Old 06-08-2015, 03:04 PM   #1
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Techron/Fuel Additives Question
Here in California we are treated to a paltry 91-octane super unleaded as are best choice (unless u find a specialty shop) to fill up with, so I was considering adding some Techron or some other octane boost/FI cleaner to my next fill-up. I saw in the manual it says not to add any "fuel system cleaners" to the gas tank. Just curious if anyone has had any issues with using these products? Thanks.
MJones_RB is offline   Reply With Quote
Old 06-08-2015, 03:05 PM   #2
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Depending on where you fill up, the gasoline already has these. No need to add extra.
This is why I don't go to third party / gas stations that offer discounted gas without additives.
Also by fuel system cleaners, they mean the kinds that AutoZone tries to upsell you on every time you go in.
The Following 4 Users Say Thank You to LucidMomentum For This Useful Post:
KalbiCool88 (06-08-2015), MJones_RB (06-08-2015), soulreapersteve (06-08-2015), Tcoat (06-08-2015)
Old 06-08-2015, 03:57 PM   #3
Chimera
Drives: FRS
I have used Seafoam motor treatment in my car without issue. Only about 2x, just over 20000. TBH I wouldn't bother with octane boosters, you'll never get the same mix every time and then your car is going to spend a lot of time from tank to tank learning its current Octane.
The Following 2 Users Say Thank You to Chimera For This Useful Post:
MJones_RB (06-08-2015), Tcoat (06-08-2015)
Old 06-08-2015, 06:29 PM   #4
Cal3000
Drives: Panda FR-S
A bottle of octane booster from the store will probably add +0.1 to the octane level. It's pointless.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
Old 06-08-2015, 06:47 PM   #5
Koa
define issue, and what are you attempting to prevent by using Seafoam?
Have you seen evidence of our injectors/heads under even heavy E85 use before? It's pretty encouraging that we don't need to Seafoam or otherwise tamper with our maintenance schedule by and large. FA20 turning out to be a good engine
The Following User Says Thank You to Koa For This Useful Post:
Old 06-08-2015, 07:40 PM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I'm of the opinion that most if not all fuel additives are snake oil at best.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
humfrz (06-08-2015), TheVoiceOfReason (06-08-2015)
Old 06-08-2015, 07:50 PM   #7
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
OFT+e85 is a great alternative to pee.
I mean 91 "fuel". If it can really even be called that.
Old 06-08-2015, 08:24 PM   #8
Tromatic
I use Klotz Uplon (Klingon, I think) fuel lube. Cricket's don't like it. Like Shutter said, E85 is the answer. ETA: A tank of E85 is probably the best "cleaner" you can buy.
The Following User Says Thank You to Tromatic For This Useful Post:
Tcoat (06-08-2015)
Old 06-08-2015, 08:55 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Cal3000 View Post
It's +0.1 pointless.
Fixed that for you.
-alex
Cal3000 (06-11-2015)
Old 06-08-2015, 11:50 PM   #10
Chimera
Drives: FRS
Honestly, its more habit than reasoned. It's not exactly expensive, though not cheap either really I guess.. Anyways, it cannot hurt I don't think, and it may help. I haven't had issues running tanks with an entire bottle of Seafoam. IIRC one was on 93 and the other was on e85. Running 93 right now.
I won't make any claim at all that I would think you need to add motor treatment at all, but I did it both times while helping with my dads car (corvette around 180k) and my girlfriends car (acura rsx with issues......, around 120k)
Old 06-09-2015, 12:35 AM   #11
Tromatic
Stop with the Seafoam crap, right now.
strat61caster (06-09-2015)
BRZ Nav Question Regarding Fuel Prices Ec1990 Electronics | Audio | NAV | Infotainment 0 09-14-2014 09:56 PM
Fuel System Max Out Question nlowell Engine, Exhaust, Transmission 7 08-19-2014 10:24 PM
Quick question about fuel firl21 Engine, Exhaust, Transmission 8 06-03-2013 10:13 PM
Myth about Fuel Additives Grishbok Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 09-20-2012 01:32 AM
Fuel Additives ArKiTeCkT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 40 06-13-2012 04:26 AM
