Old 05-03-2015, 01:12 AM   #1
Drakelee117
Drives: Subaru BRZ 2015
Driving stick shift (twins vs any other sticks)
I've been driving manual for almost a year now. I started with an really old VW Santana (Most popular car in China but I don't think it was ever sold here in the US) back in Chinese driving school, and now I've been getting pretty good with the BRZ too. At least I feel like I can ask the car to behave the way I want it to with the clutch, rev matching and all that. But today I drove my buddy's Golf GTI with stick shift and it almost blew my mind. I mean, the difference was so big it's SCARY.
For me the way the clutch feels like is always a free range at first until the biting point, once it hits that point there is another range with a mechanic feel, depends on how much you release it you know how the RPM behaves. As for the gears, it's always a clear H. But when I drove the GTI, the clutch almost feels like the braking pedal in an auto, it's so low that you release it a bit and the car goes. Also the gears are so vague you get rooms to play in every single gear unlike in my car I can almost feel the gears grinding against each other and how it disengages.
Anyway, my question is, does anybody have any idea what am I talk about with the gears? Which one is the norm among typical cars with stick shift? To me the GTI is almost like an electric switch with the tranny, clutch: on/ off, gears: 1 2 3 4 5 6 instead of the direct mechanic feel.
Drakelee117 is offline   Reply With Quote
Old 05-03-2015, 05:17 AM   #2
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
You aren't imagining it, The clutch is extremely vague. The friction point is hard to feel so it's hard to putt putt around without slipping it too much or being a little jerky.
Even my little Sambar van with the 3 banger and rubber band clutch is easier to drive slow and smooth. My RX7s super single was infinitely more drivable as well. My old Silvia's twin plate was a hair more difficult to drive smooth, but even with the tighter engagement range at least I could feel the plates starting to drag and I, thus, liked it better. Only the triple in the Skyline is worse than the twin's clutch because it's an on/off switch.
Under a decent amount of thrust the clutch is less of a PITA, but I don't rip it along much so it's irritating. There are ways to change the feel, though. Check the drivetrain forums and you will see some tricks. One is removing a spring on the clutch pedal and the other is switching the slave cylinder on the transmission to a smaller bore size.
Old 05-03-2015, 06:12 AM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
How many miles on the car?
imo it's practice practice practice. When cars are different it makes things interesting, if you had the same clutch in a minivan as you did in a 911 GT3 I think it'd be kind of lame.
As said above, there are ways to change it but I wouldn't rush it, the helper spring is easy and many people swear by moving the pedal closer to the floor (which I could write a fair amount about disagreeing with that but I'll save it for when I'm asked). Those are the two free mods.
http://www.ft86club.com/forums/showthread.php?t=84622
http://www.ft86club.com/forums/showthread.php?t=8040
http://www.ft86club.com/forums/showthread.php?t=77390
ineedyourdiddly
Old 05-03-2015, 07:48 AM   #4
humdizzle
Drives: 2018 GT3 / 2015 M3
every car is different man. it takes a few days to really adjust your mind to the timing of the clutch and where it catches. some can be heavy/light, catch high/low, have 12 inches of travel or 4 inches.
humdizzle is offline   Reply With Quote
Old 05-03-2015, 07:53 AM   #5
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I'll ask
Old 05-03-2015, 08:09 AM   #6
strat61caster
I'll ask
1. I had a clutch fail on me (on my old pickup), not sure if I lost hydraulic pressure, the pressure plate collapsed or what, point is the clutch went to the floor and at the very end of the travel it seemed to engage enough for me to get it in and out of gear and limp it home without grinding to high heaven.
If I had adjusted the pedal to be closer to the floor I think I would have been stranded and not known to move the pedal back even if I had the tools.
2. You do not need to go all the way to the floor to shift smoothly and safely with the oem setup, in doing so I find that I can operate the clutch more quickly because I only need to go a few inches, just barely hitting the halfway point of the stroke, foot strike fast like cobra. If I had the engagement point down low I would be operating it like a cave man, foot down, foot hit floor, move gear lever, lift foot off floor, a gross exaggeration but all of this stuff is subjective anyway, there's that delay as you waste time and energy putting force into the pedal stop (which will likely break eventually like it did on my pickup a few weeks ago) and waiting for that feedback to know you can do your shift and lift off again.
3. New discovery that is hardly relevant, I broke my foot and with the cast there exists the possibility that if I'm not positioned correctly my foot catches on the dead pedal, the pedal box, or the brake. Given that my clutch catches 'high' up on the stroke I am still able to shift without fumbling if my left foot doesn't land on the pedal quite right. Would not have been the end of the world with a lower clutch pedal, just would have taken a second or two longer to reposition and try again and maybe a bit of grinding in the process.
All just ridiculous speculation based on the cars that I've driven. If I were to operate a 5-ton clutch that's an inch off the floor I would figure it out and work with it before giving up or tearing it apart, I'm not saying this way is the only way. There's enough advantages in the factory setup that I'm not itching to change it.
I might try removing the helper spring at some point but other than that I'm pretty happy with it. The car is by no means an easy one to drive when it comes to the MT part, it takes practice.
ineedyourdiddly
Old 05-03-2015, 12:17 PM   #7
Drakelee117
I think most of you guys misunderstood. I meant I drove the GTI and the clutch was REALLY easy but feels not as precise and mechanical as the twins. I drive my BRZ just fine but when I drove the GTI the friction point is all the way to the floor and from the point to all the way released it's very vague.
Bottom line, I feel like the twins' clutch is much harder but much more engaging with the driver and mechanical.
Old 05-03-2015, 01:01 PM   #8
M12Power
M12Power's Avatar
Drives: 2015 Firestorm Scion FR-S 6MT
I personally think the clutch in the twins is just about perfect. It's certainly no worse than my previous manual cars. The bite point is just about right. Full engagement comes quickly, but it's still smooth and progressive, and I can engage it just fine without giving it any extra revs.
The manual gearbox, despite its quirks (e.g., difficulty shifting into 2nd when cold, grinding, etc.), is still the best manual gearbox I've come across in a street car. I love the positive, mechanical feel as well as the short throws and the close shift gates.
M12Power is offline   Reply With Quote
Old 05-03-2015, 01:24 PM   #9
dirtymax
Gold Member
dirtymax's Avatar
Drives: 14' SWP BRZ MT limited
maybe I'm crazy but I feel like the idle is to low in this car or I suck with this clutch. I've been rowing gears for 25 years now so it's not new to me but the low torque is
dirtymax is offline   Reply With Quote
Old 05-03-2015, 02:58 PM   #10
ryoma
ryoma's Avatar
for me, it's all about the guessing game. I still am not completely satisfied with the clutch after 2k+ miles. I adjusted my pedal so it grabs about 1 inch off the floor since that's what I'm used to. so besides the lack of feedback, I just estimate how much off the floor my foot is. I have no feeling in the clutch at all so I just guess the distance it travels. I rely on muscle memory to get it right, and it's not bad. what gets me though, is the gas pedal. there's a deadzone of about 1-2cm before anything happens. I came from an 86 MR2 where throttle response was instant because it used cables instead of this DBW crap. I hate DBW. hopefully I can remove that deadzone with a tune later on down the road.
Old 05-03-2015, 04:34 PM   #11
themadscientist
Hotlink Terrorist
I'm leaving mine alone. I don't like it, but the point of this car was it was very close to perfect and I am not going to screw with it. After the waranty is up, ok, but for now it stays stock.
Old 05-03-2015, 05:37 PM   #12
strat61caster
Yup, just gotta use more gas, the low idle is a consequence of maximizing fuel economy.
ineedyourdiddly
Old 05-03-2015, 05:58 PM   #13
A lot of trusted guys swear by this but I haven't tried it myself just yet:
Old 05-03-2015, 07:53 PM   #14
ajaxthebetter
Drives: 2014 Subaru BRZ LTD 6MT
I put in my Perrin Filter early on, but I want to say that it seemed like it raised the idle by about 1 to 200 rpm. Can't recall, but I do "feel" like it was a bit easier to get going post drop in. Maybe placebo.
ajaxthebetter is offline   Reply With Quote
Driving stick: A short(ish) guide boogle BRZ First-Gen (2012+) — General Topics 24 11-20-2014 12:31 AM
To those who learnt auto driving before stick sci3 Scion FR-S / Toyota 86 GT86 General Forum 64 08-16-2014 10:30 PM
Commuters driving stick rawrmatty Scion FR-S / Toyota 86 GT86 General Forum 142 02-24-2014 03:00 PM
Stick shift school in Houston? nitewolfgtr Southwest 6 09-07-2013 01:32 PM
AutoGuide.com: Parents Push Teens To Drive Stick to Avoid Distracted Driving poormans_LFA Other Vehicles & General Automotive Discussions 15 01-25-2012 10:02 AM
