Old 05-20-2014, 09:24 AM   #407
RojerLockless
RojerLockless's Avatar
Drives: Raven Fr-s
Best armrest ever. Looks great, functions great, best mod I've made to the car by far.
RojerLockless is offline   Reply With Quote
Old 06-17-2014, 11:41 AM   #408
FR-S Hot Lava
FR-S Hot Lava's Avatar
Drives: FR-S Hot Lava (AT)
Just installed my OEM armrest......very happy.....thanks Nigel
FR-S Hot Lava is offline   Reply With Quote
The Following User Says Thank You to FR-S Hot Lava For This Useful Post:
nigel-jdmparts (06-18-2014)
Old 06-18-2014, 03:33 PM   #409
Cards2323
Drives: 2014 BRZ Limited-SWP
Im about to order this too but Im a little hesitant on drilling, anyone tried using a thin 3m tape? I think I may go that route first and see how it turns out.
Cards2323 is offline   Reply With Quote
Old 06-18-2014, 03:55 PM   #410
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
It won't sit flush and you will have a gap.
MokSpeed is offline   Reply With Quote
Old 06-18-2014, 10:43 PM   #411
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
You should drill it , Plus two of the holes need to be countersunk for strength
The above statement is also correct
86SPEED is offline   Reply With Quote
Old 06-19-2014, 11:45 AM   #412
FR-S Hot Lava
There are 3 pegs on the hinge side that you need to drill for to make the armrest sit flush.
I would suggest you download the installation instructions from this thread first, since nothing came with the armrest.
It will show you why you have to drill holes in the console.
At the end it will be worth it.
86SPEED (06-19-2014)
Old 06-19-2014, 09:08 PM   #413
Cards2323
^^Yea I actually read the whole thing but was still going to give it a try...Maybe i'll just suck it up and drill..
Old 07-01-2014, 08:27 PM   #414
bumperhumper
bumperhumper's Avatar
Drives: 2013 FR-S Whiteout
Just received mine, hoping to install it this upcoming weekend.
I wanted to clarify with you guys what things I will need for the install. Hoping to clarify what equipment I need to buy/borrow before the weekend for a smooth install. Here's what I've come up with:
1. drill and drill bits
2. torx wrench (and black sharpie for the silver screws) OR replacement black screws with allen key
3. hammer and nails to create holes to guide drill (optional)
4. some scraper tool used to smoothen the hole after you drill?
5. vacuum
6. the cut outs included in the manual and tape to secure it in place
bumperhumper is offline   Reply With Quote
Old 07-02-2014, 12:10 PM   #415
FR-S Hot Lava
5. vacuum
You forgot one last point:
7. Cold beer for after armrest is installed.
The Following 2 Users Say Thank You to FR-S Hot Lava For This Useful Post:
Draco_PR23 (07-02-2014), omegared19 (07-02-2014)
Old 07-02-2014, 12:42 PM   #416
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
5. vacuum
The template is very helpful. I used a small nail to punch holes where I needed to drill. Drill using smaller drill bit first, then work up to the required size. I didn't bother with a scraper tool. For the screws, I punched them into a cardboard and gave it a couple of coats of black spray. The most important thing you need is patience and not rush the job.
Fizz is offline   Reply With Quote
The Following 3 Users Say Thank You to Fizz For This Useful Post:
bumperhumper (07-03-2014), omegared19 (07-02-2014), racecat (07-03-2014)
Old 07-02-2014, 01:38 PM   #417
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Love this thing. Had mine for about a year now. Super clean and took about an hour to install taking my sweet ass time (with a beer)
omegared19 is offline   Reply With Quote
The Following 2 Users Say Thank You to omegared19 For This Useful Post:
86SPEED (07-02-2014), racecat (07-03-2014)
Old 07-02-2014, 06:56 PM   #418
86SPEED
86SPEED's Avatar
More coming in stock next week -
The Following User Says Thank You to 86SPEED For This Useful Post:
Old 07-05-2014, 05:48 PM   #419
bumperhumper
Very pleased with how it turned out. Like others have stated, I recommend drilling the pegs first, then use the armrest as a template to drill the rest of the holes, using the armrest as a guide. If you use the paper cutout, it will likely not be as precise IMO.
I took the top off and recommend doing so to facilitate the installation process, but it is not necessary to do so. Removing the plastic plugs was tricky - I used a small screw driver. I had no problems putting the top back on once the skeleton was installed.
I painted my screws black with nail polish. I think this was a fine solution, however using a sharpie would probably have been easier in hindsight.
Like others have stated already, it looks like it came from the factory like this. Color/texture matching is spot on, and driving is significantly more comfortable. 10/10 would purchase again
The Following User Says Thank You to bumperhumper For This Useful Post:
racecat (07-05-2014)
Old 07-14-2014, 02:12 AM   #420
husker741
Originally Posted by tg_1981 View Post
I pushed in a few as well. I went to home depot and bought this Attachment 34780 worked out well and feels even stronger with these in. I only used the anchors and was able to use the screws that came with the armrest.
Installed mine this weekend. Thank God you posted this because I was so pissed when 3 of those little stopper things went through the hole. So I just replaced all the rubber things with these Pop Toggles and then it was easy to finish.
Other than that, the install was pretty straight forward with the template and everyone's tips/instructions. I tried to take my time because I felt so bad drilling into my car haha. I just wanted to make sure not to screw it up. I don't like doing any mods that require drilling.
The armrest makes the entire interior look so much cleaner and just nicer. Now you don't have stuff showing that is in the console. It matches perfectly and it sits perfectly for my arm to rest. After over a year and a half of having this part, I'm now very happy I installed it. Thanks for getting this @jpit!
husker741 is offline   Reply With Quote
The Following User Says Thank You to husker741 For This Useful Post:
tg_1981 (09-05-2014)
armrest, jpit
Carsmo Armrest - Short review and quick pics Bleevin CANADA 3 09-27-2014 01:21 PM
new armrest Derrick Cosmetic Modification (Interior/Exterior/Lighting) 3 01-24-2014 11:48 PM
86 Armrest CzechZA AFRICA 30 02-05-2013 07:44 AM
armrest!!! whitefrs Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 04:16 PM
