Old 11-01-2014, 04:27 PM   #2073
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Can someone throw me a link to some sway bar comparisons? Can't seem to find a breakdown of the market.
Old 11-01-2014, 05:45 PM   #2074
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
I'm guessing you've seen this, but if not...http://www.ft86club.com/forums/showthread.php?t=49659
dradernh is offline   Reply With Quote
Old 11-01-2014, 06:12 PM   #2075
Not sure what im missing i have a 10 mm socket and ratchet. I guess need a smaller one because its too big. Maybe a 1/4 inch ratchet?
http://www.sears.com/e-z-red-1-4inch...8000P?prdNo=34
http://www.harborfreight.com/14-in-3...het-67994.html
Old 11-01-2014, 07:47 PM   #2076
retrosmiths
Drives: Scion FR-S Whiteout
Mike, which brand of torque wrench would you recommend?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 11-01-2014, 07:47 PM   #2077
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
[pedant]
I apologise for this but I have this insatiable urge to amend this reply.
Front passenger = 1, rear driver = 4.
on LHD cars.
[/pedant]
Old 11-02-2014, 09:43 AM   #2078
Reaper
Reaper's Avatar
Drives: violent
I am definitely thinking stiff bars soft springs for my turbo mostly street car. I need a little front back weight transfer for traction. Eibach sways on full stiff might be in order. Maybe 7k springs? Maybe a little softer? Anyone running something similar on the track?
Old 11-02-2014, 02:53 PM   #2079
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
[pedant]
on LHD cars.
[/pedant]
Good point my. Maybe we should use port and starboard!
Using left and right doesn't work if you're facing backwards but port and starboard is based on facing forward so avoids that confusion.
Or, just a convention that left and right are based on when facing forward.
nzer is offline   Reply With Quote
Old 11-02-2014, 03:20 PM   #2080
gramicci101
Off Topic
A good example of using the entire track.
Old 11-02-2014, 06:17 PM   #2081
dradernh
This seven-second clip shows what that looks like from inside a car:
[ame="https://www.youtube.com/watch?v=b1o-3CEyS44"]T11 Exit Wall at Watkins Glen - AP - YouTube[/ame]
So far, I've had no success in getting students to do this. Obviously, it's not for novices, but as long as you keep your eyes up and down the track (where they're already supposed to be), you can can get up against that wall in perfect safety - the curbing doesn't upset the car, the cushion of air that a car will create and compress against a wall is present and can be felt, your peripheral vision will keep you informed as to where you are, and...it's fun!
Old 11-04-2014, 12:24 PM   #2082
pleong
Drives: 2013 Whiteout FR-S
What can I do to get better traction out of the rear coming out of a corner? I put on the whiteline positive traction inserts.. it definitely feels a LOT better.. but I feel like it's about to slip still.. any recommendations? Maybe a sway bar? I still have the stock sway bar on for now..
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 11-04-2014, 12:32 PM   #2083
dp1
driving smoother faster
Drives: Sold
Camber, tires, clutch LSD, shocks...stock sways work well for me
dp1 is offline   Reply With Quote
Old 11-04-2014, 12:34 PM   #2084
pleong
i have -2.5 degrees camber in the rear with 255/35 RS3 tires.. I do need to upgrade the LSD.. i have kwv3s
Old 11-04-2014, 07:59 PM   #2085
dradernh
Large wing with enough front aero added to balance it.
Old 11-04-2014, 08:30 PM   #2086
OkieSnuffBox
Drives: '23 BRZ Limited
A stiffer sway bar will make your loose condition worse.
Have you been using a probe to check your tire temp (edit sorry)? What's your temp spread? What's your alignment? What psi are you running?
It's possible to run too much camber/not enough toe-in.
