#491 | |
aeiou
Drives: WRB BRZ
If you lower it to 2-3 mm above the brake pedal, that should still be fine, right? Did it by spinning the clevis.
I haven't heard any chatter yet, knock on wood. Cruise control engages/disengages like normal, car doesn't move in 1st gear with pedal to the floor and revs applied.
#492 |
Drives: 2014 WRB BRZ Limited
I've put ~5k miles on my lowered clutch (2-3mm above break pedal) and haven't had any issues. Any idea how quickly after doing this mod people were having issues?
If you're like me and only read the last page of long threads, be warned: This mod is incredible. You won't ever go back to stock
#493 |
Drives: 2014 WRB Bravo Romeo Zulu
#494 | |
aeiou
Drives: WRB BRZ
| The Following User Says Thank You to unsurety For This Useful Post: | xxBrun0xx (07-26-2014) |
#495 | |
Boosted
Drives: Sideways
If you've got whistling and chirping or spinning grinding noises it's time to replace it.
#496 |
Drives: 2014 FR-S
I Just did this adjustment today. Amazing what a quarter turn does.
#497 | |
Drives: BRZ SWP 14
Here is a picture of the under body to use for reference: ![]() Going to lift my car just to see if mine is engaging or not because my clutch pedal is adjusted a little lower than brake |
#498 |
Drives: 2014 FR-S
So, behind the aluminum panel under the engine, there is a plastic one that has the exhaust coming out of it. Remove that and you will expose the underside of the transmission. There are open "vents" on the bell housing that you can look in to see the clutch assembly.
#499 | |
Boosted
Drives: Sideways
There are actually a few things you can see inside of there including the clutch assembly and the throwout bearing if you can see it at the right angle. If it's difficult to see or you aren't entirely sure what you are looking for, have a friend in the driver seat pushing the clutch pedal down and up repeatedly until you can see how the system works. The throwout bearing is attached to the clutch fork (inside the trans) which is the big black metal piece that the clutch master & slave is pushing back and forth (at the very top of the transmission) to disengage and engage the clutch. The throwout looks like this, probably not the same colors though after thousands of miles of usage.
| The Following User Says Thank You to Synack For This Useful Post: | aristo (07-28-2014) |
#500 |
Drives: '13 10 Series FRS #1203
Just did this.
My biggest issue with the clutch was that everytime I felt I had it perfect, its like my muscle memory decided LOL not anymore you dont and I would disengage is sloppily and sometimes slip it. I've never had this issue on any other of my standard vehicles. I did the initial just below the brake pedal, and while I really thought the engagement made for a much smoother shift especially when heel-toeing, there was a slight "slop" for the first little bit that I did not like. While it did not affect how the car drove, everytime i put my foot on the pedal, or took it off the pedal i could feel this "slop" and it drove me nuts. Now I have it just in line with the brake pedal and im getting used to that. |
#501 |
Drives: 2013 Asphalt FRS
So, i just adjust my clutch pedal today and put it to the same position as my brake and its feel so much better. Pedal are lower and no need to push gas to roll forward and reverse. Didn't smell any burnt for 20 mile ride, shifting are good, and no grinding while shifting to all gears. Seem like there are no problem so far.
Is there any other things i should be noticing or be aware of while testing the adjustment? |
#502 | |
| The Following User Says Thank You to xxBrun0xx For This Useful Post: | benlaz88 (08-06-2014) |
#503 |
Drives: BRZ SWP 14
DIY - Easy clutch grab adjustment (~10 mins)
Just to make sure - what exactly is free play?
When you mean free play at the bottom is it the gap before the clutch begins to slip and engage the gear? Likewise what would free play at the top be? The travel that occurs before the clutch disengages? Thanks |
#504 | |
Bottom freeplay = "Clutch Engaged" section 0 in this section, the clutch plate is completely disconnected from the flywheel, so regardless of how much the clutch plate is forced to move, the engine is spinning independently from the transmission Think of the freeplay as safeties. Those areas are put in to ensure that all clutch pedals can be set to the same height regardless of manufacturing tolerances on the clutch plate itself. By lowering the pedal, you're effectively removing some of that safety margin, which is okay, as long as you leave a little bit. You just don't have to leave as much as the stock car comes with. Correct me if I'm wrong, but I believe that over time, due to the clutch wearing, the section between "clutch starts engaging" and "Clutch fully engaged" will move downward towards the floor, requiring you to adjust the pedal upwards as needed to maintain your "Clutch Engaged" safety region.
| The Following User Says Thank You to xxBrun0xx For This Useful Post: | aristo (08-09-2014) |
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
