Old 08-27-2013, 12:03 PM   #57
Wepeel
Drives: '13 BRZ Ltd
How involved of an install is this? I've never had to replace an axle before.
Wepeel is offline   Reply With Quote
Old 08-27-2013, 12:36 PM   #58
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Originally Posted by TRev View Post
My driver axle has started clicking as well. It comes and goes but is mostly only present when I first start driving the car after it has been sitting. I can recreate the issue even when not present by loading up the car against the e-brake. Not what I wanted to deal with right before Nationals but better than it breaking out there. May have to just order one and put it in myself as I don't think the dealer will be able to get through the warranty process prior to me leaving for Lincoln.
How many runs do you think your BRZ has done?
G_Ride is offline   Reply With Quote
Old 08-27-2013, 12:40 PM   #59
TRev
I believe the shop manual calls for 1.3 hours so it shouldn't be too bad.
I would say 225-250 runs. I have 16,210 miles on the car.
TRev is offline   Reply With Quote
The Following User Says Thank You to TRev For This Useful Post:
Wepeel (08-27-2013)
Old 08-27-2013, 12:49 PM   #60
AlanLGuy
Drives: Raven 6 speed Manual FRS
Ahhh crap. I just started hearing a clicking when slipping the clutch at low speed or sometime when turning at low speed. I thought it sounded like it was coming from the driving side front, but I'm worried it may be the axle now.
I've put about 16 autocrosses on the car with Dunlop ZI Star Specs. Suspension is unmodified.
I'm supposed to have an track event this Friday... Not sure whether I should cancel or not
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel.
AlanLGuy is offline   Reply With Quote
Old 08-27-2013, 12:56 PM   #61
G_Ride
G_Ride's Avatar
That's not too bad.
Old 08-27-2013, 02:33 PM   #62
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I had about 350 runs and 15k miles and mine was clanking around. They replaced it last week and all is well. Had about 7 runs in this sunday and shut it down due to a massive screw in my rs3s.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-27-2013, 03:07 PM   #63
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Crap. If @TRev is starting to see issues, that's no good for mine. Probably 200 runs on mine so far...
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-27-2013, 03:19 PM   #64
AlanLGuy
Well I just got done taking the tech at the dealership for a ride .
He claims that's a normal noise for an axle that's being "broken in" nevermind that the car has 12,000 miles on it and it just started making that noise the past week
Old 08-27-2013, 03:37 PM   #65
husker741
Mines getting louder and happening in every gear now. After the dealer telling me everything is fine, I'm just waiting for it to split and then I'll have a real problem. Then they'll have themselves a lawsuit. Dumb fucks.
husker741 is offline   Reply With Quote
Old 08-27-2013, 04:11 PM   #66
AlanLGuy
I'm with you. I have a PDX Friday that I was going to cancel, but since they won't replace it.... I made it very clear to the service manager that if it brakes on me after I brought it in that I fully expect to be reimbursed for all associated costs. She said that in the event there is a defect they would cover all expenses, for what little that is worth... however they noted on the release form that I had "race tires" on the vehicle so I can already see a warranty denial in my future.
Old 08-27-2013, 04:19 PM   #67
qoncept
qoncept's Avatar
I assume you're using DOT approved tires.
qoncept is offline   Reply With Quote
Old 08-27-2013, 04:20 PM   #68
AlanLGuy
Absolutely, Dunlop Direzza ZI Star Specs. I walked right back in and asked why that was on the form when those are DOT approved tires. She said that they had to note I was using non-stock tires which is absolute bullshit
Old 08-27-2013, 04:35 PM   #69
TRev
Anyone know the size of the axle nut? Would be good info for this thread. I am going to pickup a socket to keep with the tools I travel with.
Torque spec is 140ft lbs.
Old 08-27-2013, 04:36 PM   #70
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
subaru axle failing?
hmm
now where did i hear that one before... ohh yeah... a common complaint from every subaru owner since Achilies took Troy.
DDM HID Problem LinknLog Cosmetic Modification (Interior/Exterior/Lighting) 18 04-11-2013 01:43 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 08:07 PM
Problem! axss Scion FR-S / Toyota 86 GT86 General Forum 32 11-24-2012 03:31 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 05:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 11:17 AM
