Old 02-08-2016, 11:23 AM   #281
VeilSide
Drives: GT86
I looked at my A00G definition file and the corresponding memory addresses do not match the ones given here. This will result in non functional tables... and most likely a bricked ECU if I would try to flash it.
Does someone have the correct memory locations for the tables for a A00G cal ID?
VeilSide is offline   Reply With Quote
Old 02-08-2016, 04:58 PM   #282
Kodename47
Kodename47's Avatar
Drives: UK GT86
A genuine A00G or for OFT?
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-08-2016, 05:21 PM   #283
VeilSide
Drives: GT86
I am running a modified OFT Stg2 UEL A00G...
Old 02-08-2016, 10:23 PM   #284
steve99
OFT A00G roms are actually A01G roms internally with calid adjusted.
you need to use matching OFT def to edit OFT roms
Old 02-09-2016, 12:01 PM   #285
VeilSide
Drives: GT86
I think the calid is not the problem here. My ECU is an A00G so OFT lets me only flash A00G roms. I know that OFT uses newer version of the FW internally. But files are exactly the same content-wise (except checksums).
What I need are the locations of these 2 tables in my G rom, as the following addresses do not match it.
Old 02-09-2016, 02:08 PM   #286
Kodename47
Kodename47's Avatar
Drives: UK GT86
They use A01G ROMs for all G series CalIDs. You need A01G ROM addresses, or you can download these Kodename47 G Series OFT Defs.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-09-2016, 02:34 PM   #287
VeilSide
Drives: GT86
After some searching I just tried to change the calid on the posted defs...
https://raw.githubusercontent.com/TD...R_ZA1JA00G.xml ... it worked
From a difference analysis I saw that the "ecuid" has changed. Could this be a problem?
And, is this definition otherwise compatible with current OTS 2.072 tunes?
Just to be absolutely sure...
Old 02-09-2016, 02:38 PM   #288
VeilSide
Drives: GT86
Ah, as it looks the ecuid is the difference between A00G and A01G roms...
So I need to use the A01G definition for my "pseudo" A00G tune.
Thank you ;o)
Old 02-09-2016, 03:57 PM   #289
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thank you ;o)
Yes, or just use the A00G definition in the zip file I linked to above. It'll work straight away
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-08-2016, 07:48 PM   #290
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
You need a '-' minus sign in your post start ignition timing you got +4 instead of -4 :-)
your post start maf corrections look a bit agressive, it might have problems , after start on rearly cold days, not sure it never gets cold where I am.
try the ones below from wayno,s thread
do you need it to idle at 800 ?? when its fully warmed up, im back down to 700 .
thank you. !
it works great .
me and neighborhood are happy with this quiet start up mod.
[ame]http://youtu.be/GwZuADpFoSc[/ame]
-7 is good for me, and I'll test more timing next time.
Tomei EL catless header
Tomei overpipe
modded full 60mm oe frontpipe
HKS legamax sports cat back
Yobiwan is offline   Reply With Quote
The Following 4 Users Say Thank You to Yobiwan For This Useful Post:
Chad86 (05-09-2016), FRSBRZGT86FAN (03-08-2016), Mr.Impreza (05-10-2016), steve99 (03-08-2016)
Old 04-26-2016, 11:37 AM   #291
Wepeel
Drives: '13 BRZ Ltd
Yes those tables are not defined in the standard oft defs if you are using V2x tunes you can use wayno's defs for oft tunes see bottom of linked post below
http://www.ft86club.com/forums/showthread.php?t=83945
once you load up wayno's defs for your rom those tables will show up in romraider
The tables are always in the tune its just that those tables were not indexed in the standard oft definitions
Okay, just want to make sure I have this right. I'm trying to modify the cold start tables on my OFT Stage 2 UEL 93 map. My car is A01C. I loaded the OFT A01C def file in RomRaider, and the OFT A01C map. I do not see the MAF correction tables.
If I load the A01C xml definition file from Wayno's zip then I will be able to edit those tables in my tune? And no weirdness/bricking will occur?
Wepeel is offline   Reply With Quote
Old 04-26-2016, 09:44 PM   #292
steve99
you will need to use wayno's "oft" defs as he has added those tables in, their not in standard defs. As always have a close look at some tables if they look weird stop something is wrong, the oft guys have made some more calid adjustments in the lastest OFH tunes
Old 05-09-2016, 11:01 PM   #293
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Can my tuner enable this in my next revision? I am in underground parking and I nearly go deaf on startup with my full 3" exhaust and UEL. Will this kill my cat?
Originally Posted by Yobiwan View Post
thank you. !
it works great .
Tomei overpipe
Chad86 is offline   Reply With Quote
Old 05-09-2016, 11:59 PM   #294
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Yes he can, no it will not cause any harm.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
Chad86 (05-10-2016), Yobiwan (05-10-2016)
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 03:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-13-2015 12:53 AM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 07:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 02:35 PM
