09-2015, 04:25 PM   #2948
Barbas
Drives: 2013 whiteout Frs
To clamp the evap hoses under the intake manifold which route did you guys take? Remove intake manifold or remove the ac compressor.
Barbas is offline   Reply With Quote
Old 02-09-2015, 04:29 PM   #2949
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Remove the AC compressor
Freeman is offline   Reply With Quote
Old 02-09-2015, 04:30 PM   #2950
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
I took the squeezing random tools in from the front and back of the manifold, and cursing a lot route. I needed to clamp mine after the SC was already installed, so didn't want to remove anything.
If you're just now installing the kit, I'd go the a/c compressor route
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
Old 02-09-2015, 04:32 PM   #2951
zoth
zoth's Avatar
Quote from CJ about being able to drive the car without the SC belt.
"Yeah, just stay below 4000 or so to be safe."
Regards,
CJ Weidl
Old 02-09-2015, 04:49 PM   #2952
Barbas
I already have it installed so we can't take the ac compressor off.
Old 02-09-2015, 04:51 PM   #2953
Freeman
Freeman's Avatar
Kinda narrows down your options then.
Old 02-09-2015, 04:57 PM   #2954
post_break
post_break's Avatar
Remove belt, remove most bolts that get in the way. You can do it without removing the SC plate I believe. I think I only took the SC off to do a belt.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
