Old 11-21-2015, 09:37 PM   #1
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Coilover Preload collars keeps coming loose
I am at a loss here folks. No results seem to show any good solutions so I am hoping someone here can chime in.
My coilovers preload collars keep coming loose after like 2 weeks of driving.
Whereas there was about 1/2 gap between the height and preload adjustment collars, there is none now.
I have torqued them to Teins recommended settings the 4 times I have reset the preload, and last time I had my friend hold one spanner while I hammered the other.
This is only happening on the fronts. What. the. $%*^.
BDotG is offline   Reply With Quote
Old 11-21-2015, 11:23 PM   #2
babykwiss
Drives: Scion FRS
Do not hammer. If you attach a ratchet where there is a square hole on the spanner, it will give you a ton of leverage to tighten it to a point where it wont move anymore. I had a similar problem when I had just installed my Tein coilovers. It was only the front that kept coming lose. After doing the method above, it has not moved at all for 6 months.
babykwiss is offline   Reply With Quote
The Following User Says Thank You to babykwiss For This Useful Post:
BDotG (11-23-2015)
Spec d spoiler keeps coming loose select20 Cosmetic Modification (Interior/Exterior/Lighting) 3 10-23-2015 01:28 PM
Benefits of a right preload adjustment? Walla Walla Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-12-2015 11:39 PM
steering wheel coming partially loose balci Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 03-30-2015 03:11 PM
Red stitching is coming loose. Chip Issues | Warranty | Recalls / TSB 7 11-01-2012 11:02 AM
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 09:07 AM
