Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-15-2012, 01:30 PM | #57 | |
Site Moderator
Drives: Stuff
The problem described here is when an impact gun is used, which can spin the damper shaft at high speeds. The tool itself it on loan, so I can't describe it in detail yet but from other homemade versions I've seen it's just two pieces of steel with a hole cut for the shaft, and then a softer material that won't scratch the shaft around the opening which is then tightened around the shaft. Look up Race Tech Shaft holder (yeah yeah...) on google. Anyways, I'll post pics of the tool monday night during the install we do on my car, and I'll follow that up a little later (when I have time to write it up, could be a day to a week later since I'll be on vacation during that time) with street impressions, track datalogging (stock and with springs), etc. Jackson can correct any of the info above.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
08-15-2012, 01:44 PM | #58 |
You can also use a strap wrench to keep the shaft stationary.
- Andrew |
08-15-2012, 01:46 PM | #59 |
Drives: E46 M3 (daily) / EG Civic (track)
08-15-2012, 01:47 PM | #60 |
Drives: pinto power
if you did not secure the shaft when taking the top nut off, you probably destroyed the shocks.
08-15-2012, 01:55 PM | #61 |
Drives: 4 wheels
I had Sportline (prototype) on my car and I didn't have issue with my car, but of course the Eibach technician put them on. I also know since the car is lowered I have to be more careful with harsh bumps, and irregularities with road conditions. I only had the Sportline (prototype) on my car for 2k miles before i switch setup. I seen Eibach facility and they not playing around, they have actual Mechanical Engineers and Technician, Testing machine, shock dyno, machines to compress the springs, and a bunch of other tools to design and setup products before they go out on the market. Even though I am their test car, I had other company offered their products to me, and I preferred sticking with Eibach knowing they have actual engineers designing and making their products in USA.
The Following User Says Thank You to Pekingduck For This Useful Post: | Jackson (08-15-2012) |
08-15-2012, 02:17 PM | #62 |
Drives: 13 Hot Lava, 01 Miata, 09 Outback
I just want to say thanks to the vendors for participating and being informative and helpful instead of defensive.
-Justin
The Following User Says Thank You to Justin.b For This Useful Post: | SkAsphalt (08-22-2012) |
08-19-2012, 04:06 PM | #63 |
Curious cat.
Drives: 86 GT base M/T - Red
So if one doesn't have a strap wrench on hand and just has regular hand tools lying around, how does one go about installing springs/top hats without screwing anything up?
I noticed Dave ROR mentioning something about a socket or Allen bolt. Can you give me a tip as to where you grip the shaft or whatnot? Also seems pretty plain that an impact gun is a no-no, but won't trying to tighten/untighten the top nuts also rotate the shaft? I'm just curious whether this is a pretty straightforward thing I can get my local tire shop/general auto mechanic to do or whether I need to wait for my alignment & chassis guru to show up (dude's put of town for another month). Edit: here's some pics of the stock shocks & Pro Kit springs from DarrenDriven's review thread in the main suspension topic: Front Spring comparison with stock on top and Eibach Pro-Kit on bottom Rear spring comparison with Eibach Pro-Kit on top and stock on bottom So where do you grip/secure the shafts while installing the top nuts? Sorry if I'm a lil slow and missing something potentially obvious.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
08-19-2012, 04:36 PM | #64 |
Drives: '13 BRZ TLM Spec
My Pro-kit is on the way, doubt I will have any issues like these. I've installed springs on several Scoobies withou any problems...
This is the funniest thing I think I've ever read on this forum Reliablility problems from a Subaru, hahahahahaha.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2016 Crosstrek, 2000 Subaru Legacy B4 RSK 5MT (JDM Import)
08-19-2012, 05:20 PM | #65 | |
You can get a pass through socket set from harbor freight for pretty cheap or just get the driver and specific socket. |
The Following User Says Thank You to xwd For This Useful Post: | ultra (08-19-2012) |
08-19-2012, 05:33 PM | #66 | |
Drives: 13 Scion FR-S, 12 Camaro ZL1
08-19-2012, 05:44 PM | #67 | |
Curious cat.
Big sigh of relief, now I know what to keep an eye out for.
08-19-2012, 06:40 PM | #68 |
08-19-2012, 06:58 PM | #69 |
08-20-2012, 08:21 AM | #70 |
Drives: vrooom...
Here's a good tool set for this job: Craftsman Max Axess
Similar Threads | ||||
Actual Spring difference BRZ vs FRS | Motopythons | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 66 | 05-13-2015 10:12 PM |
Lowest quality spring? | Synack | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 07-26-2012 12:00 PM |
Suspension Installation Warning!!!! | Don@Accelerated | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 07-20-2012 06:44 PM |
Weird GT 86 factory spring rates in GT5? | Spec-Al | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 36 | 03-27-2012 02:30 PM |
FR-S to be priced at $22k and coming in Spring of 2012? | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 92 | 10-25-2011 09:06 PM |
