Drives: SSM BRZ
Front Pipe Install Gasket Issue?
Hello,
I recently got a MXP catless front pipe installed at a new mechanic as a lot of frs/brz guys in my area recommended him. In the instructions, it says to reuse the oem donut gasket but the new mechanic said that they used a flat head gasket instead as the fitment is better? Does anyone know if its fine or should I go back to my old mechanic to get him to put in the donut gasket? He said it was fine and they didn't find any leaks but will I run into any problems in the future?
#3 |
Drives: 2014 Scion FRS
donut gasket
i reused mine from the stock FP, no leaks |
| The Following User Says Thank You to WhiteFRS69 For This Useful Post: | congee (07-22-2015) |
#4 |
Drives: SSM BRZ
What should I listen for if theres an exhaust leak? So far, I haven't noticed any issues with it and ive driven about 100km
Also, on the rare occasion when I tap the gas, I hear a faint wining sound but not sure if thats the drop in filter or exhaust. It happened before I got my front pipe installed too.
#5 | |
but just start the car, and rub your hands around the area you think you have an exhaust leak, if you feel anything, than you have a leak |
#6 |
Drives: '13 FR-S Argento
From what I have seen on after market catback systems is if the midpipe has a flex joint, the supplied gasket will be a flat type. If there is no flex joint in the midpipe (as is the case on the stock midpipe) a donut gasket is used. Either way, I personally would want some kind of device that allowed the header and front pipe to move independently from the midpipe.
As for your wining sound you will have to provide a lot more information or a video of the problem for us to figure out what it is. |
| The Following User Says Thank You to DM7 For This Useful Post: | congee (07-22-2015) |
| no flange for donut gasket on J2 front pipe | k0tkmnd | Engine, Exhaust, Transmission | 1 | 06-05-2015 03:04 PM |
| Front Pipe donut gasket | EightSix93 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-02-2015 10:02 PM |
| Front pipe to mid pipe gasket? | ryoma | Engine, Exhaust, Transmission | 6 | 04-30-2015 01:27 AM |
| Installing front pipe...need gasket sealant? | Fizz | Engine, Exhaust, Transmission | 10 | 07-23-2014 11:40 AM |
| front pipe use donut gasket or not | garfull | Engine, Exhaust, Transmission | 2 | 12-09-2013 04:20 PM |
