| CANADA Canada |
Drives: 2013 Scion FRS
Etests, turbos, and tunes?
I want to turbo this car. Will Ecutek or OFT be able to toggle the o2 sensors to keep them in a "readiness" state and show cat efficiency? Or must I definitively need the primary cat in order to pass the obd2 test? This whole area is still quite fuzzy to me. I met a WRX guy who's car was modded to the tilt (gt3076r, huge injectors, catless, etc.) and he said this new obd2 test was in fact easier to pass. He has a Cobb Access port and I can't remember exactly what he said but with the Cobb you can configure it to pass even with no cats and all.
Yes, etesting this car is still a few years away but I am planning for the future now. I want to turbo the car and that removes the primary cat. It's not like I want to go catless because I will still continue to run a cat on the car further downstream because of smell and environmental reasons. It's just that the turbo kits I am deciding between all remove the primary cat. So, will any of the software for this car allow me to toggle etest readiness and clear any unwanted CEL's? Thanks. |
#2 |
If the tune has the proper CEL's disabled, then you should be fine.
#3 |
#4 |
Who is doing the tuning? They should be able to easily answer that for you.
#5 |
PhoneFlash by EcuTeK
You can disable any CEL you like, but without a cat in the header it will likely never pass the emissions readiness monitors for the rear o2.
Sincerely, Zach Delicious Tuning |
#6 | |
Drives: 2015 Subaru BRZ
#7 | |
![]() Sincerely, Zach Delicious Tuning |
#8 |
Drives: 4-Runner Sport - 13' BRZ SportTech
If you want to save yourself the trouble, there are a couple of turbo kits that enable you to use the stock header or provide a main cat on their own setup.
The WORKS kit and the PTuning kits both use the stock header and will allow you to keep the stock cat. Also, there is a GReddy turbo kit that comes with a catalytic converter. I'm not sure if it's sold in North America, but there are sites where you can order direct from Japan.
Top Tier Imports - Check out my build journal HERE
#9 | |
I've seen a totally catless STI pass the Ontario (Canada) OBD test no problem.
#10 | |
:shrug: Sincerely, Zach Delicious Tuning |
#11 | |
I dug this up
http://forums.nasioc.com/forums/showthread.php?t=358978 Quote:
| Turbos for sale | Anthony7515 | Engine, Exhaust, Bolt-Ons | 9 | 07-05-2014 01:20 PM |
| Oilless turbos?? | Shit Luck | Forced Induction | 21 | 12-07-2013 03:50 AM |
| Small Turbos? | SamS | Forced Induction | 30 | 11-18-2013 11:00 AM |
| WRX/STI turbos on FA20 | mrk1 | Forced Induction | 9 | 10-04-2013 08:44 AM |
| snails and turbos | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 12-27-2012 04:44 PM |
