Old 05-24-2016, 07:07 PM   #1
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Spring Rubbers?
Does anyone have any experience with these? I'm wondering if it might be a good compromise to allow me to keep the spring rates that I have (which I like) but allow me to bump up the spring rate for autocross days.
Any pros/cons of using them? Are they allowed in STX? Does anyone make them specifically for my KW V3 coilovers? I've never used them before, so I'm just looking for input.
To clarify, this is what I am referring to:
Stang70Fastback is offline   Reply With Quote
Old 05-24-2016, 07:20 PM   #2
8R6
8R6's Avatar
Drives: FRS
arent those spring spacers only used for transportation purposes? like when the oem's ship out their cars to the ports and the ports to the dealer lots.
8R6 is offline   Reply With Quote
Old 05-24-2016, 08:50 PM   #3
ryoma
ryoma's Avatar
that looks really sketchy to me lol.
The Following 2 Users Say Thank You to ryoma For This Useful Post:
fumanchu1 (05-26-2016), stevemp5 (05-26-2016)
Old 05-24-2016, 09:16 PM   #4
15limited
15limited's Avatar
You're running V3 coil overs and are trying to use a gimmick like "spring rubbers"?
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following 2 Users Say Thank You to 15limited For This Useful Post:
CrispyCheddar (05-25-2016), Mr.ac (05-24-2016)
Old 05-24-2016, 09:49 PM   #5
Stang70Fastback
A.K.A. Starlord
I've seen them used by other folks at autocross. I don't really know much about them, so I was curious if they were common or not. One guy slipped them into the springs on his restomodded Camaro after a run to stiffen up the rear and eliminate some understeer.
It seemed kind of sketchy to me too but the little bit of Googling I did at work today led me to believe they are used in NASCAR and things so it can't be completely brainless, but maybe it isn't a good idea. I have no idea. Was just looking for a way to increase the spring rate without changing the spring.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
strat61caster (05-25-2016)
Old 05-25-2016, 01:26 AM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Spring rubbers will be categorized by spring size, go for a search see if you can find something that looks like it fits and if it's affordable buy it. I think V3's are 60mm springs but I'm not positive, it will likely take some legwork to find the right parts.
Yes, it's been a staple in NASCAR for decades, also Indycar and Outlaw/Sprint Cars. I say try it, maybe it's the perfect fit, maybe it's a disaster, maybe it's the ticket to top time of the day. Trying things is how you find an edge.
ineedyourdiddly
Stang70Fastback (05-25-2016)
Old 05-25-2016, 01:44 AM   #7
Stang70Fastback
A.K.A. Starlord
I just want to make sure I won't damage anything. I can't see why it would, though. Thanks for the info!
Old 05-25-2016, 11:57 AM   #8
Gunman
Drives: 2019 Mazda Miata RF
We use spring rubbers all the time, it's the only way you can change spring rate during a pit stop
Old 05-25-2016, 12:01 PM   #9
gramicci101
Off Topic
How does one calculate the new spring rate to make sure you're getting what you want?
Old 05-25-2016, 12:56 PM   #10
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
It's not a simple calculation.
Spring rates are based on the diameter of the "wire", diameter of the coil, and the number of active coils.
LINK to Engineer's Edge
Spring rubber supports and couples the motion of adjacent coils. It doesn't completely deactivate a coil, but it reduces its contribution to the active coil count. Less effective coils = stiffer overall rate.
You can see in the table below that it can add 5-10% to the effective spring rate.
LINK to Hot Rod Magazine article
For the record, you can do this very safely. It's better to run the right spring... but you won't damage anything, even with multiple coils coupled.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following 3 Users Say Thank You to Shankenstein For This Useful Post:
8R6 (05-25-2016), gramicci101 (05-25-2016), strat61caster (05-25-2016)
Old 05-25-2016, 01:03 PM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I seriously thought it was going to be this. Sorry, Guess I'm down in OT too much...
Old 05-25-2016, 04:31 PM   #12
strat61caster
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
8R6 (05-26-2016), Leonardo (05-25-2016)
Old 05-25-2016, 05:00 PM   #13
Stang70Fastback
A.K.A. Starlord
Ha! I am running those coilover covers tho, haha.
Old 05-25-2016, 05:24 PM   #14
Norville Rogers
Drives: Subaru BRZ
I've used these for years in other vehicles. Mostly for preventing rear sag when heavily loaded.
Booze cruises etc ������
Never had any problems and worked perfectly
Norville Rogers is offline   Reply With Quote
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 03:42 AM
WTB Clock Spring Gazooks113 Want-To-Buy Requests 0 07-18-2015 09:18 PM
WTB TRD Spring gepeyo Want-To-Buy Requests 0 02-10-2015 08:26 PM
Spring help RavenEight6 Brakes, Suspension, Chassis 1 09-10-2014 07:09 PM
WTB RCE spring or RS*R spring mounted on stock strut jshum Want-To-Buy Requests 1 10-11-2013 02:47 PM
