Old 12-17-2016, 02:17 AM   #4383
Originally Posted by bigbcraig View Post
Ok Mike, got a bit of a curveball for you-
I've been autocrossing for about 6 years now, and currently run an AP1 S2000 in B street class (very nearly stock). I also daily drive a 2015 WRX.
I moved at the beginning of the year and now have poor access to autocross but much better access to HPDE/track days, so those are starting to take a bit of a priority for me.
I've run 2 days of HPDE in the WRX and other than brake pads (stoptech street performance) getting significantly glazed over, it took it like a champ. But, its my daily that I'd rather not modify much and otherwise don't want to ptlut it into a wall.
What are your thoughts about an early FRS/BRZ for a replacement to the S2000 and dual purpose autox/track car? I think Ive read in the thread you actually own a '15 WRX and have significant S2000 experience. Would the twins leave me wanting more? I'm very attracted to having a newish, stiff platform with such low weight.
I'd also be interested in hearing other ideas for track cars - but, to make things harder, I need quite a bit of headroom at my height which makes a miata or S2000 significantly comprimised comfort and streetability wise to meet 'broomstick rule'
Thanks!
I actually own all 3 cars in your post.
Why not track the S2000 first? Do your local tracks REQUIRE you to have a roll bar? Have you considered just putting a rollbar in your S2000?
Old 12-17-2016, 07:44 AM   #4384
bigbcraig
Drives: 2013 BRZ / 2015 WRX
On the books, the clubs I run with require being able to lass a broomstick test. In practice, people are able to run being taller than their rollbars.
From a personal standpoint, though, I don't love the lack of "safety room" in the S.
The only S2k ive sat in and met broomstick (barely) has evo2's bolted to the floor and a custom height RSG roll bar that just exactly fit under the guy's hardtop skin (cf mugen rep) - so too tall for the soft top to work which kinda kills the S2k being a fun street car for me.
FRS's have another 1-2" everywhere around my legs and knees, more modern impact structure, and even 100% stock some clearance to a helmet - so with a bucket and rear roll bar I'd feel quite safe and comfortable which is pretty big for me.
It probably doesnt help that this was the ridealong I got at the end of my first HPDE:
bigbcraig is offline   Reply With Quote
Old 12-17-2016, 11:09 AM   #4385
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If you want safety, get a used, quality-fully-caged car with HANS. It'll be cheaper than a twin and safer on the track. Then you don't need a roll bar on the S2000 for the street. If you want to go cheap, drop your S2000 seat before adding a roll bar. Maybe swap to a race seat. Depending on your height, build, and how you adjust the seat, it may be enough to pass the stick.
Old 12-17-2016, 08:28 PM   #4386
bigbcraig
Even with a race seat, I'd need a roll bar tall enough the soft top can't fold over it to meet broomstick.
Buying a caged car is definitely safest and best way to go to the track, but IMO an exceedingly bad idea on the street. If I could own as many vehicles as possible, I'd have a truck and trailer and caged beater in addition to DD and S2k but wife and driveway space arent gonna let that happen.
So, I'm looking for a dual-purpose car, ideally lightweight RWD but with a little more room inside than the S2k. OR, I could just run my WRX but it could never from a practicality standpoint get seat/roll bar / HANS which is definitely the right direction to go
Old 12-18-2016, 06:40 PM   #4387
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I do. They're not my top choice in pad though; the modulation range is rather small.
How about trying a set of R18?
That's good to know, thanks.
Are the R18's significantly better than the R12?
Old 12-18-2016, 10:34 PM   #4388
In terms of bite? Huge increase.
Old 12-18-2016, 10:39 PM   #4389
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Durability wise? I know they're supposed to deal with heat better...
I would appreciate the extra bite though, the pedal pressure is fairly high for hard braking on the R12.
Old 12-19-2016, 02:46 PM   #4390
OND
OND's Avatar
Drives: 2023 BRZ
My steering wheel is not centered (~10 degrees off) after a wet trackday with lots of drift attempts and fails (several trips onto the grass). The car doesnt pull or show any weird behavior, I actually checked my videos and saw that it happened earlier in the day, so I had lots of track driving with off center steering without noticing significant handling changes. Already scheduled an alignment, but wondering if you guys can provide some insight about possible failure points.
I am hoping nothing is bent and it is just some slipped eccentric bolts etc.
OND is offline   Reply With Quote
Old 12-19-2016, 03:37 PM   #4391
The heat capacity is higher, but not by a TON; the real answer for capacity is BBK.
It may be enough to get you the bite you want though.
Old 12-19-2016, 09:12 PM   #4392
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Bleh. Cheaper to do Essex Parts' AP kit for the RS, I think. I'm tired of messing with mediocre factory brakes.
That said... I paid $124 each for new 4 pot brembos for the RS, lol
Old 12-19-2016, 10:20 PM   #4393
We can help you with that
Old 12-20-2016, 08:55 AM   #4394
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Not street class legal for autocross, unfortunately. The RS hasn't been classed for ST* classes yet either I really want to get a tune and other odds and ends, but oh well
Old 12-20-2016, 04:58 PM   #4395
I know that pain... I'm still waiting on the 17 BRZ/86 too.
Old 12-22-2016, 07:06 PM   #4396
Prmspen
Student Driver
Prmspen's Avatar
Drives: 2016 Subaru BRZ Limited
I have a question about sway bars. Last season I ran several C Street autocross events in by bone stock BRZ. I was fighting understeer the whole time. I want to set my car up as best I can for C Street (or D Street, if the BRZ ends up in that class) in 2017. Obviously I'll get rims and tires. Since I can also swap out one sway bar, I'm looking into options. Seems like most people go for a stiffer front bar, but I read that a stiffer front bar increases understeer.
Does a stiffer front bar increase understeer? Given that I'm prone to understeer already, would I be better off considering a stiffer rear bar instead?
Prmspen is offline   Reply With Quote
