Koji_Online
Old 04-29-2014, 01:35 AM   #463
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by aristo View Post
Bump with a question: Do you guys think it would be a good idea to adjust the clutch back to normal height before getting it checked out for service by the techs at a dealer?
Would they care that the height of engagement was lowered at all? (Because it is quite a significant difference after changing it)
Great 'mod' for the car by the way.. To anyone who is still hesitant or putting off doing it, go do it! It's very easy as long as you follow the video guide.
No service tech is gonna bother going down there with a ruler to measure that shit -_- nor can they prove that it didn't come like that from the factory
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 05-01-2014, 09:04 PM   #464
brokedrifter
Drives: Scion FR-S white
Did this mod today and wow wow wow! So much better then stock!
brokedrifter is offline   Reply With Quote
Old 05-03-2014, 05:24 PM   #465
Churnobyl
Churnobyl's Avatar
Drives: 2014 Limited Subaru BRZ DGM
Done this AM. Set it juuuust above the brake. Drove it to the next city and back, spirited. Just incredible the difference it makes. Thanks.
Churnobyl is offline   Reply With Quote
Old 05-04-2014, 05:42 AM   #466
ikovacs
ikovacs's Avatar
Drives: Toyota GT86
Did the adjustment today and ended up setting the clutch pedal slightly above the brake pedal, first tried to set it below the brake pedal as per instructions but I found that to be too direct for my taste, now I can slowly ease of the clutch pedal and move without any gas input, just like in my previous car ( also a toyota ) and all the manuals before that. Made a big difference, this will make reversing, slow traffic, balancing on the clutch on a slight incline, etc... much easier. Thank you !
ikovacs is offline   Reply With Quote
Old 05-08-2014, 02:54 AM   #467
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
I'm sorry if this has been posted but i couldnt find it in 150 first posts (over 450). Am i the only one who has about 1 inch of "no resistance whatsoever" before the clutch kicks on depress ? It seems to be even worse on startup (i guess since fluids are colder) because i even have to pull my clutch with the top of my foot to see the gear indicator/activate the cruise control. Is it possible to i put my clutch too low ?
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 05-08-2014, 07:42 PM   #468
aristo
aristo's Avatar
Drives: BRZ SWP 14
It is normal to have a softer/mushier pedal with less resistance at the top after doing this adjustment
And the gear indicator not showing up might simply mean you didn't adjust the indicator to register lower along with lowering the clutch pedal.
Here is a picture of the gear indicator white switch: http://i1067.photobucket.com/albums/...g?t=1339388676
It is not supposed to look like that in the picture - the large white 'pad' is supposed to be lined up almost flush with the silver bolt. (a little tiny bit of white should show to make sure the selector is not pushing your clutch down)
aristo is offline   Reply With Quote
Old 05-10-2014, 01:16 PM   #469
LFA.Baby
LFA.Baby's Avatar
Drives: Frs 2014 MT whiteout
Just did it and I am not sure if the bolt behind the U shape bracket is tight enough. I did use the 12mm wrench to tightening it, but it slipped on the bolt.. I don't think I mess up the bolt, so I used my fingers to turn it tight, if it doesn't turn no more (with fingers force) I guess it is tight enough.
[[ ]=(86)=[ ]]
instagram - afong.86
Automotive Art
Commission me! for Virtual Tuning & Design
LFA.Baby is offline   Reply With Quote
Old 05-10-2014, 06:35 PM   #470
aristo
aristo's Avatar
Drives: BRZ SWP 14
Should check it once a while to make sure it does not start loosening on you
And to make the 12mm tightening much easier, you need to use a very short wrench (like less than 5 inches) to make sure it's grabbing correctly because there is not much room for positioning back there
Old 05-10-2014, 11:04 PM   #471
LFA.Baby
LFA.Baby's Avatar
My 12mm is short and I had room to move it, but still couldn't grab the bolt good enough.. anyways the drive is a lot smoother now, will keep an eye on the bolt. I am just scare that if I do adjustment again I will destroy the bolt because the 12mm slip on it when I turn. It was already like that when I unbolt it, but I still manage to loosen it.
[[ ]=(86)=[ ]]
Automotive Art
Old 06-02-2014, 11:05 AM   #472
kbye
kbye's Avatar
Drives: 2014 FR-S
How is everyone's clutch doing after this adjustment? I adjusted my clutch pedal a couple mm higher than my brake, but I'm paranoid that even though I'm fully depressing the clutch, I might not be releasing it completely.
edit: just read through a few of the comments in this thread... good information. I'm going to do the checks to test for fully dis-engaging clutch as recommended by some members.
kbye is offline   Reply With Quote
Old 06-02-2014, 11:50 AM   #473
1Cor10:23
1Cor10:23's Avatar
I'm slightly below the brake, I would say you're completely fine. Easy check is to put it into gear (while stepping on clutch) - first time around you'll feel the transmission kick back a bit - take it back into neutral (still on the clutch) and back into gear - should be seamless, and will not have the transmission 'clunk' from the first time. If you left off the clutch then back into gear, it will 'clunk' again.
Old 06-17-2014, 06:44 PM   #474
JohnAyySays
JohnAyySays's Avatar
Drives: Scion FR-S Whiteout
Just did this mod and was really surprised and how my shifting improved! What I noticed is if I slowly let off the clutch and add no gas the car automatically starts going without any gas needed. This is also the same for reverse as well. I know before with my old clutch position it would stall. Is this normal?
JohnAyySays is offline   Reply With Quote
Old 06-18-2014, 06:55 AM   #475
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Depends on where the clutch is when the car starts to move. If it's moving right as your foot is coming off the ground, that means you're never fully disengaging the clutch and the pedal should be raised. If you've got maybe .5"-1" of travel before the car starts to move, you should be fine.
As far as moving without stalling, do you have any power mods? I'm completely stock and my car always seems like it's going to stall if I let off slowly with no throttle.
xxBrun0xx is offline   Reply With Quote
Old 06-23-2014, 05:06 PM   #476
BRZrkr
Drives: 2017 BRZ PP
Recently tried this mod and very happy with new clutch engagement point. Question though: I initially set the pedal too low, and while there was zero grinding (per the OP's test for success), I was immediately able to smell burnt friction disk (just down the block for a test drive). I adjusted the pedal up (just above brake pedal) and seemingly, problem solved. Occasionally though, I feel like I get the slightest whiff of friction material after I park the car. Might be in my head though, or the brakes, or any number of things. Anyone else experience this? Mechanically, if the clutch didn't fully disengage because of the pedal being set too low, I can't see how the clutch would be slipping, resulting in burnt disc? Am I overthinking this, or not thinking enough?
BRZrkr is offline   Reply With Quote
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
