CANADA Canada
Old 05-04-2015, 10:44 AM   #1
autobot84
Drives: 2013 Scion FRS
Etests, turbos, and tunes?
I want to turbo this car. Will Ecutek or OFT be able to toggle the o2 sensors to keep them in a "readiness" state and show cat efficiency? Or must I definitively need the primary cat in order to pass the obd2 test? This whole area is still quite fuzzy to me. I met a WRX guy who's car was modded to the tilt (gt3076r, huge injectors, catless, etc.) and he said this new obd2 test was in fact easier to pass. He has a Cobb Access port and I can't remember exactly what he said but with the Cobb you can configure it to pass even with no cats and all.
Yes, etesting this car is still a few years away but I am planning for the future now. I want to turbo the car and that removes the primary cat. It's not like I want to go catless because I will still continue to run a cat on the car further downstream because of smell and environmental reasons. It's just that the turbo kits I am deciding between all remove the primary cat.
So, will any of the software for this car allow me to toggle etest readiness and clear any unwanted CEL's?
Thanks.
autobot84 is offline   Reply With Quote
Old 05-04-2015, 01:06 PM   #2
wparsons
wparsons's Avatar
If the tune has the proper CEL's disabled, then you should be fine.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
autobot84 (05-04-2015), grant (05-04-2015)
Old 05-04-2015, 11:54 PM   #3
autobot84
Do you know what provisions would need to be disabled? It would suck to mod the car extensively only to find out I shot myself in the foot come etest time.
Old 05-05-2015, 12:02 AM   #4
wparsons
wparsons's Avatar
Who is doing the tuning? They should be able to easily answer that for you.
flickr
Old 05-05-2015, 12:29 PM   #5
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
You can disable any CEL you like, but without a cat in the header it will likely never pass the emissions readiness monitors for the rear o2.
Sincerely,
Zach
Old 05-05-2015, 04:33 PM   #6
IBill4You
Drives: 2015 Subaru BRZ
Sincerely,
Zach
I was under the impression that with EcuTek, tuners had the capability of forcing emissions ready status in order to pass an OBD2 plug in type emissions test. I understand that what you're saying is this is false, and that the FI guys will have to completely remove their turbo's and bolt the factory exhaust manifold back in place to to pass the emissions readiness check?
IBill4You is offline   Reply With Quote
Old 05-05-2015, 04:56 PM   #7
DeliciousTuning
From what we've seen EcuTek can never really force a readiness monitor, it can only deactivate CEL's. So while for example we can deactivate the rear o2 sensor, the readiness monitor for rear o2 will never clear if it has no signal to begin with.
Sincerely,
Zach
Old 05-05-2015, 07:03 PM   #8
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
If you want to save yourself the trouble, there are a couple of turbo kits that enable you to use the stock header or provide a main cat on their own setup.
The WORKS kit and the PTuning kits both use the stock header and will allow you to keep the stock cat.
Also, there is a GReddy turbo kit that comes with a catalytic converter. I'm not sure if it's sold in North America, but there are sites where you can order direct from Japan.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 05-05-2015, 08:22 PM   #9
wparsons
wparsons's Avatar
Sincerely,
Zach
Unless you remove the secondary O2, it should have a signal... from my understanding, "disabling" the CEL is done by raising the limit to a value that will never be hit, so in the eyes of the ECU everything is fine.
I've seen a totally catless STI pass the Ontario (Canada) OBD test no problem.
flickr
Old 05-05-2015, 08:34 PM   #10
DeliciousTuning
All I can say is what you can and can't do from my own experience with EcuTek. I can't comment on one person or another that did or didn't pass an OBD test with a catless exhaust.
:shrug:
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
wparsons (05-06-2015)
Old 05-06-2015, 02:36 AM   #11
autobot84
I dug this up
http://forums.nasioc.com/forums/showthread.php?t=358978
Originally Posted by Mike@dynocomp.com View Post
With the ECUTEK you can actually set the perameters for the CELs. If your test station simply plugs into the OBD port to check that the syetems pass I would say you have a pretty good chance if these perameters have been set correctly. I think in general with the sophistication of a stock ECU you are prolly looking at the cleanest burning tune and the best chance of passing. Of course standards seem to vary by station and I don't work @ any of them... But if I did I would pass ya.
Mike
The Following User Says Thank You to autobot84 For This Useful Post:
IBill4You (05-06-2015)
Turbos for sale Anthony7515 Engine, Exhaust, Bolt-Ons 9 07-05-2014 01:20 PM
Oilless turbos?? Shit Luck Forced Induction 21 12-07-2013 03:50 AM
Small Turbos? SamS Forced Induction 30 11-18-2013 11:00 AM
WRX/STI turbos on FA20 mrk1 Forced Induction 9 10-04-2013 08:44 AM
snails and turbos carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 10 12-27-2012 04:44 PM
