Old 03-01-2015, 09:36 PM   #1
Amir Ghadiri
Amir Ghadiri's Avatar
At what point do we need to upgrade head studs and main studs?
Could anybody with first hand experience chime in on how much power the factory head studs and main studs can handle?
I'm currently building my motor and trying to determine if it's worth doing for the power goals I've got in mind.
Thanks for your input!!
Amir Ghadiri is offline   Reply With Quote
Old 03-01-2015, 10:41 PM   #2
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Well considering people have done 500whp on the stock block for extended periods, I'd say that's around the safest currently explored. However, if you're rebuilding your engine either make sure your studs are within spec if you're reinstalling or buy new OEM studs.
That said, you should spend the extra money and upgrade considering it's pretty cheap for ARP fasteners.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
Amir Ghadiri (03-03-2015)
Old 03-02-2015, 12:47 AM   #3
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
From building EJ motors, the head studs are more dependent on the boost you plan to run to prevent head lift, and the case bolts I'm not sure what the failure point was. The head studs are cheap enough to run just for insurance. I did read about the case bolts messing with the main journal oil clearances though because of the different torque specs. What's your power target?
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
Old 03-02-2015, 01:18 AM   #4
Amir Ghadiri
I'll be running 20psi on pump and possibly 27-28 on e85. I'm assuming power will be at approx 425-450 and 550-575 wheel, but I don't necessarily have a hp goal I need to meet.
I was thinking I'd just upgrade the head studs and keep factory case studs, and it sounds like that may be a good plan?
Old 03-02-2015, 11:15 AM   #5
zkv476
zkv476's Avatar
You definitely want head studs for that level of boost. But yes that's a good plan. Unless you are building a car for time attack or majority track duty and harsh abuse you don't really need the case bolts. They require a decent bit of work alongside them, since they oval the main bearings if you just put them in.
Old 03-03-2015, 12:13 PM   #6
Amir Ghadiri
Okay cool, thanks for your help!!
WTB OEM Wheel Studs Anthony Want-To-Buy Requests 8 08-27-2014 04:22 PM
WTB: tires and studs jammz Wheels and Tires 0 02-24-2014 11:29 PM
summit point main 9-14 -9-15 subaruferrucci Tracking / Autocross / HPDE / Drifting 15 09-17-2013 06:48 AM
SUMMIT POINT MAIN, still NA and 2650 weight. Racecomp Engineering Tracking / Autocross / HPDE / Drifting 3 08-19-2013 02:12 PM
Extened Studs? BlaineWasHere Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-29-2013 12:29 PM
